9014|19
请大家帮我看看,为何无法进入中断呢??只看到灯循环点亮,按键却无法触发中断。 [复制链接]
下面的程序,是我从一个教程的代码上修改的,调了2天,还是不行,真急人。望大家多多指点,谢谢了
#include
GPIO_InitTypeDef GPIO_InitStructure;
EXTI_InitTypeDef EXTI_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
ErrorStatus HSEStartUpStatus;
  void  RCC_Config(void);
  void  GPIO_Config(void );
  void  NVIC_Config(void );
  void  EXTI_Config(void );
  void  Delay(vu32 ncount);
int main(void)
   RCC_Config();
   GPIO_Config();
   NVIC_Config();
   EXTI_Config();
while(1)
  GPIO_SetBits(GPIOD , GPIO_Pin_3);
  GPIO_ResetBits(GPIOD , GPIO_Pin_4|GPIO_Pin_7|GPIO_Pin_13);
  Delay(0xfffff);
  Delay(0xfffff);
  Delay(0xfffff);
  GPIO_SetBits(GPIOD , GPIO_Pin_4);
  GPIO_ResetBits(GPIOD , GPIO_Pin_3|GPIO_Pin_7|GPIO_Pin_13);
  Delay(0xfffff);
  Delay(0xfffff);
  Delay(0xfffff);
  GPIO_SetBits(GPIOD , GPIO_Pin_7);
  GPIO_ResetBits(GPIOD , GPIO_Pin_4|GPIO_Pin_3|GPIO_Pin_13);
  Delay(0xfffff);
  Delay(0xfffff);
  Delay(0xfffff);
  GPIO_SetBits(GPIOD , GPIO_Pin_13);
  GPIO_ResetBits(GPIOD , GPIO_Pin_4|GPIO_Pin_7|GPIO_Pin_3);
  Delay(0xfffff);
  Delay(0xfffff);
  Delay(0xfffff);
//延时程序
for(;ncount!=0;ncount--);
//步骤一系统初始化,使用固件模板中自带的SystemInit();函数即可。
SystemInit();
//该函数配置系统时钟,其函数原型在system_stm32f10x.c
//RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE | RCC_APB2Periph_AFIO , ENABLE);
//使能所用时钟,主要是各个GPIO时钟,不要忘记RCC_APB2Periph_AFIO时钟使能
//步骤二GPIO 配置 ,使用 GPIO_Config()函数
void GPIO_Config(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
* LD1 -> PD7 , LD2 -> PD13 , LD3 -> PD3 , LD4 -> PD4
* B3 -> PB8 , B4-> PC13
RCC->APB2ENR|=0x09;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 |GPIO_Pin_13|GPIO_Pin_3|GPIO_Pin_4;  //配置PD为输出模式,由CPU驱动LED点亮
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //配置PB8为浮空输入模式FLOATING,触发中断1--IPU 上拉
