3550|0
2606
Clock jitter analyzed in the time domain Part 1 [复制链接]
Introduction
Newer high-speed ADCs e outfitted
with a large analog-input bandwidth (about
three to six times the maximum sampling
frequency) so they can be used in undersampling
applications. Recent advances in
ADC design extend the usable input range
significantly so that system designers can
eliminate at least one intermediate
frequency
stage, which reduces cost and power
consumption. In the design of an undersampling
receiver, special attention
has to be
given to the sampling clock, because at
higher input frequencies the jitter of the
clock bees a dominant factor in limiting
the signal-to-noise ratio (SNR).
Part 1 of this three-part article series
focuses on how to accurately estimate jitter
from a clock source and bine it with the
aperture jitter of the ADC. In Part 2, that
bined jitter will be used to calculate the
ADC’s SNR, which will then be pared
against actual measurements. Part 3 will
show how to further increase the SNR of the ADC by
improving the ADC’s aperture jitter, with a focus on optimizing
the slew rate of the clock signal.
Clock jitter analyzed in the time domain Part 1.pdf
302.83 KB, 下载次数: 16
个人签名工程 = 数学+物理+经济
