6484|8
各位大哥keil 编译汇编语言,怎么老是报错啊 [复制链接]
;*****************************************************  ONE初始化
                       ORG 0
                       SJMP ONE
                       ORG 0003H
                       LJMP ELEVEN
                       ORG 000BH
                       LJMP NINE
                       ORG 001BH
                       LJMP TEN
                   ONE:LED12 EQU 30H  ;数码管12显示缓存
                LED34 EQU 31H  ;数码管34显示缓存
                LED56 EQU 32H  ;数码管56显示缓存
                COUNT EQU 33H  ;定时器T0(用来走时)计数值存储器(计数中断20次到1秒)
                COUNTS EQU 34H ;定时器T1(用来预置)计数值存储器(计数中断15次到预置值加一)
                HOUR EQU 40H
                MIN EQU 41H
                       SECOND EQU 22H
                       YEAR EQU 50H
                       MONTH EQU 23H
                       DAY EQU 52H
                       RH EQU 60H     ;闹铃小时
             RM EQU 61H     ;闹铃分
             RE EQU 62H     ;闹铃使能
             BM EQU 71H     ;生日-月份
             BD EQU 72H     ;生日-天
             MOV LED12,#0
                       MOV LED34,#0
                       MOV LED56,#0
                       MOV COUNT,#0
                       MOV COUNTS,#0
                       MOV HOUR,#0
                       MOV MIN,#0
                       MOV SECOND,#0
                       MOV YEAR,#0
                       MOV MONTH,#1
                       MOV DAY,#1
                       MOV RH,#0
                       MOV RM,#0
                       MOV RE,#0
                       MOV BM,#6
                       MOV BD,#1
                       BS BIT 00H
             SS BIT 01H
             GS BIT 02H
             FC BIT 03H
             NB BIT 04H
             CLR BS
                       CLR SS
                       CLR GS
                       CLR FC
                       CLR NB
                       SETB 05H   ;生日有效标志位
             MOV IP,#02H;中断优先级:T0>INT0>T1
                       MOV TMOD,#11H
                       MOV IE,#8BH
                       SETB IT0
                       MOV TH0,#3CH  ;50ms
                       MOV TL0,#0B0H
                       SETB TR0
                       MOV R1,#50   ;显示延时用
             MOV R0,#0     ;显示延时用
;**************************************************** TWO检测开关号
            TWO:MOV P0,#0FFH
                     JB P0.5,TWO1
                     MOV RE,#0A0H
                     SJMP TWO2
                TWO1:MOV RE,#0A1H
                TWO2:JB P0.0,TWO4
                     JB P0.1,TWO3
                     MOV LED12,HOUR
                     MOV LED34,MIN
                     MOV LED56,SECOND
                     SJMP THREE
                TWO3:MOV LED12,YEAR
                     MOV LED34,MONTH
                     MOV LED56,DAY
                     SJMP THREE
                TWO4:JB P0.1,TWO5
                     MOV LED12,RH
                     MOV LED34,RM
                     MOV LED56,RE
                     SJMP THREE
                TWO5:MOV LED12,BM
                     MOV LED34,BD
                     MOV LED56,#0BCH
                     SJMP THREE
;************************************** THREE显示主程序(同时包含了闹铃,预置闪烁,闹铃功能)
               THREE:MOV P1,#0
                     MOV P0,#0FFH
                     MOV DPTR,#TAB3
                     JNB SS,THREEB
            SJMP THREEA
          THREEB:LJMP THREE11
      THREEA:JNB P0.3,THREE1
               JNB GS,THREE1
               LCALL TWELVE
                          SJMP THREE4
            THREE1:MOV A,LED34
                          ANL A,#0FH
                          MOVC A,@A+DPTR
                     MOV P2,A
              THREE2:SETB P1.3
                     NOP
