7529|1
569
QUARTUS2编译出错误了 [复制链接]
用quartus 2编译一下程序
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY seg7dec IS
   PORT(bcdin : IN std_logic_vector(3 DOWNTO 0);
        segout : OUT std_logic_vector(6 DOWNTO 0));
END seg7dec;
ARCHITECTURE ver3 OF seg7dec IS
BEGIN
   WITH bcdin SELECT
      segout <= "1000000" WHEN X"0",
          "1100111" WHEN X"1",
          "1101101" WHEN X"2",
          "0000011" WHEN X"3",
          "0100101" WHEN X"4",
          "0001001" WHEN X"5",
          "0001000" WHEN X"6",
          "1100011" WHEN X"7",
          "0000000" WHEN X"8",
          "0000001" WHEN X"9",
          "-------" WHEN OTHERS;
END ver3;
报错说:Error (10430): VHDL Primary Unit Declaration error at ver3.vhd(4): primary unit "seg7dec" already exists in library "work",这个是什么意思,怎么解决啊,谢谢大家啊.........
此帖出自FPGA/CPLD论坛
seg7dec已经存在了,换个名字试试···  详情 回复 发表于 2010-8-31 15:58
221
此帖出自FPGA/CPLD论坛
个人签名学习