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //配置PC13为浮空输入模式,触发中断2
GPIO_Init(GPIOC, &GPIO_InitStructure);
//步骤三EXTI 的配置。此步相当于单片机的中断配置,使用 EXTI_Config()函数
void EXTI_Config(void)
/* Initialize the EXTI Init Structure parameters */
EXTI_InitTypeDef EXTI_InitStructure;  //声明语句 要写在前面,一句就可以了
GPIO_EXTILineConfig(GPIO_PortSourceGPIOB, GPIO_PinSource9); // 管脚选择
EXTI_ClearITPendingBit(EXTI_Line9);         //清除中断标志位,进入中断后,先做清除中断标志位,否则它会不断响应中断,不断进入中断函数。
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; //上升下降沿都触发 Falling  Rising
EXTI_InitStructure.EXTI_Line = EXTI_Line9; //EXTI_Line8,这个表示的是中断线8。对于外部中断中的GPIO,有16 个中断线,分别是0-15,刚好对应于每个GPIO 端口的0-15 引脚。
EXTI_InitStructure.EXTI_LineCmd = ENABLE;        //启动中断的接收
EXTI_Init(&EXTI_InitStructure);           //外部中断启动
EXTI_GenerateSWInterrupt(EXTI_Line9);
GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource13);
EXTI_ClearITPendingBit(EXTI_Line13);
EXTI_InitStructure.EXTI_Line = EXTI_Line13;
EXTI_GenerateSWInterrupt(EXTI_Line13);
//步骤四NVIC 配置。先解释下NVIC,它的中文全称是“嵌套向量中断控制器"。用的是NVIC_Config()函数
void NVIC_Config(void)
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);         //for中断1
NVIC_InitStructure.NVIC_IRQChannel = EXTI2_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);           //for中断2
NVIC_InitStructure.NVIC_IRQChannel = EXTI3_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
//步骤五中断服务子程序的编写。
void EXTI9_IRQHandler(void)                        //中断1
if ( EXTI_GetITStatus(EXTI_Line9) != RESET )  //判断外部中断1的标志位是否为1,
EXTI_ClearITPendingBit(EXTI_Line9);                   //若外部中断1的标志位为1,则清中断标志位
GPIO_ResetBits(GPIOD , GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_7|GPIO_Pin_13);  //给PD口的3、4、7、13脚置0
Delay(0xfffff);
Delay(0xfffff);
Delay(0xfffff);
EXTI_ClearFlag( EXTI_Line9);           //清中断标志
