2865|3
79
单片机编程问题告急!!!希望个位大哥大姐帮忙. [复制链接]
我要实现的是4X4键盘显示电路  我键盘接P2口  显示电路用LED(8位) ,使用的是 (P3.1)串行通行 现在我要让键盘每一个键对应显示 1,2,3,....F,0,   我的单片机初始状态显示了 LED 全亮  可我的按键不能控制, 按下一点反应也没?  我在电脑上KEILC51 中编译也通过了,ISP下载也下到单片机里面去了,希望各为帮忙跟我找出原因,我的程序如下:
#include
#include
#include
  void delay ( );
unsigned int jiansao( );
unsigned char  A[16]={0x60,0xda,0xf2,0x66,0xb6,0xbe,0xe0,0xfe,0xf6,0xee,0x3e,0x9c,0x7a,0x9e,0x8e,0xfc};
void uart()
       TH0=0xf4;   //计数3000次//
           TL0=0x48;
       TR0=1;
main ( )
{ TMOD=0x01;//00000001  方式1 (16位计数器//
  SCON=0x00; //8位移位寄存器   开起串口//
  uart();
  ET0=1; EA=1;
for (; ;);
  void timer0(void) interrupt 1 using 1
{   unsigned int i;
     unsigned int key;
      key=jiansao( );
      delay();
   switch (key)
   { case 0x11: for (i=0;i<=7;i++)
                 { if (i<=7) SBUF=A[0];  while(!TI)  TI=0;};  break;
     case 0x21: for (i=0;i<=7;i++)
                    {   if (i<=7) SBUF=A[1];   while(!TI) TI=0;};  break;
     case 0x41: for (i=0;i<=7;i++)
                    { if (i<=7) SBUF=A[2];  while(!TI)  TI=0;};  break;
     case 0x81: for (i=0;i<=7;i++)
                    { if (i<=7) SBUF=A[3];  while(!TI)  TI=0;};  break;
     case 0x12: for (i=0;i<=7;i++)
                    { if (i<=7) SBUF=A[4];  while(!TI)  TI=0;};  break;
     case 0x22: for (i=0;i<=7;i++)
                    { if (i<=7) SBUF=A[5];  while(!TI)  TI=0;};  break;
     case 0x42: for (i=0;i<=7;i++)
                    {  if (i<=7) SBUF=A[6];  while (!TI)  TI=0;};  break;
     case 0x82:  for (i=0;i<=7;i++)
                    { if (i<=7) SBUF=A[7];  while(!TI)  TI=0;};  break;
     case 0x14: for (i=0;i<=7;i++)
                    {if (i<=7)  SBUF=A[8];  while(!TI)  TI=0;};  break;
     case 0x24: for (i=0;i<=7;i++)
                    {if (i<=7)  SBUF=A[9];  while(!TI)  TI=0;};  break;
    case 0x44:  for (i=0;i<=7;i++)
                    {if (i<=7)  SBUF=A[10];  while(!TI)  TI=0;};  break;
    case 0x84: for (i=0;i<=7;i++)
                    { if (i<=7) SBUF=A[11];  while(!TI)  TI=0;};  break;
     case 0x18: for (i=0;i<=7;i++)
                    {if (i<=7)  SBUF=A[12];  while(!TI)  TI=0;};  break;
     case 0x28: for (i=0;i<=7;i++)
                    { if (i<=7) SBUF=A[13];  while(!TI)  TI=0;};  break;
     case  0x48: for (i=0;i<=7;i++)
                    { if (i<=7) SBUF=A[14];  while(!TI)  TI=0;};  break;
     case 0x88: for (i=0; i<=7;i++)
                     {if (i<=7) SBUF=A[15];  while (!TI)  TI=0;}; break;
    default: SBUF=0xff; break;
void delay(void)    //延时去斗//
  {     unsigned int k;
      for  (k=600;  k>0;  k--);
unsigned int jiansao  (void )     扫描子程序
{    unsigned int  lie,  han;
     P2=0xf0;
     if ((P2&0xf0)!=0xf0)   判断有无键按下
       {   delay ();  去斗
          if((P2&0xf0)!=0xf0)  确认有键按下
             {    lie=0xfe;
                   while ((lie&0x10)!=0)
                 {     P2=lie;
                      {   han=(P2&0xf0)|0x0f;
                           return ((~lie)+(~han));
                     else lie=(lie<<1)|0x01;
       }      return (0);    无键按下 返回0
串口通讯的波特率定时器呢?while(!TI)  TI=0;这个地方可能出现死等待哦  详情 回复 发表于 2007-7-18 11:51
55
P2=0xf0; //这个是不是给错了?应该给0x0F,我猜的哈...
41
禁止发言
我猜错了,呵呵
你原来是对的
64
