longhorn系统下的minidump文件
使用kd进行分析时,总出现符号错误,如下:
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: pshed!_WHEA_ERROR_RECORD_HEADER ***
Signature :
*** work. ***
Revision : 0x0000
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, MCA_ASSERT
Arg2: fffffa800885f030, Address of WHEA_ERROR_RECORD structure
Arg3: 00000000f6002000, High 32 bits of MCi_STATUS MSR for the MCA bank that had
the error
Arg4: 0000000000000853, Low 32 bits of MCi_STATUS MSR for the MCA bank that had
the error
Debugging Details:
WHEA_ERROR_RECORD: !errrec fffffa800885f030
Error Record @ FFFFFA800885F030
*** work. ***