void EXTI13_IRQHandler(void)                        //中断2
if ( EXTI_GetITStatus(EXTI_Line13) != RESET )
EXTI_ClearITPendingBit(EXTI_Line13);  //清中断
GPIO_SetBits(GPIOD , GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_7|GPIO_Pin_13);        //给PD口的3、4、7、13脚置1(set)
Delay(0xfffff);
Delay(0xfffff);
Delay(0xfffff);
EXTI_ClearFlag( EXTI_Line13);           //清中断标志
此帖出自stm32/stm8论坛
目前 的问题是什么? 还是没有调试通过吗?  详情 回复 发表于 2011-2-22 11:47
2131
至上芯片
回复 楼主 ploughman 的帖子
看程序LZ想让 GPIOB_9与GPIOC_13 产生按键的外部中断
首先要对时钟配置:
你上面的这个:
引脚设置:
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
3:外部中断配置:
EXTI_Config(void);
4:中断配置
如果楼主没有分清中断分组那么可以使用默认优先级
如果楼主想进行分析 请参考例程
这样就配置完成 了,可以参考例程,有问题一起讨论
此帖出自stm32/stm8论坛
个人签名处处留心皆学问!
那个.s文件中断得改成中断函数的名,这个注意了没
此帖出自stm32/stm8论坛
2131
至上芯片
回复 板凳 ddllxxrr 的帖子
正解
目前用的名子为:
void EXTI9_5_IRQHandler(void)
与void EXTI15_10_IRQHandler(void)
此帖出自stm32/stm8论坛
个人签名处处留心皆学问!
回复 4楼 daicheng 的帖子
可否说得再明白些??我是应该把.s文件中的EXTI15_10_IRQHandler和EXTI9_5_IRQHandler都改成上面程序中的EXTI9_IRQHandler和EXTI13_IRQHandler 么?
另外,EXTI15_10_IRQHandler中的15 和10 这两个数字怎么来的??
谢谢,一并向楼上各位热心的回答表示感谢!!
此帖出自stm32/stm8论坛
还有一个问题,硬件上GPIOB_9与GPIOC_13 的端口有上拉电阻
那么IO设置时,就不必设置上拉输入模式了吧?我这里设置的是浮空模式。
我把程序里的中断名字换成了EXTI15_10_IRQHandler和EXTI9_5_IRQHandler,虽然编译通过了,还是不能进入中断。我再试试把.s里的都换成EXTI9_IRQHandler和EXTI13_IRQHandler 看看。
此帖出自stm32/stm8论坛
2131
至上芯片
回复 5楼 ploughman 的帖子
闂傚倸鍊搁崐鎼佸磹閹间礁纾归柟闂寸绾剧懓顪冪€n亝鎹i柣顓炴閵嗘帒顫濋敐鍛婵°倗濮烽崑鐐烘偋閻樻眹鈧線寮撮姀鐘栄囨煕閳╁啨浠︾紒顔瑰墲娣囧﹪鎮欓鍕ㄥ亾閺嶎厼绀夌憸蹇曞垝婵犳艾绠i柣妯烘▕濡粓姊虹粔鍡楀濞堟洟鏌i幘瀛樼闁哄瞼鍠栭弻鍥晝閳ь剟鎮橀柆宥嗙厱闁靛牆鎷嬮崕鏃堟煛鐏炶鈧繂顕i崼鏇炵閹肩补鈧弶妯婇梻鍌欑閹碱偊寮甸鍌滅煓闁硅揪绠戦悡鈥愁熆鐠哄彿鍫ュ几鎼淬劍鐓欓梺顓ㄧ畱閺嬨倝鏌嶇拠鑼婵﹨娅i幏鐘诲箵閹烘繂濡烽梻浣哄帶缂嶅﹦绮婚弽顒侇棨濠电偞娼欓崥瀣缚濞嗘劦鏀伴梻鍌欑閹测€趁洪敃鍌氬瀭闁规鍠氭稉宥夋煙閹澘袚闁绘挻娲熼弻宥夊煛娴e憡娈ф繛瀵稿缁犳垿鈥︾捄銊﹀枂闁告洦鍓涢ˇ顓犵磽娴d粙鍝洪柟鐟版搐閻g兘骞掗幋鏃€鐎婚梺鐟扮摠缁诲倿鈥栨径瀣╃箚闁绘劦浜滈埀顒佸灴瀹曟繄浠︽潪鎸庣☉閳规垹鈧綆浜濋悗顒勬⒑閸涘﹤濮﹂柛鐘崇墵閿濈偤宕ㄧ€涙ḿ鍘藉┑鈽嗗灥濞咃絾绂掑☉娆戠闁割偆鍠庨崝銈夋煃鐟欏嫬鐏︽鐐诧躬閺屾稒绻濋崘鈺冾槹濡ょ姷