library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.std_logic_arith.all;
entity serial_out is port ( clkin : in std_logic; cntout:in std_logic_vector(7 downto 0); --锁存计数器,由外界控制 parallel:in std_logic_vector(13 downto 0); serial :Put std_logic ); end entity; architecture behav of serial_out is signal temp :std_logic_vector(31 downto 0); begin process(clkin,cntout,temp) variable i:integer range 0 to 31; begin if clkin'event and clkin='1' then if cntout=0 then temp(9 downto 0)<="0101010101"; temp(23 downto 10)<=parallel; temp(31 downto 24)<="11100100"; i:=31; else i:=i-1; end if; end if; serial<=temp(i); end process; end behav;
