if (!is_up) // Last data received was the up-key identifier
switch (sc)
case 0xF0 : // The up-key identifier
is_up = 1;
break;
case 0x12 : // Left SHIFT
shift = 1;
break;
case 0x59 : // Right SHIFT
shift = 1;
break;
case 0x05 : // F1
if(mode == 0)
mode = 1; // Enter scan code mode
if(mode == 2)
mode = 3; // Leave scan code mode
break;
default:
if(mode == 0 || mode == 3) // If ASCII mode
if(!shift) // If shift not pressed,
{ // do a table look-up
for(i = 0; unshifted[0]!=sc && unshifted[0]; i++);
if (unshifted[0] == sc) {
put_kbbuff(unshifted[1]);
} else { // If shift pressed
for(i = 0; shifted[0]!=sc && shifted[0]; i++);
if (shifted[0] == sc) {
put_kbbuff(shifted[1]);
} else{ // Scan code mode
print_hexbyte(sc); // Print scan code
put_kbbuff(' ');
put_kbbuff(' ');
break;
} else {
is_up = 0; // Two 0xF0 in a row not allowed
switch (sc)
shift = 0;
break;
shift = 0;
break;
case 0x05 : // F1
if(mode == 1)
mode = 2;
if(mode == 3)
mode = 0;
break;
case 0x06 : // F2
clr();
break;
void put_kbbuff(unsigned char c)
if (buffcnt < BUFF_SIZE) // If buffer not full
*inpt = c; // Put character into buffer
inpt++; // Increment pointer
