5193|3
569
写testbench时输入输出数据到文件 [复制链接]
-- Copyright (C) 1991-2005 Altera Corporation
-- Your use of Altera Corporation's design tools, logic functions
-- and other software and tools, and its AMPP partner logic
-- functions, and any output files any of the foregoing
-- (including device programming or simulation files), and any
-- associated documentation or information are expressly subject
-- to the terms and conditions of the Altera Program ******
-- Subscription Agreement, Altera MegaCore Function ******
-- Agreement, or other applicable ****** agreement, including,
-- without limitation, that your use is for the sole purpose of
-- programming logic devices manufactured by Altera and sold by
-- Altera or its authorized distributors.  Please refer to the
-- applicable agreement for further details.
-- This file contains a Vhdl test bench template that is freely editable to
-- suit user's needs .Comments are provided in each section to help the user
-- fill out necessary details.
-- Generated on "06/30/2006 11:18:26"
-- Vhdl Test Bench template for design  :  diohs_task_logic
-- Simulation tool : ModelSim (VHDL)
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_textio.all;
USE std.textio.all;
ENTITY diohs_task_logic_tb IS
END diohs_task_logic_tb;
ARCHITECTURE diohs_task_logic_arch OF diohs_task_logic_tb IS
-- constants
-- signals
SIGNAL t_sig_HSIN : STD_LOGIC_VECTOR(7 downto 0);
SIGNAL t_sig_clk : STD_LOGIC:='0';
SIGNAL t_sig_rstn : STD_LOGIC;
SIGNAL t_sig_hs_in : STD_LOGIC_VECTOR(7 downto 0);
SIGNAL t_sig_pwm_ena_highs : STD_LOGIC;
CONSTANT ClockPeriod:   Time := 10ns;
FILE results:   TEXT is OUT "results.txt";
COMPONENT diohs_task_logic
        PORT (
        HSIN : in STD_LOGIC_VECTOR(7 downto 0);
        clk : in STD_LOGIC;
        rstn : in STD_LOGIC;
        hs_in : out STD_LOGIC_VECTOR(7 downto 0);
        pwm_ena_highs : out STD_LOGIC        );
END COMPONENT;
BEGIN
        tb : diohs_task_logic        PORT MAP (
-- list connections between master ports and signals
        HSIN => t_sig_HSIN,
        clk => t_sig_clk,
        rstn => t_sig_rstn,
        hs_in => t_sig_hs_in,
        pwm_ena_highs => t_sig_pwm_ena_highs
init : PROCESS
-- variable declarations
BEGIN
   -- code that executes only once
   t_sig_rstn <='0';
   wait for 20 ns;
   t_sig_rstn <='1';
WAIT;
END PROCESS init;
always : PROCESS
-- optional sensitivity list
BEGIN
     -- code executes for every event on sensitivity list
     t_sig_clk <= '1';
     wait for 20 ns;
     loop
--      t_sig_clk <= transport'0';
--      wait for 5 ns;
--      t_sig_clk <= transport'1';
--      wait for 5 ns;
     wait for (ClockPeriod/2);
     t_sig_clk <= not t_sig_clk;
   end loop;
END PROCESS always;
PROCESS
variable l : line;
variable good_number: boolean;
variable r: std_logic_vector(7 downto 0);
file vector_file: text is in "values.txt";
begin
    wait for 20 ns;
    while not endfile(vector_file) loop
        readline(vector_file,l);
        read(l,r,good => good_number);
        t_sig_HSIN <= r;
        wait for 1000 ns;
    end loop;
   wait for 200 ns;
   assert false
   report
   "End of simulation"
   severity error;
END PROCESS;
process
constant myw: width:= 8;
constant mys: side:= right;
variable wl: line;
begin
    wait for 30 ns;
    loop
       wait for 1000 ns;
       writeline(results,wl);
       write(wl,t_sig_hs_in,mys,myw);
   end loop;
end process;
END diohs_task_logic_arch;
用到了TEXTIO包里的 read/readline, 和write/writeline
源程序:
--  Library
library ieee;
use ieee.std_logic_1164.all;
-- entity
entity diohs_task_logic is
    port
        clk:                in  std_logic;
        rstn:               in  std_logic;
        HSIN:               in  std_logic_vector(7 downto 0);
        hs_in:              out std_logic_vector(7 downto 0);
        pwm_ena_highs:         out std_logic
end diohs_task_logic;
-- architecture
architecture arch of diohs_task_logic is
-- signal
signal HSIN_reg:                    std_logic_vector(7 downto 0);
signal HSIN_debcnt:                 std_logic_vector(7 downto 0);
begin
--  Process: high speed inputs debounce counter;
    process(rstn,clk,HSIN,HSIN_debcnt,HSIN_Reg)
    begin
        if rstn='0' then
                        HSIN_debcnt<=(others => '0');
                        HSIN_Reg <= (others => '0');
        elsif rising_edge(clk) then
            if HSIN_debcnt = 99 then
                HSIN_Reg <= HSIN;
            else
                HSIN_debcnt <= HSIN_debcnt + 1;
                HSIN_Reg <= HSIN_Reg;
            end if;
        end if;
    end process;
   hs_in <= HSIN_Reg;
    pwm_ena_highs <= not(HSIN_Reg(2) or HSIN_Reg(1) or HSIN_Reg(0));
end arch
此帖出自FPGA/CPLD论坛
参考verilog仿真文件对数据读写要求  详情 回复 发表于 2012-3-13 13:33
6892
顶,好帖!比较完整的表达了写TESTBENCH 时,输入输出数据到文件的整个过程!
此帖出自FPGA/CPLD论坛
个人签名一个为理想不懈前进的人,一个永不言败人!
欢迎光临网上店铺!
51
。。。。请问txt里面的格式是什么?想输入正弦波的数据
此帖出自FPGA/CPLD论坛
6892
此帖出自FPGA/CPLD论坛
欢迎光临网上店铺!
