20733|44
在EK-STM32F学习套件上实现了USB-DFU设备功能 [复制链接]
首先在ST官网上下载了STM32的USB开发套件
地址:http://www.st.com/stonline/products/support/micro/files/um0424.zip
由于此开发套件基于ST的官方开发板,与EK-STM32F的电路有所不同。
比较了一下,不同之处在于
1, 官方的开发套件使用PD.09作为USB识别使能线,而EK-STM32F使用PD.08。
2, 官方的开发套件通过PB.09来判断是否进入DFU模式, 而EK-STM32F的按键使用了PD.03和PD.04。
3,  EK-STM32F没有接外部SPI Flash, 所以只能更新内部flash。
因此修改代码如下:
void DFU_Button_Config(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  /* Enable GPIOD clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);
  /* Configure PD.04 as input floating (Key push-button on EK-STM32F) */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
u8 DFU_Button_Read (void)
  /* Return the value of PD.04 */
  return GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_4);
void Set_System(void)
  FLASH_Unlock();
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
  /* PD.08 used as USB pull-up --> EK-STM32F */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  USB_Cable_Config (DISABLE);
 // SPI_FLASH_Init();
  USB_Cable_Config (ENABLE);
void USB_Cable_Config (FunctionalState NewState)
  if (NewState != DISABLE)
    GPIO_ResetBits(GPIOD, GPIO_Pin_8);
  else
    GPIO_SetBits(GPIOD, GPIO_Pin_8);
修改后烧入EK-STM32F学习板,果然能识别出一个DFU设备。
已上传移植到EKSTM32F的USB开发套件
https://bbs.eeworld.com.cn/upfiles/img/20081/200818174511397.zip
https://bbs.eeworld.com.cn/upfiles/img/20081/200818174737153.zip
下载了后要把001.zip改成zip.001, 002.zip改成zip.002
由于我用的7-zip看上去和大家的winzip不太兼容,所以请按23楼的说明,重新下载。
ZT 23楼如下:
 香水城 发表于 2008-1-9 14:02 ST MCU ←返回版面
23楼: 问题找到了,是楼主使用的压缩软件与Windows自带的不兼容
通过与各方沟通,发现不能正确解压缩的原因是,楼主使用的压缩软件与Windows自带的不兼容。我下载并成功解压楼主的文件包,里面有两个目录,我把他们分别做了两个压缩包,因为项目文件中有相联关系,请下载后把他们放到同一个目录下(STM32F10xUSBLib)。
自建一个STM32F10xUSBLib目录
  下载https://bbs.eeworld.com.cn/upfiles/img/20081/200819135956499.zip文件并解压到STM32F10xUSBLib目录
  再下载https://bbs.eeworld.com.cn/upfiles/img/20081/20081914129199.zip文件并解压到STM32F10xUSBLib目录
最终目录结构应为:
STM32F10xUSBLib
  FWLib
    library
      inc
      src
  USBLib
    demos
      Device_Firmware_Upgrade  本帖介绍的DFU演示软件
      JoyStickMouse
      Mass_Storage
      Virtual_COM_Port
    library
      inc
      src
此帖出自stm32/stm8论坛
                                 我在IAR环境下编译DFU项目,不使用任何优化时,程序代码接近10k,如果开启IAR中最佳代码长度的优化选项,程序代码接近7K。扣除DFU的一些控制代码,其中的USB部分代码我估计在5K左右。   详情 回复 发表于 2008-3-13 17:05
继续
在ST官网下载PC端驱动和应用程序
地址:http://www.st.com/stonline/products/support/micro/files/um0412.zip
安装后运行DfuSeDemo(V2.1),在DFU Device中识别到一个STM Device in DFU Mode设备。
选择Internal Flash,选择STM32 USB开发套件的DFU DEMO中的任意image, 按下Upgrade按键。
出现一个对话框:擦除操作失败
此帖出自stm32/stm8论坛
继续
DFU的代码我曾经在ST的官方开发板上测试过,没有出过错,那么现在的错误在哪里呢?
