4208|0
怎样利用Broadcom公版程式读取Chip [复制链接]
这是我在DOS下运行Broadcom公版程式WL.exe出现的命令,求助如何用这些命令去读取Chip的EEPROM
authe_sta_list
        Get authenticated sta mac address list
autho_sta_list
        Get authorized sta mac address list
measure_req
        Send an 802.11h measurement request.
        Usage: wl measure_req
        Measurement types are: TPC, Basic, CCA, RPI
        Target MAC addr format is xx:xx:xx:xx:xx:xx
quiet   Send an 802.11h quiet command.
        Usage: wl quiet , , s)>
csa     Send an 802.11h channel switch anouncement
        Usage wl csa
constraint
        Send an 802.11h Power Constraint IE
        Usage: wl constraint 1-255 db
rm_req  Request a radio measurement of type basic, cca, or rpi
        specify a series of measurement types each followed by options.
        example: wl rm_req cca -c 1 -d 50 cca -c 6 cca -c 11
        Options:
        -t n  numeric token id for measurement set or measurement
        -c n  channel
        -d n  duration in TUs (1024 us)
        -p    parallel flag, measurement starts at the same time as previous
        Each measurement specified uses the same channel and duration as the
        previous unless a new channel or duration is specified.
rm_rep  Get current radio measurement report
join_pref
        Set/Get join target preferences.
assoc_pref
        Set/Get association preference.
Usage: wl assoc_pref [auto|a|b|g]
wme     Set WME (Wireless Multimedia Extensions) mode (0=off, 1=on, -1=auto)
wme_ac  wl wme_ac ap|sta [be|bk|vi|vo [ecwmax|ecwmin|txop|aifsn|acm ] ...
wme_apsd
        Set APSD (Automatic Power Save Delivery) mode on AP (0=off, 1=on)
wme_apsd_sta
        Set APSD parameters on STA. Driver must be down.
Usage: wl wme_apsd_sta
   : number of frames per USP: 0 (all), 2, 4, or 6
   : value 0 to disable, 1 to enable U-APSD per AC
wme_dp  Set AC queue discard policy.
Usage: wl wme_dp
   : value 0 for newest-first, 1 for oldest-first
wme_counters
        print WMM stats
lifetime
        Set Lifetime parameter (milliseconds) for each ac.
wl lifetime be|bk|vi|vo []
reinit  Reinitialize device
sta_info
        wl sta_info
cap     driver capabilities
malloc_dump
        debug malloc info
chan_info
        channel info
add_ie  Add a vendor proprietary IE to 802.11 management packets
Usage: wl add_ie length OUI hexdata
: Bit 0 - Beacons
           Bit 1 - Probe Rsp
           Bit 2 - Assoc/Reassoc Rsp
           Bit 3 - Auth Rsp
Example: wl add_ie 3 10 00:90:4C 0101050c121a03
         to add this IE to beacons and probe responses
del_ie  Delete a vendor proprietary IE from 802.11 management packets
Usage: wl del_ie length OUI hexdata
: Bit 0 - Beacons
           Bit 1 - Probe Rsp
           Bit 3 - Auth Rsp
Example: wl del_ie 3 10 00:90:4C 0101050c121a03
list_ie Dump the list of vendor proprietary IEs
rand    Get a 2-byte Random Number from the MAC's PRNG
Usage: wl rand
otpw    Write an srom image to on-chip otp
Usage: wl otpw file
nvotpw  Write nvram to on-chip otp
Usage: wl nvotpw file
bcmerrorstr
        errorstring
freqtrack
        Set Frequency Tracking Mode (0=Auto, 1=On, 2=OFF)
eventing
        set/get 128-bit hex filter bitmask for MAC event reporting up to applica
tion layer
event_msgs
        set/get 128-bit hex filter bitmask for MAC event reporting via packet in
dications
counters
        Return driver counter values
assoc_info
        Returns the assoc req and resp information [STA only]
autochannel
        auto channel selection:
        1 to issue a channel scanning;
        2 to set channel based on the channel scanning result;
        without argument to only show the channel selected;
        ssid must set to null before this process, RF must be up
closed  hides the network from active scans, 0 or 1.
        0 is open, 1 is hide
pmkid_info
        Returns the pmkid table
abminrate
        get/set afterburner minimum rate threshold
bss     set/get BSS enabled status: up/down
closednet
        set/get BSS closed network attribute
diag    diag testindex(1-interrupt, 2-loopback, 3-memory, 4-led); precede by 'wl
down' and follow by 'wl up'
reset_d11cnts
        reset 802.11 MIB counters
staname get/set station name:
        Maximum name length is 15 bytes
apname  get AP name
otpdump Dump raw otp
cac_addts
        add TSPEC, error if STA is not associated or WME is not enabled
cac_delts
        delete TSPEC, error if STA is not associated or WME is not enabled
cac_tslist
        Get the list of TSINFO in driver
        eg. 'wl cac_tslist' get a list of TSINFO
cac_tspec
        Get specific TSPEC with matching TSINFO
        eg. 'wl cac_tspec 0xaa 0xbb 0xcc' where 0xaa 0xbb & 0xcc are TSINFO octe
ts
