48418|1
有关C8051F的485串口通信问题 [复制链接]
这个程序为什么返回数据总是0?
#include "compiler_defs.h"
#include "c8051f930_defs.h"
#include "stddef.h"
#include "stdio.h"
#define SYSCLK       24500000          // SYSCLK frequency in Hz
#define BAUDRATE     9600            // Baud rate of UART in bps 115200
unsigned char RXD;
unsigned char TXD;
//unsigned char i;
SBIT (t,SFR_P2,3);      //接收使能
void Timer_Init(void);
void UART_Init(void);
void Port_IO_Init(void);
void Oscillator_Init(void);
void Interrupts_Init(void);
void Init_Device(void);
void TXD_SUB(void);
void RXD_SUB(void);
void UART_ISR(void);
void main(void)
   PCA0MD &= ~0x40;                       // 关闭看门狗
   Init_Device();
   while (1)
//波特率为7500
void Timer_Init()
    TCON      = 0x50;
    TMOD      = 0x20;
    CKCON     = 0x01;
 if (SYSCLK/BAUDRATE/2/256 < 1)
      {TH1 = -(SYSCLK/BAUDRATE/2);
      CKCON &= ~0x0B;                  // T1M = 1; SCA1:0 = xx
      CKCON |=  0x08;
   else if (SYSCLK/BAUDRATE/2/256 < 4)
      {TH1 = -(SYSCLK/BAUDRATE/2/4);
      CKCON &= ~0x0B;                  // T1M = 0; SCA1:0 = 01
      CKCON |=  0x01;
   else if (SYSCLK/BAUDRATE/2/256 < 12)
      {TH1 = -(SYSCLK/BAUDRATE/2/12);
      CKCON &= ~0x0B;
   }                  // T1M = 0; SCA1:0 = 00
   else
      {TH1 = -(SYSCLK/BAUDRATE/2/48);
      CKCON &= ~0x0B;                  // T1M = 0; SCA1:0 = 10
      CKCON |=  0x02;
   TMOD &= ~0xf0;                      // TMOD: timer 1 in 8-bit autoreload
   TMOD |=  0x20;
   TR1 = 1;                            // START Timer1
   TI0 = 1;
void UART_Init()
{ EA=1;
    SCON0     = 0x10;
void Port_IO_Init()
{  // UART TX
    P0MDOUT |= 0x10;                    // Set TX pin to push-pull
    XBR0      = 0x01;
    XBR2      = 0x40;
void Oscillator_Init()
    OSCICN    = 0x82;
//允许中断,允许串口中断;
void Interrupts_Init()
    IE        = 0x90;
// Initialization function for device,
// Call Init_Device() from your main program
    Timer_Init();
    UART_Init();
    Port_IO_Init();
    Oscillator_Init();
    Interrupts_Init();
 t=0;
//串口中断子程序
//此处的延时是对串口接受的响应延时,不可改变
void UART_ISR(void) interrupt 4
    IE =0x00;       //禁止中断
 RI0=0;
    TXD=SBUF0;
    TXD_SUB();
    if (TI0==1)
    {   TI0=0;
        RI0=0;
        IE=0x90;
//串口发送一个字节子程序
//此处的延时涉及到89C52的接受,不可改变
void TXD_SUB()
    IE =0x00;       //禁止中断
    t=1;
 SBUF0=7;
    while(!TI0);  //等待发送结束
 TI0 = 0;   //发送结束标志清零
 t=0;
 IE=0x90;
本文来自电子工程师之家:http://www.eehome.cn/read.php?tid=45865
此帖出自单片机论坛
此帖出自单片机论坛