                     DJNZ R0,THREE2
                     CLR P1.3
                     MOV A,LED34
                     SWAP A
                     ANL A,#0FH
                     MOVC A,@A+DPTR
                     MOV P2,A
              THREE3:SETB P1.2
                     NOP
                     DJNZ R0,THREE3
                     CLR P1.2
                     JNB P0.2,THREE4
            JNB GS,THREE4
            LCALL TWELVE
                     SJMP THREE7
              THREE4:MOV A,LED12
                     ANL A,#0FH
                     MOVC A,@A+DPTR
                     MOV P2,A
              THREE5:SETB P1.1
                     NOP
                     DJNZ R0,THREE5
                     CLR P1.1
                     MOV A,LED12
                     SWAP A
                     ANL A,#0FH
                     MOVC A,@A+DPTR
                     MOV P2,A
              THREE6:SETB P1.0
                     NOP
                     DJNZ R0,THREE6
                     CLR P1.0
                     JB P0.0,THREE7
            JNB P0.1,THREE7
                     JB P0.3,THREE7
                     JNB P0.4,THREE7
                     JNB GS,THREE7
                     LCALL TWELVE
                     SJMP THREE10
              THREE7:MOV A,LED56
                     ANL A,#0FH
                     MOVC A,@A+DPTR
                     MOV P2,A
              THREE8:SETB P1.5
                     NOP
                     DJNZ R0,THREE8
                     CLR P1.5
                     MOV A,LED56
                     SWAP A
                     ANL A,#0FH
                     MOVC A,@A+DPTR
                     MOV P2,A
              THREE9:SETB P1.4
                     NOP
                     DJNZ R0,THREE9
                     CLR P1.4
      THREE10:DJNZ R1,TWOA
                     SJMP TWOB
          TWOA:LJMP TWO
          TWOB:MOV R1,#50
            CPL GS
            LJMP TWO
              ;**************************正常显示
    THREE11:LCALL EIGHT
             JB NB,THREE12
             JNB BS,THREE12
                      SJMP SEVEN
             THREE12:CLR NB
             MOV A,LED34
                     ANL A,#0FH
                     MOVC A,@A+DPTR
                     MOV P2,A
             THREE13:SETB P1.3
                     NOP
                     DJNZ R0,THREE13
                     CLR P1.3
                     MOV A,LED34
                     SWAP A
                     ANL A,#0FH
                     MOVC A,@A+DPTR
                     MOV P2,A
             THREE14:SETB P1.2
                     NOP
                     DJNZ R0,THREE14
                     CLR P1.2
                     LCALL EIGHT
                     MOV A,LED12
                     ANL A,#0FH
                     MOVC A,@A+DPTR
                     MOV P2,A
             THREE15:SETB P1.1
                     NOP
                     DJNZ R0,THREE15
                     CLR P1.1
                     MOV A,LED12
                     SWAP A
                     ANL A,#0FH
                     MOVC A,@A+DPTR
                     MOV P2,A
             THREE16:SETB P1.0
                     NOP
                     DJNZ R0,THREE16
                     CLR P1.0
                     LCALL EIGHT
                     MOV A,LED56
                     ANL A,#0FH
                     MOVC A,@A+DPTR
                     MOV P2,A
             THREE17:SETB P1.5
                     NOP
                     DJNZ R0,THREE17
                     CLR P1.5
                     MOV A,LED56
                     SWAP A
                     ANL A,#0FH
                     MOVC A,@A+DPTR
                     MOV P2,A
             THREE18:SETB P1.4
