3730|6
64
编译没有错误但是不生成sys文件 [复制链接]
一个以前同事的程序 输出文件名设置的是XXX.sys 编译通过但是没有生成XXX.sys
信息如下
Deleting intermediate files and output files for project 'Make File - Win32 Debug'.
--------------------Configuration: Make File - Win32 Debug--------------------
E:\WINDDK\2600
BUILD: Object root set to: ==> objfre
BUILD: Adding /Y to COPYCMD so xcopy ops won't hang.
BUILD: /i switch ignored
BUILD: Compile and Link for i386
BUILD: Loading E:\WINDDK\2600\build.dat...
BUILD: Computing Include file dependencies:
BUILD: Examining e:\temp\multicom_2k_xp\byserial\serial directory for files to compile.
BUILD: e:\temp\multicom_2k_xp\byserial\serial\serial.rc: e:\winddk\2600\inc\crt\winbase.h: cannot find include file
BUILD: e:\temp\multicom_2k_xp\byserial\serial\serial.rc: e:\winddk\2600\inc\crt\wingdi.h: cannot find include file
BUILD: e:\temp\multicom_2k_xp\byserial\serial\serial.rc: e:\winddk\2600\inc\crt\winuser.h: cannot find include file
BUILD: e:\temp\multicom_2k_xp\byserial\serial\serial.rc: e:\winddk\2600\inc\crt\winnls.h: cannot find include file
BUILD: e:\temp\multicom_2k_xp\byserial\serial\serial.rc: e:\winddk\2600\inc\crt\winreg.h: cannot find include file
BUILD: e:\temp\multicom_2k_xp\byserial\serial\serial.rc: e:\winddk\2600\inc\crt\mmsystem.h: cannot find include file
BUILD: e:\temp\multicom_2k_xp\byserial\serial\serial.rc: e:\winddk\2600\inc\crt\winsock2.h: cannot find include file
BUILD: Linking e:\temp\multicom_2k_xp\byserial\serial directory
BUILD: Done
byserial.sys - 0 error(s), 0 warning(s)
我现在也碰到这个问题 我也在找答案 各位高手速度回答一下啊   详情 回复 发表于 2008-10-20 17:02
81
不是提示文件找不到么
75
macwin32.h 似乎是i386才需要  这里没有影响吧
哪位有macwin32.h,wsipv6ok.h文件发给我谢谢
107
这个问题我碰过,有人提示检查SOURCE文件。
该文件有指出sys输出的路径及名字。
你的说不定是这个原因。
81
明明提示有问题啊.按以上楼主的方法查一遍问题吧
build -Zcgw编译
我现在也碰到这个问题
我也在找答案 各位高手速度回答一下啊
