library IEEE ; use IEEE.std_logic_1164.all ; use IEEE.std_logic_unsigned.all ; use IEEE.numeric_std.all ;
entity key1 is port ( Clk_I : in std_logic ; Rst_I : in std_logic ; key_I : in std_logic ; key_O : out std_logic ); end entity ; architecture rt1 of key1 is type state_type is (s0, s1, s2, s3, s4, s5); signal state : state_type ; signal count : integer range 0 to 80000 ; signal reg : std_logic ; signal key_confirm : std_logic ; begin reg <= key_I ; process (Clk_I, Rst_I) begin if Rst_I = '0' then state <= s0 ; elsif Clk_I'event and Clk_I = '1' then
case state is when s0 => if reg = '1' then state <= s0; else state <= s1; end if ; when s1 => if count = 80000 then count <= 0 ; state <= s2 ; else count <= count + 1 ; state <= s1 ; end if ; when s2 => if reg = '1' then state <= s0 ; else state <= s3; end if ; when s3 => if reg = '1' then state <= s0 ; else state <= s4 ; end if ; when s4 => if reg = '1' then state <= s0 ; else state <= s5 ; end if ; when s5 => if reg ='0' then state <= s0 ; else state <= s5 ; end if ; when others => state <= s0 ; end case ; end if ; end process ; process (Clk_I) begin if Clk_I'event and Clk_I = '1' then case state is when s5 => key_confirm <= '1' ; when others => key_confirm <= '0' ; end case ; end if ; end process ; key_O <= key_confirm ; end rt1; 错误: key_O : out std_logic ); 不应该有分号
