3669|1
75
请教用VB.NET怎么在WinCE下怎么打开一个外部可执行文件。 [复制链接]
此帖出自WindowsCE论坛
c#的一个完整类; public class ShellExecute         {                 public static void Start(string fileName, string parameters)                 {                         int nSize;                         SHELLEXECUTEEX see;                         IntPtr pFile;                         IntPtr pParams;                         see = new SHELLEXECUTEEX();                         nSize = fileName.Length * 2 + 2;                         pFile = localAlloc(MemoryAllocFlags.LPtr, nSize);                         Marshal.Copy(Encoding.Unicode.GetBytes(fileName), 0, pFile, nSize - 2);                         nSize = parameters.Length * 2 + 2;                         pParams = localAlloc(MemoryAllocFlags.LPtr, nSize);                         Marshal.Copy(Encoding.Unicode.GetBytes(parameters), 0, pParams, nSize - 2);        see.lpFile = pFile;                         see.lpParameters = pParams;        ShellExecuteEx(see);                         LocalFree(pFile);                         LocalFree(pParams);                         //return see.hProcess;                 }                 public static void Start(string fileName)                 {                         Start(fileName, "");                 }                 #region localAlloc MemoryAllocFlags                 private static IntPtr localAlloc(MemoryAllocFlags uFlags, int uBytes)                 {                         const int GMEM_FIXED = 0x0000;                         const int LMEM_ZEROINIT  = 0x0040;                         const int LPTR = (GMEM_FIXED | LMEM_ZEROINIT);                         IntPtr ptr = LocalAlloc(LPTR, (uint)uBytes);                         if (ptr == IntPtr.Zero)                                 throw new Exception("Out of memory!");                         return ptr;                 }                 private enum MemoryAllocFlags : int                 {                         Fixed                 = 0x00,                         ZeroInit = 0x40,                         LPtr     = ZeroInit | Fixed                 }                 #endregion                 #region APIs                 [DllImport("coredll.dll")]                 private static extern IntPtr LocalAlloc(uint uFlags, uint Bytes);                 [DllImport("coredll")]                 private static extern IntPtr LocalFree(IntPtr hMem);                 [DllImport("coredll")]                 private extern static int ShellExecuteEx( SHELLEXECUTEEX ex );                 private class SHELLEXECUTEEX                 {                         public UInt32 cbSize                = 60;                         public UInt32 fMask                        = 0;                         public IntPtr hwnd                        = IntPtr.Zero;                         public IntPtr lpVerb                = IntPtr.Zero;                         public IntPtr lpFile                = IntPtr.Zero;                         public IntPtr lpParameters        = IntPtr.Zero;                         public IntPtr lpDirectory        = IntPtr.Zero;                         public int nShow                        = 0;                         public IntPtr hInstApp                = IntPtr.Zero;                         public IntPtr lpIDList                = IntPtr.Zero;                         public IntPtr lpClass                = IntPtr.Zero;                         public IntPtr hkeyClass                = IntPtr.Zero;                         public UInt32 dwHotKey                = 0;                         public IntPtr hIcon                        = IntPtr.Zero;                         public IntPtr hProcess                = IntPtr.Zero;                 }                 #endregion          }  详情 回复 发表于 2007-4-6 16:23
75
c#的一个完整类;
                        int nSize;
                        SHELLEXECUTEEX see;
                        IntPtr pFile;
                        IntPtr pParams;
                        see.lpFile = pFile;
                        LocalFree(pFile);
                        LocalFree(pParams);
                        return ptr;
                        Fixed                 = 0x00,
                        ZeroInit = 0x40,
                #endregion
                #region APIs
                #endregion
此帖出自WindowsCE论坛