鍋涢敃銉╁箚閺冨牆顫呴柣妯诲絻椤﹪姊婚崒姘偓鎼佸磹妞嬪海鐭嗗〒姘e亾闁诡喖娼″畷鎯邦檨婵炲瓨鐗犻弻鏇熺箾瑜嶉幊鎰版倿閸忚偐绠鹃弶鍫濆⒔缁夘剚銇勯銏╂█鐎规洩缍€缁犳稑鈽夊▎鎴濆妇闂備礁澹婇崑鍛崲瀹ュ憘锝堛亹閹烘挾鍘介梺瑙勫礃濞夋盯寮稿☉銏$厸鐎光偓鐎n剙鍩屽銈庡亝缁捇宕洪埀顒併亜閹哄秷鍏屾い鈺傜叀閹娼幏宀婂妳闂佽楠搁悥濂稿蓟閿濆绠i柨婵嗘啗閹剧粯鐓熼柟鎯х摠缁€瀣煛瀹€瀣瘈鐎规洘甯掗埞鎴﹀炊閳瑰簱鍋撴繝鍕=濞达絽鎼暩缂備緡鍣崹鑸典繆閻㈢ǹ绀嬫い鏍ㄥ嚬濞煎﹪姊洪幐搴b槈閻庢凹鍙冨畷鎶藉级鐠囩偓妫冮幃鈺呮濞戞鎹曟俊鐐€栭崹鐢杆囬棃娑卞殨妞ゆ劧绠戠壕濂告煟閹邦厽缍戞繛鍫㈠枛濮婃椽妫冨☉杈€嗘繝纰樷偓铏┛闁靛洦鍔欐俊鎼佸煛閸屾瀚奸梺鑽ゅТ濞诧箓鎮¢敓鐙€鏁佹俊銈呮噺閻撴洘淇婇婵嗗惞闁活厽甯為埀顒冾潐濞叉﹢宕归崸妤冨祦婵☆垵鍋愮壕鍏间繆椤栨粌甯舵鐐茬墦濮婄粯鎷呴崫銉ㄩ梺绋款儏閿曨亜鐣烽姀锛勯檮缂佸娉曢ˇ顕€姊洪棃娑氬婵☆偅绋撶划缁樸偅閸愨晝鍘卞銈嗗姦閸嬪嫭鏅堕鐐村€垫慨妯煎亾鐎氾拷闂傚倸鍊搁崐鎼佸磹閹间礁纾归柟闂寸绾惧湱鈧懓瀚崳纾嬨亹閹烘垹鍊炲銈嗗笂缁€渚€宕滈鐑嗘富闁靛牆妫楁慨褏绱掗悩鍐茬伌闁绘侗鍣f慨鈧柕鍫濇閸樻捇鏌℃径灞戒沪濠㈢懓妫濆畷婵嗩吋閸℃劒绨婚梺鍝勫€搁悘婵嬵敂椤愩倗纾奸弶鍫涘妽瀹曞瞼鈧娲樼敮鎺楋綖濠靛鏁勯柦妯侯槷婢规洟姊洪崨濠勭細闁稿孩濞婇幆灞解枎閹惧鍘遍梺鍝勬储閸斿矂鎮橀悩鐢电<闁绘瑢鍋撻柛銊ョ埣瀵濡搁埡鍌氫簽闂佺ǹ鏈粙鎴︻敂閿燂拷闂傚倸鍊搁崐鎼佸磹閹间礁纾归柟闂寸绾惧綊鏌i幋锝呅撻柛銈呭閺屾盯顢曢敐鍡欘槬缂備胶濮锋繛鈧柡宀€鍠栧畷婊嗩槾閻㈩垱鐩弻娑氣偓锝冨妼閳ь剚绻堝濠氬即閻旇櫣顔曢梺缁樺姦閸撴岸鎮甸弴銏♀拺缂佸顑欓崕蹇斻亜閹存繍妯€鐎殿喖顭烽弫鎰緞婵犲嫮鏉告俊鐐€栫敮濠囨倿閿曞倸纾块柟鍓х帛閳锋垹绱撴担濮戭亞绮幒妤佺厽闊洦鏌ㄩ崫鍝勨攽閿涘嫭鏆€规洜鍠栭、娑橆潩妲屾牕鏁介梻鍌欐祰椤骞嗗畝鍕瀭闂侇剙绉撮弸浣肝旈敐鍛殲闁绘挾鍠栭獮鏍庨鈧悘顕€鏌涢悢鍝ュ弨闁哄瞼鍠栧畷娆撳Χ閸℃浼�婵犵數濮烽弫鍛婃叏閻戣棄鏋侀柛娑橈攻閸欏繘鏌i幋锝嗩棄闁哄绶氶弻鐔兼⒒鐎靛壊妲紒鎯у⒔缁垳鎹㈠☉銏犵闁哄啠鍋撻柛銈呯Ч閺屾盯濡烽鐓庘拻闂佽桨绀佸ú顓㈠蓟閺囷紕鐤€闁哄洨鍊妷锔轰簻闁挎棁顕у▍宥夋煙椤旂瓔娈滅€规洘顨嗗鍕節娴e壊妫滈梻鍌氬€风粈渚€骞夐垾瓒佹椽鏁冮崒姘憋紱婵犮垼鍩栭崝鏇㈠及閵夆晜鐓熼柟閭﹀枛閸斿鏌嶉柨瀣伌闁诡喖缍婇獮渚€骞掗幋婵愮€虫繝鐢靛仜閹冲繘宕濆▎鎾宠摕闁绘梻鍘х粈鍕煏閸繃顥滄い蹇ユ嫹
此帖出自stm32/stm8论坛
个人签名处处留心皆学问!
这么做了还是不行,郁闷!
此帖出自stm32/stm8论坛
此帖出自stm32/stm8论坛
2131
至上芯片
此帖出自stm32/stm8论坛
个人签名处处留心皆学问!
回复 10楼 daicheng 的帖子
此帖出自stm32/stm8论坛
我的代码,帮我看看吧
zhongduantest.rar
3.41 MB, 下载次数: 6
exit
此帖出自stm32/stm8论坛
2131
至上芯片
回复 12楼 ploughman 的帖子
此帖出自stm32/stm8论坛
个人签名处处留心皆学问!
回复 13楼 daicheng 的帖子
此帖出自stm32/stm8论坛
啊,崩溃啊~~~程序还没有调通啊,Jlink突然连接不上了
此帖出自stm32/stm8论坛
2131
至上芯片
回复 15楼 ploughman 的帖子
此帖出自stm32/stm8论坛
个人签名处处留心皆学问!
7233
192
此帖出自stm32/stm8论坛
回复 16楼 daicheng 的帖子
此帖出自stm32/stm8论坛
原来,我接上串口,JLINK就不能connect了,但是不连串口也无法调试串口啊
此帖出自stm32/stm8论坛
2131
至上芯片
回复 19楼 ploughman 的帖子
此帖出自stm32/stm8论坛
个人签名处处留心皆学问!
福禄克有奖直播:高精度测温赋能电子制造 报名中!
直播时间:2025年2月28日(周五)上午10:00
直播主题:高精度测温赋能电子制造
小伙伴们儿快来报名直播吧~好礼等你拿!
