2181|0
ATmega164p-20mu原装现货鑫亿电子13418849546 [复制链接]
  • High-performance, Low-power Atmel® AVR® 8-bit Microcontroller
  • Advanced RISC Architecture
  – 131 Powerful Instructions – Most Single-clock Cycle Execution
  – 32 × 8 General Purpose Working Registers
  – Fully Static Operation
  – Up to 20 MIPS Throughput at 20 MHz
  – On-chip 2-cycle Multiplier
  • High Endurance Non-volatile Memory segments
  – 16K/32K/64K Bytes of In-System Self-programmable Flash program memory
  – 512B/1K/2K Bytes EEPROM
  – 1K/2K/4K Bytes Internal SRAM
  – Write/Erase Cycles: 10,000 Flash/ 100,000 EEPROM
  – Data retention: 20 years at 85°C/100 years at 25°C(1)
  – Optional Boot Code Section with Independent Lock Bits
  In-System Programming by On-chip Boot Program
  True Read-While-Write Operation
  – Programming Lock for Software Security
  • JTAG (IEEE std. 1149.1 Compliant) Interface
  – Boundary-scan Capabilities According to the JTAG Standard
  – Extensive On-chip Debug Support
  – Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface
  • Peripheral Features
  – Two 8-bit Timer/Counters with Separate Prescalers and Compare Modes
  – One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture Mode
  – Real Time Counter with Separate Oscillator
  – Six PWM Channels
  – 8-channel, 10-bit ADC
  Differential mode with selectable gain at 1×, 10× or 200×
  – Byte-oriented Two-wire Serial Interface
  – Two Programmable Serial USART
  – Master/Slave SPI Serial Interface
  – Programmable Watchdog Timer with Separate On-chip Oscillator
  – On-chip Analog Comparator
  – Interrupt and Wake-up on Pin Change
  • Special Microcontroller Features
  – Power-on Reset and Programmable Brown-out Detection
  – Internal Calibrated RC Oscillator
  – External and Internal Interrupt Sources
  – Six Sleep Modes: Idle, ADC Noise Reduction, Power-save, Power-down, Standby and
  Extended Standby
  • I/O and Packages
  – 32 Programmable I/O Lines
  – 40-pin PDIP, 44-lead TQFP, 44-pad VQFN/QFN/MLF (ATmega164P/324P/644P)
  – 44-pad DRQFN (ATmega164P)
  • Operating Voltages
  – 1.8V - 5.5V for ATmega164P/324P/644PV
  – 2.7V - 5.5V for ATmega164P/324P/644P
  • Speed Grades
  – ATmega164P/324P/644PV: 0 - 4 MHz @ 1.8V - 5.5V, 0 - 10 MHz @ 2.7V - 5.5V
  – ATmega164P/324P/644P: 0 - 10 MHz @ 2.7V - 5.5V, 0 - 20 MHz @ 4.5V - 5.5V
  • Power Consumption at 1 MHz, 1.8V, 25°C for ATmega164P/324P/644PV
  – Active: 0.4 mA
  – Power-down Mode: 0.1 µA
  – Power-save Mode: 0.6 µA (Including 32 kHz RTC)
  Note: 1. See ”Data Retention” on page 8.
  8-bit
  Microcontroller
  with
  16K/32K/64K
  Bytes In-System
  Programmable
  Flash
  ATmega164P/V
  ATmega324P/V
  ATmega644P/V
  Summary
站长推荐上一条 2/10 下一条
ADI 探索季,邀您在活动帖跟帖,ADI资深工程师将与您一道寻求解决之道!
春晚,最出圈当属穿着棉马甲跳秧歌的机器人”秧Bot”。
转手绢、飞手绢、变换队形,精准度和稳定性甚至超越人类,这背后少不了电机控制技术。