                     NOP
                     DJNZ R0,THREE18
                     CLR P1.4
                     LJMP TWO
            TAB3:DB 3FH,06H,5BH,4FH,66H,6DH,7DH,07H,7FH,6FH,40H,7CH,5EH
                   ;0.1.2.3.4.5.6.7.8.9.-.b.d,的字形表"bd"在显示生日时间时显示在LED56
               SEVEN:MOV P1,#01H
                     MOV P2,#76H
                     DJNZ R0,SEVEN
              SEVEN1:MOV P1,#02H
                     MOV P2,#77H
                     DJNZ R0,SEVEN1
              SEVEN2:MOV P1,#04H
                     MOV P2,#73H
                     DJNZ R0,SEVEN2
             BSEVEN3:MOV P1,#08H
                     MOV P2,#73H
                     DJNZ R0,SEVEN3
              SEVEN4:MOV P1,#10H
                     MOV P2,#6EH
                     DJNZ R0,SEVEN4
                     LJMP TWO
               EIGHT:MOV A,RE
                     CJNE A,#0A1H,EIGHT1
                     MOV A,MIN
                     CJNE A,RM,EIGHT1
                     MOV A,HOUR
                     CJNE A,RH,EIGHT1
                     SJMP EIGHT4
              EIGHT1:MOV A,MIN
                     CJNE A,#59H,EIGHT7
                     MOV A,SECOND
                     CJNE A,#59H,EIGHT5
     EIGHT2:MOV A,COUNT
             CJNE A,#10,EIGHT3
          EIGHT3:JC EIGHT7
          EIGHT4:CPL P1.6
                       SETB NB
                     SJMP EIGHT7
          EIGHT5:MOV A,SECOND
                     CJNE A,#51H,EIGHT6
     EIGHT6:JC EIGHT7
                     JNB 10H,EIGHT7
            JB FC,EIGHT7
            SJMP EIGHT2
        EIGHT7:CPL FC
            RET
;******** NINE中断(T0)
       NINE:MOV TH0,#3CH
            MOV TL0,#0B0H
                     SETB TR0
                     INC COUNT
                     MOV A,COUNT
                     CJNE A,#20,INEAA
                     SJMP AAA
                NEAA:LJMP NINE1
                 AAA:MOV COUNT,#0
                     MOV A,SECOND
                     ADD A,#01
                     DA A       ;
            MOV SECOND,A
                     CJNE A,#60H,INEAA
                     MOV SECOND,#0
                     MOV A,MIN
                     ADD A,#01
                     DA A
                     MOV MIN,A
                     CJNE A,#60H,INEAA
                     MOV MIN,#0
                     MOV A,HOUR
                     ADD A,#01
                     DA A
                     MOV HOUR,A
                     CJNE A,#24H,INEAA
                     MOV HOUR,#0
                     MOV A,DAY
                     ADD A,#01
                     DA A
                     MOV DAY,A
            MOV A,MONTH
                     CJNE A,#02H,TEN6A
                     MOV A,YEAR
            ANL A,#0F0H
                     SWAP A
                     MOV B,#10
                     MUL AB
                     MOV 24H,A
                     MOV A,YEAR
                     ANL A,#0FH
                     ADD A,24H
                     JB ACC.0,TEN5A
            JB ACC.1,TEN5A
                     MOV 24H,#01
                     MOV A,DAY
                     CJNE A,#30H,NINE1
                     MOV DAY,#1
                     SJMP NINE0
                EN5A:MOV A,DAY
                     CJNE A,#29H,NINE1
                     MOV DAY,#1
                     SJMP NINE0
    ;**************判断大小月;
            TEN6A:MOV A,MONTH
                     CJNE A,#08H,TEN7A
               TEN7A:JC TEN9A
                     JB 18H,TEN8A
                     MOV A,DAY
                     CJNE A,#32H,NINE1
                     MOV DAY,#1
                     SJMP NINE0
               TEN8A:MOV A,DAY
                     CJNE A,#31H,NINE1
                     MOV DAY,#1
