5887|11
哪位兄弟研究过EPI指点下!!!! [复制链接]
#define EXT_SRAM_BASE           0x68000000 //***************************************************************************** // //! Initializes any daughter-board SRAM as the external RAM heap. //! //! When an SRAM/Flash daughter board is installed, this function may be used //! to configure the memory manager to use the SRAM on this board rather than //! the SDRAM as its heap.  This allows software to call the ExtRAMAlloc() and //! ExtRAMFree() functions to manage the SRAM on the daughter board. //! //! Function PinoutSet() must be called before this function. //! //! \return Returns \b true on success of \b false if no SRAM is found or //! any other error occurs. // //***************************************************************************** tBoolean ExtRAMHeapInit(void) {     volatile unsigned char *pucTest;     //     // Is the correct daughter board installed?     //     if(g_eDaughterType == DAUGHTER_SRAM_FLASH)     {         //         // Test that we can access the SRAM on the daughter board.         //         pucTest = (volatile unsigned char *)EXT_SRAM_BASE;         pucTest[0] = 0xAA;         pucTest[1] = 0x55;         if((pucTest[0] == 0xAA) && (pucTest[1] == 0x55))         {             //             // The memory appears to be there so remember that we found it.             //             g_bExtRAMPresent = true;             //             // Now set up the heap that ExtRAMAlloc() and ExtRAMFree() will use.             //             bpool((void *)pucTest, SRAM_MEM_SIZE);         }     }     else     {         //         // The SRAM/Flash daughter board is not currently installed.         //         return(false);     }     //     // If we get here, all is well so pass this good news back to the caller.     //     return(true); } 具体用法,你参考dk-lm3s9b96中的qs-checkout项目里的如上hans  详情 回复 发表于 2011-1-27 14:55
2641
我现在的项目直接用的GPIO驱动,没有用EPI,到时一起交流吧
126
不懂,帮你顶一下
我公司工程师可以帮你
我公司工程师可以帮你,我们是写TI ARM MCU写了几年了,请找王工13530244817  www.wellida.com
210
回复 沙发 fengzhang2002 的帖子
斑竹这个头像看起来怎么这么像小童鞋哇 ?
回复 5楼 zhengjiewen 的帖子
随便找的,呵呵,因为我是公司年龄最小的,所以弄个小孩的
这次我用到的9b92的开发板,上面的RAM和显示器一下子占用了好几十个引脚,现在外设不够用,所以准备把屏的数据线放在RAM上,也就是外部扩展总线的第八位,这样可以弄出一些外设出来。但是EPI我并不是很了解。
918
回复 7楼 zhangyao 的帖子
我也不太了解,帮顶。
49
以后一起学习,正好要用到EPI
回复 9楼 whctx 的帖子
你在用EPI做外部SDRAM吗?我准备在上面挂一个显示屏的8根数据线。但EPI之前没用过,想问下,是不是初始化SDRAM后,直接相当于内部RAM使用吗?
tBoolean
        pucTest[0] = 0xAA;
        pucTest[1] = 0x55;
    else
        return(false);
    return(true);
个人签名In God I trust!
回复 11楼 dcknightdc 的帖子
这样的用法用过,但不知道用的时候有什么注意的东西没,还有我现在复用了一个显示屏的数据线
