2410开发板开机Reading data from NAND FLASH without ECC isnot recommended
我是刚接触嵌入式的用是优龙的2410开发板,开机进Linux时只是停在QT欢迎界面就没有反应了,下面是启动过程:
Power on reset
Read chip id = ec76
Nand flash status = c0
Env.Os_Auto_Flag=1
* ST2410 Board BIOS V3.01 *
* Http://www.ucdragon.com *
NAND Flash Boot
Please select function :
0 : USB download file
1 : Uart download file
2 : Write Nand flash with download file
3 : Load Pragram from Nand flash and run
4 : Erase Nand flash regions
5 : Write NOR flash with download file
6 : Set boot params
7 : Set AutoBoot parameter,1:linux 2:wince
Read chip id = ec76
Set boot params = root=/dev/mtdblock2 load_ramdisk=0 init=/linuxrc console=ttyS0 mem=64M devfs=mount
Uncompressing Linux............................................................... done, booting the kernel.
Linux version 2.4.18-rmk7-pxa1 (root@localhost.localdomain) (gcc version 2.95.3 20010315 (release)) #2 Thu Nov 18 09:49:37 CST 2004
CPU: ARM/CIRRUS Arm920Tsid(wb) revision 0
Machine: Samsung-SMDK2410
On node 0 totalpages: 16384
zone(0): 16384 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/mtdblock2 load_ramdisk=0 init=/linuxrc console=ttyS0 mem=64M devfs=mount
DEBUG: timer count 15626
Console: colour dummy device 80x30
Calibrating delay loop... 99.94 BogoMIPS
Memory: 64MB = 64MB total
Memory: 62364KB available (1686K code, 343K data, 72K init)
Dentry-cache hash table entries: 8192 (order: 4, 65536 bytes)
Inode-cache hash table entries: 4096 (order: 3, 32768 bytes)
Mount-cache hash table entries: 1024 (order: 1, 8192 bytes)
Buffer-cache hash table entries: 4096 (order: 2, 16384 bytes)
Page-cache hash table entries: 16384 (order: 4, 65536 bytes)
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
CPU clock = 200.000 Mhz, HCLK = 100.000 Mhz, PCLK = 50.000 Mhz
Initializing S3C2410 buffer pool for DMA workaround
usbctl: zombie --> [reset] --> default. Device in default state.
S3C2410 USB Controller Core Initialized
USB Function Character Driver Interface - 0.5, (C) 2001, Extenex Corp.
usbctl: Opened for usb-char
usbctl: Started for usb-char
Starting kswapd
devfs: v1.10 (20020120) Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
tts/00 at I/O 0x50000000 (irq = 52) is a S3C2410
tts/d1 at I/O 0x50004000 (irq = 55) is a S3C2410
tts/02 at I/O 0x50008000 (irq = 58) is a S3C2410
Console: switching to colour frame buffer device 30x40
Installed S3C2410 frame buffer
pty: 256 Unix98 ptys configured
s3c2410-ts initialized
s3c2410-pwm initialized
S3C2410 Real Time Clock Driver v0.1
block: 128 slots per queue, batch=32
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
eth0: cs8900 rev K(3.3 Volts) found at 0xd0000300
cs89x0 media RJ-45, IRQ 37
loop: loaded (max 8 devices)
PPP generic driver version 2.4.1
PPP BSD Compression module registered
Linux video capture interface: v1.00
SCSI subsystem driver Revision: 1.00
NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V)
Creating 5 MTD partitions on "NAND 64MiB 3,3V":
0x00000000-0x00030000 : "boot"
0x00030000-0x00200000 : "kernel"
0x00200000-0x02000000 : "rootfs"
0x02000000-0x03000000 : "ext-fs1"
0x03000000-0x04000000 : "ext-fs2"
usb.c: registered new driver usbdevfs
usb.c: registered new driver hub
usb-ohci.c: USB OHCI at membase 0xe9000000, IRQ 26
usb.c: new USB bus registered, assigned bus number 1
hub.c: USB hub found
port #1 suspened!
port #0 alived!
hub.c: 1 port detected
usb.c: registered new driver usb_mouse
usbmouse.c: v1.6:USB HID Boot Protocol mouse driver
usb.c: registered new driver keyboard
usbkbd.c: :USB HID Boot Protocol keyboard driver
mice: PS/2 mouse device common for all mice
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 4096 bind 4096)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
NetWinder Floating Point Emulator V0.95 (c) 1998-1999 Rebel.com
VFS: Mounted root (cramfs filesystem).
Mounted devfs on /dev
Freeing init memory: 72K
Reading data from NAND FLASH without ECC is not recommended
mount /etc as ramfs
re-create the /etc/mtab entries
UDA1341 audio driver initialized
Initializing USB Mass Storage driver...
usb.c: registered new driver usb-storage
USB Mass Storage support registered.
video_dev: unable to get major 81
insmod: init_module: videodev: Input/output error
usb.c: registered new driver ov511
ov511.c: v1.48a for Linux 2.4 : OV511 USB Camera Driver
mount: Mounting none on /proc/bus/usb failed: No such file or directory
cramfs: wrong magic
mount: Mounting /dev/mtdblock/3 on /tmp/disk3 failed: Invalid argument
init started: BusyBox v0.60.5 (2003.05.12-11:53+0000) multi-cll binary
Please press Enter to activate this console. /bin/cp: will not create hard link `/tmp/Applications/Network/modules' to directory `/tmp/Applications/AlarmServer'
/bin/cp: will not create hard link `/tmp/Documents' to directory `/tmp/Applications/qimpen'
Could not open mime.types file, "etc/mime.types", for reading
[9;0][?33l[?25l][?33l[?25lReading data from NAND FLASH without ECC is not recommended
Could not read calibration: /etc/pointercal
Create pluginlibman in libqpe
Use QPEApplication's PluginLibraryManager
Setting up QCop to QPE/System
channel QPE/Card added
channel QPE/Server added
channel QPE/IME added
QuickLauncher running
channel QPE/Application/quicklauncher added
channel QPE/QuickLauncher-54 added
Registered QPE/QuickLauncher-54
过一会就会有出现在了如下提示:
Cannot suspend - no APM support in kernel
这是怎么回事呀?
怎么解决呀!
