4246|3
流明学习笔记之四用两种方法实现LED闪烁 [复制链接]
第一种方法就是开发板自己带的那个固件库里的例程
一般都直接装在C盘,
我的安装路径是:C:\StellarisWare\boards\ek-lm3s8962\blinky
为了方便我把它打个包,这个是不用库的
#include "inc/lm3s8962.h"
//! \addtogroup example_list
//! <h1>Blinky (blinky)</h1>
//! A very simple example that blinks the on-board LED.
// Blink the on-board LED.
int
main(void)
    volatile unsigned long ulLoop;
    // Enable the GPIO port that is used for the on-board LED.
    SYSCTL_RCGC2_R = SYSCTL_RCGC2_GPIOF;
    // Do a dummy read to insert a few cycles after enabling the peripheral.
    ulLoop = SYSCTL_RCGC2_R;
    // Enable the GPIO pin for the LED (PF0).  Set the direction as output, and
    // enable the GPIO pin for digital function.
    GPIO_PORTF_DIR_R = 0x01;
    GPIO_PORTF_DEN_R = 0x01;
    // Loop forever.
    while(1)
        // Turn on the LED.
        GPIO_PORTF_DATA_R |= 0x01;
        // Delay for a bit.
        for(ulLoop = 0; ulLoop < 200000; ulLoop++)
        // Turn off the LED.
        GPIO_PORTF_DATA_R &= ~(0x01);
        // Delay for a bit.
程序打包:
blinky.zip (162.32 KB, 下载次数: 29)
看来超简单,下面这个我自己调通的用库的哈:
注意下:
用库时一定要加上如下:
#include "inc/hw_types.h"
#include "inc/hw_memmap.h"
涉及到系统时钟还应加上:
#include "driverlib/debug.h"
#include "driverlib/sysctl.h"
我发现它们都在 driverlib 里,这个是MDK包含的目录,
再有就是用什么加什么的头文件,
程序列出哈:
#include "gpio.h"
#include "drivers/rit128x96x4.h"
//! <h1>Hello World (hello)</h1>
//! A very simple ``hello world'' example.  It simply displays ``hello world''
//! on the OLED and is a starting point for more complicated applications.
// The error routine that is called if the driver library encounters an error.
#ifdef DEBUG
void
__error__(char *pcFilename, unsigned long ulLine)
#endif
delay(int d)
   for(;d;--d)
// Print "Hello world!" to the OLED on the Stellaris evaluation board.
int
main(void)
    // Set the clocking to run directly from the crystal.
    SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN |
                   SYSCTL_XTAL_8MHZ);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);//这里是给F口时钟
 GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, 0x01 );//设F0为输出
    // Initialize the OLED display.
    RIT128x96x4Init(1000000);
    // Hello!
    RIT128x96x4StringDraw("Hello World!", 30, 24, 15);
    // Finished.
    while(1)
      GPIOPinWrite(GPIO_PORTF_BASE,(GPIO_PIN_0 ),0x01);  //F0高电平
   RIT128x96x4StringDraw("TEH LED IS HIGH", 30, 24, 15);//在OLED显示一下
delay(60000);
   delay(60000);
   delay(60000);
   delay(60000);
   delay(60000);
   GPIOPinWrite(GPIO_PORTF_BASE,(GPIO_PIN_0 ),0x00);
   RIT128x96x4StringDraw("TEH LED IS LOW", 30, 24, 15);
   delay(60000);
   delay(60000);
   delay(60000);
   delay(60000);
   delay(60000);
程序打包哈:
blinkcool.zip (279.25 KB, 下载次数: 28)
这么好的贴子,怎么现在才发现呢,呵呵,哎,还让我搞了好久才弄好的东西,其实早就有人发过了,哎~~~菜鸟学习真的不容易啊~~  详情 回复 发表于 2010-12-16 11:11
918
回复 楼主 ddllxxrr 的帖子
呵呵,楼主这么早起发帖,支持一个!
回复 沙发 academic 的帖子
上班之前发地
324
