3906|3
在wince5.0 platform manager下面没选项!?? [复制链接]
1、就是在wince5.0 添加选项中的platform manager下面没选项!
我在其他资料上看 应该有 添加选项 ActiveSync  /KITL /TCP IP啊 是不是已经包含了。??
2、开发板和PC可以连接但无法调试??
开发班和PC通过交叉网线连接的,可以把NK。BIN下进去,但是无论怎么设置WINCE或 EVC下的
TOOLS\CONFIGURE 下的DEVICE 属性 都不能进行连接调试 !下载文件
本公司专业承接PCB印制线路板厂家。主要生产单,双以及多层线路板,盲孔,高频板等。最小孔径0.15mm,是小线距0.1mm. 表面处理:防氧化,镀金,镀锡.无铅工艺等等.质量保证,交货及时.最快24小时交货,月产量1.2万个平方米.本企业已经过ISO9000:2000/ISO14001质量休系/环保体系国际认证和UL认证.以及欧洲环保认证(ROHS认证).双赢互利是我们的一贯经营理念。我们期盼与业内朋友放眼世界、展望未来、携手并进、齐享高科技的结晶,共创辉煌! (24小时提供PCB相关技术支持!欢迎您与我们联系) 联系人:萧先生 深圳市奔强电路有限公司 www.szbq168.com TEL:0755-29606209    13798334626 MSN:xhg26270001pcb@hotmail.com SKYPE:LTDLFPCB      QQ:426617608 邮箱:BQPCB@VIP.163.COM   详情 回复 发表于 2007-11-8 11:45
62
If you installed pb ever, and this pb you are using is you second intalling, the removing action of the first PB may not completely, some registry items may not be deleted completely, so you must first delete the registry items, then re-install PB, but I forget where the registry could be deleted..sorry
我通过TCPIP把NK下到开发板!不能自动启动,串口到KITL..就停止了.但NK已经下载完成.
关闭开发板电源再启动,WINCE可以启动,但在串口输出很多错误信息:
Board Name =
InitClock...
Processor = 199Mhz, Bus = 99Mhz
OEMGetExtensionDRAM
Sp=ffffc7cc
ISL1208 write failed 1111
ISL1208 read failed 1111
Test ISL1208, failed to read
VBridge:: VB_INITIALIZED returns [0]
VMini:: VBridge is not initialized!   Bail out..
OEMSetWakeupSource dwSource = 0x18
DeviceFolder::LoadDevice!Enumerate Found deprecated load instructions at (Driver
s\BuiltIn\AFD). Driver cannot be unloaded.
nd deprecated load instructions at (Drivers\BuiltIn\PPP). Driver cannot be unloa
ded.
    Init Raster engine
Clearing screen
Returning from DDI init
Lyg.p: Layout Manager successfully initialized to  1
OEMResetWakeupSource dwSource = 0x11
OEMSetWakeupSource dwSource = 0x11
Maximum Allowed Error 768:
Explorer(V2.0) taskbar thread started.
2.开发板上的系统也出现错误对话框(windows ce Networking)提示::DHCP was unable to obtain an ip
address...
联系人:萧先生