                     SJMP NINE0
               TEN9A:JNB 18H,TEN10A
                     MOV A,DAY
                     CJNE A,#32H,NINE1
                     MOV DAY,#1
                     SJMP NINE0
              TEN10A:MOV A,DAY
                     CJNE A,#31H,NINE1
                      MOV DAY,#1
                NINE0:MOV A,MONTH
                      ADD A,#01
                      DA A
                      MOV MONTH,A
                      SETB 05H
                      CJNE A,#13H,NINE1
                      MOV MONTH,#1
                      MOV A,YEAR
                      ADD A,#01
                      DA A
                      MOV YEAR,A
                NINE1:MOV A,MONTH
                      CJNE A,BM,NINE2
                      MOV A,DAY
                      CJNE A,BD,NINE2
                      JNB 05H,NINE2
                      SETB BS
                NINE2:RETI
    ;**********************************TEN中断(T1)
        TEN:MOV TH1,#3CH
                      MOV TL1,#0B0H
                      SETB TR1
                      INC COUNTS
                      MOV A,COUNTS
                      CJNE A,#15,TENE
                      MOV COUNTS,#0
                      JB P0.0,RBRB
                      JB P0.1,DAT
                      SJMP TIME
                 DAT: LJMP DATE
                 RBRB:JB P0.1,BDAT
                      LJMP RTIME
                 BDAT:LJMP BDATE
                 TENE:RETI
                ;**********************预置时间
       TIME: JNB P0.3,TEN1
                      MOV A,MIN
                      ADD A,#01
                      DA A
                      MOV MIN,A
                      CJNE A,#60H,TENA
                      MOV MIN,#0
                      SJMP TENA
                 TEN1:JNB P0.2,TENA
                      MOV A,HOUR
                      ADD A,#01
                      DA A
                      MOV HOUR,A
                      CJNE A,#24H,TENA
                      MOV HOUR,#0
              TENA:RETI
                ;******************预置日期
       DATE:JNB P0.3,TEN3
                      MOV A,MONTH
                      ADD A,#01
                      DA A
                      MOV MONTH,A
                      CJNE A,#13H,TENB
                      MOV MONTH,#1
                      SJMP TENB
                 TEN3:JNB P0.2,TEN4
                      MOV A,YEAR
                      ADD A,#01
                      DA A
                      MOV YEAR,A
                      SJMP TENB
                 TEN4:JNB P0.4,TENB
                      MOV A,DAY
                      ADD A,#01
                      DA A
                      MOV DAY,A
                 ;***************判断平闰年
             MOV A,MONTH
                      CJNE A,#02H,TEN6
                      MOV A,YEAR
                      ANL A,#0F0H
                      SWAP A
                      MOV B,#10
                      MUL AB
                      MOV 24H,A
                      MOV A,YEAR
                      ANL A,#0FH
                      ADD A,24H
                      JB ACC.0,TEN5
                      JB ACC.1,TEN5
                      MOV A,DAY
                      CJNE A,#30H,TENB
                      MOV DAY,#1
                      SJMP TENB
                 TEN5:MOV A,DAY
                      CJNE A,#29H,TENB
                      MOV DAY,#1
                      SJMP TENB
         TEN6:CJNE A,#08H,TEN7
                 TEN7:JC TEN9
                      JB 18H,TEN8
                      MOV A,DAY
                      CJNE A,#32H,TENB
                      MOV DAY,#1
                      SJMP TENB
                 TEN8:MOV A,DAY
