3470|0
Windows CE开发EVC简单功能代码,高手看看,谢谢 [复制链接]
下面代码主要实现滑动条设置RGB颜色功能,(窗口就三个滑动条:RED,GREEN,BLUE)为什么我的窗口看不到显示的颜色。
BOOL CSliderUseDlg::OnInitDialog()
        CSliderCtrl *pSliderRed=(CSliderCtrl*)GetDlgItem(IDC_SLIDER_RED);
        ASSERT(pSliderRed!=NULL);
        pSliderRed->SetRange(0,255);
        pSliderRed->SetPos(128);
        CSliderCtrl *pSliderGreen=(CSliderCtrl*)GetDlgItem(IDC_SLIDER_GREEN);
        ASSERT(pSliderGreen!=NULL);
        pSliderGreen->SetRange(0,255);
        pSliderGreen->SetPos(128);
        CSliderCtrl *pSliderBlue=(CSliderCtrl*)GetDlgItem(IDC_SLIDER_BLUE);
        ASSERT(pSliderBlue!=NULL);
        pSliderBlue->SetRange(0,255);
        pSliderBlue->SetPos(128);
        CDialog::OnInitDialog();
        // Set the icon for this dialog.  The framework does this automatically
        //  when the application's main window is not a dialog
        SetIcon(m_hIcon, TRUE);                        // Set big icon
        SetIcon(m_hIcon, FALSE);                // Set small icon
        CenterWindow(GetDesktopWindow());        // center to the hpc screen
        // TODO: Add extra initialization here
        return TRUE;  // return TRUE  unless you set the focus to a control
void CSliderUseDlg::OnHScroll(UINT nSBCode, UINT nPos, CScrollBar *pScrollBar)
int iRed,iGreen,iBlue;
if((pScrollBar->GetDlgCtrlID()==IDC_SLIDER_RED)||(pScrollBar->GetDlgCtrlID()==IDC_SLIDER_GREEN)||(pScrollBar->GetDlgCtrlID()==IDC_SLIDER_BLUE))
        iRed=pSliderRed->GetPos();
        iGreen=pSliderGreen->GetPos();
        iBlue=pSliderBlue->GetPos();
        UpdateData(TRUE);
        CBrush colorBrush;
        COLORREF clRGB;
        clRGB =RGB(iRed,iGreen,iBlue);
        CClientDC * pClientDC;
        pClientDC= new CClientDC(this);
        colorBrush.CreateSolidBrush(clRGB);
        CRect rect(80,120,160,200);
        pClientDC->FillRect(rect,&colorBrush);
        delete pClientDC;
        CDialog::OnHScroll(nSBCode,nPos,pScrollBar);
