2432|0
串口通信:为什么总是得不到句柄? [复制链接]
我想用vb.net写的程序来取得串口的句柄,但是getlasterror总是得到12的值,查MSDN,注明为The access code is invalid。请各位高手给予指点程序哪儿有问题还是我createfile的参数值有问题:
        Dim hDiskName As Integer
        Dim tFile As StreamWriter
        Dim tmpString As String
        ‘注:diskname="COM1:"
        hDiskName = CreateFile(diskName, GENERIC_READ + GENERIC_WRITE, 0, Nothing, OPEN_EXISTING, 0, Nothing)
        'hDiskName = CreateFile(diskName, &HC0000000, 0, 0, 3, 0, 0)
        If hDiskName.Equals(INVALID_HANDLE_VALUE) Then
            tmpString = diskName + "--Get invalid handle. GetLastError is " + GetLastError().ToString
        Else
            tmpString = diskName + "--" + hDiskName.ToString
        End If
        If File.Exists(tempPath) = False Then
            tFile = File.CreateText(tempPath)
        Else
            tFile = File.AppendText(tempPath)
        End If
        tFile.WriteLine(tmpString)
        tFile.Flush()
        tFile.Close()
