3204|3
winsocket select 函数的设置为读时返回总是0 [复制链接]
我的代码如下
CUDP_CE *pSocket;
        pSocket = (CUDP_CE*)lparam;
        fd_set fdRead;
        int ret;
        TIMEVAL        aTime;
        char * recvBuf=NULL;
        aTime.tv_sec = 1;
        aTime.tv_usec = 0;
        SOCKADDR_IN tmpAddr;
        int tmpRecvLen;
        int recvLen;
        int iErrorCode;
        char * recvedBuf = NULL;
        int recvedBufLen;
        while (TRUE)
        //收到退出事件,结束线程
                if (WaitForSingleObject(pSocket->m_ExitThreadEvent,0) == WAIT_OBJECT_0)
                        break;
                //将set初始化空集合
                FD_ZERO(&fdRead);
                //将pSocket->m_UDPSocket套接字添加到集合中
                FD_SET(pSocket->m_UDPSocket,&fdRead);
                //调用select函数,判断套接字I/O状态
                ret = select(0,&fdRead,NULL,NULL,&aTime);
                if (ret == SOCKET_ERROR)
                        iErrorCode = WSAGetLastError();
                        pSocket->m_OnUdpError(pSocket->m_pOwnerWnd,iErrorCode);
                        break;
                if (ret > 0)
                        if (FD_ISSET(pSocket->m_UDPSocket,&fdRead))
//要执行的代码
如果ret = select(0,&fdRead,NULL,NULL,&aTime);中变为ret = select(0,NULL,&fdRead,NULL,&aTime);ret就可以为1 不是零 还有一个现象就是fdRead在 select  执行之后为空 请各位大侠帮忙解决
nfds specifies the maximum number of sockets to check. EXAMPLE In this example select waits for data to read from a socket. #include #include #include #include /* This function calls select to wait for data to read from */ /* one of the sockets passed as a parameter.                */ /* If more than 3 seconds elapses, it returns.              */ /* Return value flags. These indicate the readiness of      */ /* each socket for read.                                    */ #define S1READY 0x01 #define S2READY 0X02 waittoread(int s1,int s2) {    fd_set fds;    struct timeval timeout;    int rc, result;       /* Set time limit. */    timeout.tv_sec = 3;    timeout.tv_usec = 0;       /* Create a descriptor set containing our two sockets.  */    FD_ZERO(&fds);    FD_SET(s1, &fds);    FD_SET(s2, &fds);    rc = select(sizeof(fds)*8, &fds, NULL, NULL, &timeout);    if (rc==-1) {       perror("select failed");       return -1;    }    result = 0;    if (rc > 0)    {       if (FD_ISSET(s1, &fds)) result |= S1READY;       if (FD_ISSET(s2, &fds)) result |= S2READY;    }    return result; }   详情 回复 发表于 2008-4-30 16:40
你前一个是指读,,后一个是写,,,改天我也把select用在ce上玩玩,,
67
有点难度哦
EXAMPLE
#include
#include
#include
#include
   fd_set fds;
   int rc, result;
   timeout.tv_sec = 3;
   FD_ZERO(&fds);
   FD_SET(s1, &fds);
   FD_SET(s2, &fds);
   if (rc==-1) {
      return -1;
   result = 0;
   if (rc > 0)
   return result;