                      CJNE A,#31H,TENB
                      MOV DAY,#1
                      SJMP TENB
                 TEN9:JNB 18H,TEN10
                      MOV A,DAY
                      CJNE A,#32H,TENB
                      MOV DAY,#1
                      SJMP TENB
                TEN10:MOV A,DAY
                      CJNE A,#31H,TENB
                      MOV DAY,#1
                TENB: RETI
                ;**************************预置闹铃时间
      RTIME:JNB P0.3,TEN12
                      MOV A,RM
                      ADD A,#01
                      DA A
                      MOV RM,A
                      CJNE A,#60H,TENC
                      MOV RM,#0
                      SJMP TENC
                TEN12:JNB P0.2,TENC
                      MOV A,RH
                      ADD A,#01
                      DA A
                      MOV RH,A
                      CJNE A,#24H,TENC
                      MOV RH,#0
                 TENC:RETI
     BDATE:JNB P0.3,TEN14
                      MOV A,BD
                      ADD A,#01
                      DA A
                      MOV BD,A
                      MOV A,BM
                      CJNE A,#02H,TEN15
                      MOV A,BD
                      CJNE A,#30H,TEND
                      MOV BD,#1
                      SJMP TEND
                TEN15:CJNE A,#08H,TEN16
                TEN16:JC TEN18
                      JB 18H,TEN17
                      MOV A,BD
                      CJNE A,#32H,TEND
                      MOV BD,#1
                      SJMP TEND
                TEN17:MOV A,BD
                      CJNE A,#31H,TEND
                      MOV BD,#1
                      SJMP TEND
                TEN18:JNB 18H,TEN19
                      MOV A,BD
                      CJNE A,#32H,TEND
                      MOV BD,#1
                      SJMP TEND
                TEN19:MOV A,BD
                      CJNE A,#31H,TEND
                      MOV BD,#1
                      SJMP TEND
                TEN14:JNB P0.2,TEND
                      MOV A,BM
                      ADD A,#01
                      DA A
                      MOV BM,A
                      CJNE A,#13H,TEND
                      MOV BM,#1
                 TEND:SETB 05H
                      RETI
;*******************************ELEVEN中断
      ELEVEN:JNB SS,ELEVEN1
              CLR SS
                        CLR TR1
                        SJMP ELEVEN3
        ELEVEN1:JNB BS,ELEVEN2
              CLR 05H
                        CLR BS
                        SJMP ELEVEN3
                ELEVEN2:SETB SS
              MOV TH1,#3CH
                        MOV TL1,#0B0H
                        SETB TR1
          ELEVEN3:RETI
  ;***************************************************TWELVE  延时程序
             TWELVE:MOV P1,#0
                        MOV P2,#0
                        DJNZ R0,TWELVE
                TWELVE1:MOV P1,#0
                        MOV P2,#0
                        DJNZ R0,TWELVE1
                        RET
此帖出自51单片机论坛
又一个没有错误信息的!  详情 回复 发表于 2011-3-1 19:54
那些表情代表“:”的意思   我的QQ1144784451  请大家帮帮忙,救急啊
此帖出自51单片机论坛
回复 板凳 zhangkai0215 的帖子
我也不知道是怎么回事,你帮我看看吧,加我QQ。我把源程序发给你吧,万分感谢
此帖出自51单片机论坛
出什么错了你不说,你怎么知道一定程序错
请说明下什么提示
此帖出自51单片机论坛
7815
55
裸片初长成(中级)
要学会自己找方法,把一串代码复制出来,很难获得帮助的
恩,至少先把下面的出错信息发出来啊。不然这么长的程序,谁看都头大。
LS的LS有个方法,直接把出错信息复制百度,这招管用,我经常用
此帖出自51单片机论坛
强者为尊,弱者,死无葬身之地
463
闁哄被鍎冲﹢鍛村嫉椤掆偓缁楁﹢宕楅妸鈺佸姤閻犱降鍔忛鎴︽晬瀹€鍐惧殲闁谎嗩嚙缂嶏拷闁瑰瓨鐗為埀顒婃嫹婵炲鍔岄崬锟�
此帖出自51单片机论坛
回复 8楼 zhangkai0215 的帖子
此帖出自51单片机论坛
赞赏
查看全部赞赏
7815
55
裸片初长成(中级)
回复 9楼 123collin 的帖子
此帖出自51单片机论坛
强者为尊,弱者,死无葬身之地
289
此帖出自51单片机论坛
个人签名科学家研究已有的世界,工程师创造未来的世界!
【直播时间】5月28日(周三)上午10:00
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 11