拿了USB分析仪,看USB线上数据,发现设备总在某次的DFU_GETSTATUS请求后响应一个STALL信号,导致出错。
根据USB DFU协议(下载地址:http://www.usb.org/developers/devclass_docs/DFU_1.1.pdf), 对DFU_GETSTATUS的响应应该由:bStatus(1byte) + bwPollTimeout(3Bytes,以ms为单位) + bState(1byte) + iString(1byte)组成,但看USB线上数据,设备的响应为:00 00 00 00 04 00,显然是要求的Poll Time时间太短,导致设备在擦除flash的等待时间内无法响应PC端的又一个请求。
仔细看u8 *GETSTATUS(u16 Length)的代码:
    case   STATE_dfuDNLOAD_SYNC:
      if (wlength != 0)
        DeviceState = STATE_dfuDNBUSY;
        DeviceStatus[4] = DeviceState;
        if ((wBlockNum == 0) && (Load_Buffer[0] == CMD_ERASE))
          if  (Pointer < 0x800000) /* 64K sectors of SPI Flash */
            DeviceStatus[1] = 0xDC;  /* 1.5 seconds */
            DeviceStatus[2] = 0x05;
            DeviceStatus[3] = 0x00;
                  <=====================此处值得商榷
        else
          DeviceStatus[1] = (wlength >> 8) * 2  ; /* Nb of Pages(of 256 )* 2ms */
          DeviceStatus[2] = 0;
          DeviceStatus[3] = 0;
      else  /* (wlength==0)*/
        DeviceState = STATE_dfuDNLOAD_IDLE;
        DeviceStatus[1] = 0;
   break;
代码在分析到当前操作为CMD_ERASE命令时,仅仅对SPI FLASH的操作定义了Poll的时间,而对内部flash的操作没有定义,因此设备直接返回了0。
察看STM32F103的Datasheet:
Page(1KB)erase time 为 Min20ms,  Max40ms
Word programming time 为 Min20us, Max40us
修改代码如下:
      if (wlength != 0)
          else {
            DeviceStatus[1] = 0x28;
            DeviceStatus[2] = 0x00;
        else
//          DeviceStatus[1] = (wlength >> 8) * 2  ; /* Nb of Pages(of 256 )* 2ms */
          DeviceStatus[1] = (wlength >> 8) * 10  ; /* Nb of Pages(of 256 )* 10ms */
      break;
修改后重新烧录代码,重新执行Upgrade操作,OK。
此帖出自stm32/stm8论坛
77
继续
至于原先在测试DFU代码时为何没有出错,我认为是因为我刚新换了电脑的缘故,PC跑的快了,愿意等待的时间短了。。。。。
DUF搞完,开始考虑image的生成。
PC端的应用程序除了DfuSeDemo,还有个DfuFileManage(V2.1),能将S19,HEX和BIN文件生成DFU文件。
随便找了个LCD的demo,修改lnkarm_flash.xcl文件如下:
// Code memory in FLASH
-DROMSTART=0x8003000
-DROMEND=0x801FFFF
修改stm32f10x_nvic.h文件对于Vector Table地址的定义如下:
#define NVIC_VectTab_RAM             ((u32)0x20000000)
#define NVIC_VectTab_FLASH           ((u32)0x08003000)
使用IAR生成raw-binary文件。
运行DFU File Manager Generation程序, 选择Mullti Bin injection,输入刚才生成的bin文件,选择地址为0x08003000, 生成OK。
运行DfuSeDemo程序,将刚才生成的DFU文件烧录到内部flash中。
按下Reset按键,LCD DEMO程序如愿跑了起来,再次按下Reset按键,同时按下KEY3,PC识别到一个DFU设备。
至此,DFU设备在EK-STM32F学习板上移植成功。
此帖出自stm32/stm8论坛
65
赏两条裤子
本主题帖的选题非常好,为各位学习STM32的USB开了个好头,这个第一条裤子。
3搂在移植的基础上发现了原来程序的Bug,通过对照USB-DFU协议,找到问题所在,使得所有功能正常运行;这就赚到了第二条裤子。
此帖出自stm32/stm8论坛
55
学习中
                                 等我忙完了这段也玩玩强大的DFU
此帖出自stm32/stm8论坛
77
谢谢版主赏裤子,正好要降温了。。。
再接再厉,上传移植到EK-STM32F学习板的USB开发套件。
相关链接:https://bbs.eeworld.com.cn/upfiles/img/20081/200818174511397.zip
此帖出自stm32/stm8论坛
67
继续
文件太大了,压成了两个包,下载了以后要把001.zip改成zip.001, 002.zip改成zip.002
相关链接:https://bbs.eeworld.com.cn/upfiles/img/20081/200818174737153.zip
此帖出自stm32/stm8论坛
77
哈哈~~~谢谢~~~
此帖出自stm32/stm8论坛
67
好,我喜欢。
此帖出自stm32/stm8论坛
66
顶一个,啥事俺也要玩玩。
此帖出自stm32/stm8论坛
75
怎么解压啊!谢谢
                                 怎么解压啊!谢谢
此帖出自stm32/stm8论坛
64
楼上居然连zip文件如何解压都不知道?
                                 外星人?
此帖出自stm32/stm8论坛
先做记号
此帖出自stm32/stm8论坛
86
这帖子不错,有质量
此帖出自stm32/stm8论坛
67
文件是不是有问题啊,解压不了
好像第二个压缩包有问题
此帖出自stm32/stm8论坛
可以解压呀
                                 按8楼指示,下载7楼文件并改名为xxxx.zip.001,下载8楼文件并改名为xxxx.zip.002,这两个文件放到同一个目录下,然后双击文件xxxx.zip.001,既可解压。
此帖出自stm32/stm8论坛
晕倒,还是不行,难道是电脑出问题了??
能否把修改的文件直接打包传上来?
或者发我邮箱吧
liuhang20011@163.com
谢谢
此帖出自stm32/stm8论坛
79
1、3、4楼已经讲解了所有修改的部分,你可以自己手动改一
我这里又下载了一遍,没有问题。估计你是下载的窗口中存文件是改的文件名,这样有可能文件被存为xxxx.zip.001.zip和xxxx.zip.002.zip,这当然有问题。
请务必下载后确认文件名为xxxx.zip.001和xxxx.zip.002!!
看了一下,压缩包里有其他几个例子,不知道是否已经修改过。
此帖出自stm32/stm8论坛
67
报告
压缩包里的DEMO都是已经移植好的
和ST官方的USB开发套件相比,少了一个Audio_Speaker的DEMO,我还没想好怎么改过去。
此帖出自stm32/stm8论坛
