5072|2
918
关于 hw_memmap.h的一点小疑问 [复制链接]
#define FLASH_BASE              0x00000000  // FLASH memory
#define SRAM_BASE               0x20000000  // SRAM memory
#define WATCHDOG0_BASE          0x40000000  // Watchdog0
#define WATCHDOG1_BASE          0x40001000  // Watchdog1
#define GPIO_PORTA_BASE         0x40004000  // GPIO Port A
#define GPIO_PORTB_BASE         0x40005000  // GPIO Port B
#define GPIO_PORTC_BASE         0x40006000  // GPIO Port C
#define GPIO_PORTD_BASE         0x40007000  // GPIO Port D
#define SSI0_BASE               0x40008000  // SSI0
#define SSI1_BASE               0x40009000  // SSI1
#define UART0_BASE              0x4000C000  // UART0
#define UART1_BASE              0x4000D000  // UART1
#define UART2_BASE              0x4000E000  // UART2
#define I2C0_MASTER_BASE        0x40020000  // I2C0 Master
#define I2C0_SLAVE_BASE         0x40020800  // I2C0 Slave
#define I2C1_MASTER_BASE        0x40021000  // I2C1 Master
#define I2C1_SLAVE_BASE         0x40021800  // I2C1 Slave
#define GPIO_PORTE_BASE         0x40024000  // GPIO Port E
#define GPIO_PORTF_BASE         0x40025000  // GPIO Port F
#define GPIO_PORTG_BASE         0x40026000  // GPIO Port G
#define GPIO_PORTH_BASE         0x40027000  // GPIO Port H
#define PWM_BASE                0x40028000  // PWM
#define QEI0_BASE               0x4002C000  // QEI0
#define QEI1_BASE               0x4002D000  // QEI1
#define TIMER0_BASE             0x40030000  // Timer0
#define TIMER1_BASE             0x40031000  // Timer1
#define TIMER2_BASE             0x40032000  // Timer2
#define TIMER3_BASE             0x40033000  // Timer3
#define ADC0_BASE               0x40038000  // ADC0
#define ADC1_BASE               0x40039000  // ADC1
#define COMP_BASE               0x4003C000  // Analog comparators
#define GPIO_PORTJ_BASE         0x4003D000  // GPIO Port J
#define CAN0_BASE               0x40040000  // CAN0
#define CAN1_BASE               0x40041000  // CAN1
#define CAN2_BASE               0x40042000  // CAN2
#define ETH_BASE                0x40048000  // Ethernet
#define MAC_BASE                0x40048000  // Ethernet
#define USB0_BASE               0x40050000  // USB 0 Controller
#define I2S0_BASE               0x40054000  // I2S0
#define GPIO_PORTA_AHB_BASE     0x40058000  // GPIO Port A (high speed)
#define GPIO_PORTB_AHB_BASE     0x40059000  // GPIO Port B (high speed)
#define GPIO_PORTC_AHB_BASE     0x4005A000  // GPIO Port C (high speed)
#define GPIO_PORTD_AHB_BASE     0x4005B000  // GPIO Port D (high speed)
#define GPIO_PORTE_AHB_BASE     0x4005C000  // GPIO Port E (high speed)
#define GPIO_PORTF_AHB_BASE     0x4005D000  // GPIO Port F (high speed)
#define GPIO_PORTG_AHB_BASE     0x4005E000  // GPIO Port G (high speed)
#define GPIO_PORTH_AHB_BASE     0x4005F000  // GPIO Port H (high speed)
#define GPIO_PORTJ_AHB_BASE     0x40060000  // GPIO Port J (high speed)
#define EPI0_BASE               0x400D0000  // EPI0
#define HIB_BASE                0x400FC000  // Hibernation Module
#define FLASH_CTRL_BASE         0x400FD000  // FLASH Controller
#define SYSCTL_BASE             0x400FE000  // System Control
#define UDMA_BASE               0x400FF000  // uDMA Controller
#define ITM_BASE                0xE0000000  // Instrumentation Trace Macrocell
#define DWT_BASE                0xE0001000  // Data Watchpoint and Trace
#define FPB_BASE                0xE0002000  // FLASH Patch and Breakpoint
#define NVIC_BASE               0xE000E000  // Nested Vectored Interrupt Ctrl
#define TPIU_BASE               0xE0040000  // Trace Port Interface Unit
// The following definitions are deprecated.
#ifndef DEPRECATED
// The following are deprecated defines for the base address of the memories
// and peripherals.
#define WATCHDOG_BASE           0x40000000  // Watchdog
#define SSI_BASE                0x40008000  // SSI
#define I2C_MASTER_BASE         0x40020000  // I2C Master
#define I2C_SLAVE_BASE          0x40020800  // I2C Slave
#define QEI_BASE                0x4002C000  // QEI
#define ADC_BASE                0x40038000  // ADC
该头文件定义了 外设的基址,注意后边几个是不推荐使用的。
比如,在配置ADC时推荐使用
ADCSequenceConfigure(ADC0_BASE, 3, ADC_TRIGGER_PROCESSOR, 0);
而非
ADCSequenceConfigure(ADC_BASE, 3, ADC_TRIGGER_PROCESSOR, 0);
没看懂  详情 回复 发表于 2011-3-22 12:05
64
我就这么用过
178
没看懂
