4831|9
WDG不能产生复位的问题 [复制链接]
晕倒,这么个问题实在没着了。
不好意思,我咨询的是WDG不能产生复位
用例程能进入中断,但是无论禁止中断还是
在中断中不更新初值
都不能产生控制器的复位!!
我没有在DEBUG状态。
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name          : main.c
* Author             : MCD Application Team
* Version            : V2.0.1
* Date               : 06/13/2008
* Description        : Main program body.
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
#include "platform_config.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
ErrorStatus HSEStartUpStatus;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void NVIC_Configuration(void);
void GPIO_Configuration(void);
void Delay(vu32 nCount);
/* Private functions ---------------------------------------------------------*/
* Function Name  : main
* Description    : Main program.
* Input          : None
* Output         : None
* Return         : None
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* System Clocks Configuration */
  RCC_Configuration();
  /* GPIO configuration */
  GPIO_Configuration();
  /* Check if the system has resumed from WWDG reset */
  if (RCC_GetFlagStatus(RCC_FLAG_WWDGRST) != RESET)
  { /* WWDGRST flag set */
    /* Set GPIO_LED pin 6 */
     GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8);    //LED ON
    /* Clear reset flags */
    RCC_ClearFlag();
  else
  { /* WWDGRST flag is not set */
    /* Reset GPIO_LED pin 6 */
   GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8);   //LED OFF
  /* NVIC configuration */
  NVIC_Configuration();
  Delay(700000);
  Delay(700000);
  Delay(700000);
  Delay(700000);
  /* WWDG configuration */
  /* Enable WWDG clock */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_WWDG, ENABLE);
  /* WWDG clock counter = (PCLK1/4096)/8 = 244 Hz (~4 ms)  */
  WWDG_SetPrescaler(WWDG_Prescaler_8);
  /* Set Window value to 65 */
  WWDG_SetWindowValue(65);
  /* Enable WWDG and set counter value to 127, WWDG timeout = ~4 ms * 64 = 262 ms */
  WWDG_Enable(127);
  /* Clear EWI flag */
  WWDG_ClearFlag();
  /* Enable EW interrupt */
  WWDG_EnableIT();   //注释这里不能造成STM32复位
  while (1)
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if (HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 0 wait state */
    FLASH_SetLatency(FLASH_Latency_0);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK */
    RCC_PCLK1Config(RCC_HCLK_Div1);
    /* Select HSE as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_HSE);
    /* Wait till HSE is used as system clock source */
    while (RCC_GetSYSCLKSource() != 0x04)
  /* GPIOA, GPIOB and SPI1 clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
                         RCC_APB2Periph_SPI1, ENABLE);
* Function Name  : GPIO_Configuration
* Description    : Configures the different GPIO ports.
* Input          : None
* Output         : None
* Return         : None
  GPIO_InitTypeDef GPIO_InitStructure;
  /*led*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
* Function Name  : NVIC_Configuration
* Description    : Configures NVIC and Vector Table base location.
* Input          : None
* Output         : None
* Return         : None
  NVIC_InitTypeDef NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
  /* 2 bits for Preemption Priority and 2 bits for Sub Priority */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  NVIC_InitStructure.NVIC_IRQChannel = WWDG_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
* Function Name  : Delay
* Description    : Inserts a delay time.
* Input          : nCount: specifies the delay time length.
* Output         : None
* Return         : None
  for (; nCount != 0; nCount--);
#ifdef  DEBUG
* Function Name  : assert_failed
* Description    : Reports the name of the source file and the source line number
*                  where the assert_param error has occurred.
* Input          : - file: pointer to the source file name
*                  - line: assert_param error line source number
* Output         : None
* Return         : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d ", file, line) */
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
* Function Name  : WWDG_IRQHandler
* Description    : This function handles WWDG interrupt request.
* Input          : None
* Output         : None
* Return         : None
void WWDG_IRQHandler(void)
  /* Update WWDG counter */
  WWDG_SetCounter(0x7F);   //注释这里不能造成STM32复位!!!!
  WWDG_ClearFlag();
此帖出自stm32/stm8论坛
                                 只能说ST-JLINK 影响了芯片的工作,由他供电不行。   详情 回复 发表于 2008-7-20 00:12
要是能上传文件我实在想让香主验证下工程,呜呜
此帖出自stm32/stm8论坛
61
芯片 STM32 101C6
此帖出自stm32/stm8论坛
64
请问你用的什么硬件?如何判断没有复位
通过程序看到好像在检测到WWDG复位时,会点亮2个LED,但很快又关上了,有可能因为速度太快,你根本没有看见他们被点亮。
此帖出自stm32/stm8论坛
58
LED的闪动
  通过这个:
  Delay(700000);
  Delay(700000);
  Delay(700000);
  Delay(700000);
此帖出自stm32/stm8论坛
88
请在检测到WWDG复位时,打开LED后作个延迟
                                 否则你还没有看到他们亮,程序就到了5楼的部分,LED又被关闭!
此帖出自stm32/stm8论坛
79
不会是连着的仿真器在捣鬼吧,试试
此帖出自stm32/stm8论坛
气死我了,是这个玩意儿在捣鬼
使用   ST LINKII  的USB供电不行!!断开后单独供电,好了。
太郁闷了,实在想不到会是这里。
总算好了,多谢香主帮助。
此帖出自stm32/stm8论坛
108
不是早就有人让你不要用Debug吗
你的问题解决了,可是我的问题你还没有帮我解决:STM32暂不论性能如何,技术支持差强人意
此帖出自stm32/stm8论坛
59
我是不在DEBUG状态,IAR都退出了!
此帖出自stm32/stm8论坛
会议时间:3月18日(周二)09:30签到
参会奖励:电动螺丝刀套装、户外登山包、京东卡
