3086|2
中断问题(AT91 A3)高手求救! [复制链接]
  (灯)LED 与PA相连   按钮(SW,一共四个按钮)与PB 相连
#define LED_MASK        (LED1|LED2|LED3|LED4)
#define SW_MASK         (SW1_MASK|SW2_MASK|SW3_MASK|SW4_MASK|SW5_MASK)
高手帮我看看,为什么我按了SW4 ,没有反映呀(好像进不了中断呀)
#include "Board.h"
__ramfunc void aic_software_interrupt(void)
    //* Read the output state
    if ( (AT91F_PIO_GetInput(AT91C_BASE_PIOA) & LED2 ) == LED2 )
        AT91F_PIO_ClearOutput( AT91C_BASE_PIOA, LED2 );
    else
        AT91F_PIO_SetOutput( AT91C_BASE_PIOA, LED2 );
__ramfunc void pio_c_irq_handler ( void )
int dummy;
    if ( (AT91F_PIO_GetInput(AT91C_BASE_PIOA) & LED4 ) == LED4 )
       AT91F_PIO_ClearOutput( AT91C_BASE_PIOA, LED4);
    else
          AT91F_PIO_SetOutput( AT91C_BASE_PIOA, LED4);
    //* enable the next PIO IRQ
   dummy =AT91C_BASE_PIOA->PIO_ISR;
    //* suppress the compilation warning
   dummy =dummy;
    //* while SW3 is push wait
   while ( (AT91F_PIO_GetInput(AT91C_BASE_PIOB) & SW3_MASK ) != SW3_MASK );
int main( void )
//* Begin
    unsigned int   loop_count ;
    AT91PS_AIC     pAic;
        pAic = AT91C_BASE_AIC;
             loop_count = 0 ;
            AT91F_PMC_EnablePeriphClock ( AT91C_BASE_PMC, 1 << AT91C_ID_PIOA ) ;
              AT91F_PIO_CfgOutput( AT91C_BASE_PIOA, LED_MASK ) ;
             AT91F_PIO_SetOutput( AT91C_BASE_PIOA, LED_MASK ) ;
    //* open external PIO interrupt
        //* define switch SW3 at PIO input for interrupt IRQ loop
          AT91F_PMC_EnablePeriphClock ( AT91C_BASE_PMC, 1 << AT91C_ID_PIOB ) ;
          AT91F_PIO_CfgInput(AT91C_BASE_PIOB, SW3_MASK | SW4_MASK);
          AT91F_AIC_ConfigureIt ( pAic, AT91C_ID_PIOB,PIO_INTERRUPT_LEVEL,AT91C_AIC_SRCTYPE_POSITIVE_EDGE , pio_c_irq_handler);
          AT91F_PIO_InterruptEnable(AT91C_BASE_PIOB,SW4_MASK);
        //* set the interrupt by software
         AT91F_AIC_EnableIt (pAic, AT91C_ID_PIOB);
for (;;)
        AT91F_PIO_ClearOutput( AT91C_BASE_PIOA, LED1 );
        delay () ;
        AT91F_PIO_SetOutput( AT91C_BASE_PIOA, LED1 );
        delay () ;
        loop_count ++ ;
    //* Set LED by software interrupt
        if (loop_count == 3)
             loop_count=0;
         //* Software interrupt
             AT91F_AIC_Trig (pAic,AT91C_ID_SYS) ;
//* End
这个程序在中断配置处有问题  详情 回复 发表于 2009-1-13 13:43
你跟踪一下,看看程序到哪停了?
这个程序在中断配置处有问题
