2513|5
单片机与计算机通信 [复制链接]
哪位大侠能教我编一个用VB语言,PC与单片机进行串口通讯的程序,串口RS232,波特率4800
运行出错:use-defined type not defined 显示的是这行Public Sub SubReceive(Addr As Byte, dataType As Byte, RcvUART As Byte, CheckOut As Boolean, MSC As MSComm)   详情 回复 发表于 2007-7-18 16:35
网上很多现成的代码,可以下载!
VB语言
看它专有的那个控件!!
这就OK了
用VB的MScom控件
波特率可以用软件计算
具体原理一般的教材都有叙述
下面给出VB部分程序
根据通讯协议不同有所不同,只做参考
波特率9600
//初始化
Private Sub Form_Load()
With MSC
.CommPort = 1
.Settings = "9600,N,8,1"
.InputLen = 6
.OutBufferSize = 6
.SThreshold = 0
.RThreshold = 0
.InputMode = comInputModeBinary
.PortOpen = True
End With
End Sub
//接收子程序
Dim instring() As Byte, temp As Variant
Dim Checksum As Long, bytChecksum As Byte, i As Integer
MSC.InBufferCount = 0
Do Until MSC.InBufferCount >= 6
   DoEvents
Loop
temp = MSC.Input
instring = temp
Addr = instring(1)
dataType = instring(2)
RcvUART = instring(3)
Checksum = 0            '校验码等于收到的校验码,CheckOut为ture,否则为flase
For i = 0 To 3
   Checksum = (Checksum + instring(i))
Next i
bytChecksum = Checksum Mod 256#
If bytChecksum <> instring(4) Then
CheckOut = False
Else
CheckOut = True
End If
End Sub
//发送子程序
Public Sub SubSend(Addr As String, dataType As String, UARTdata As String, MSC As MSComm)
Dim Sentdata(0 To 5) As Byte
Dim i As Integer
Sentdata(0) = Val("&h42")
Sentdata(1) = Val("&h" & Addr)
Sentdata(2) = Val(dataType)
Sentdata(3) = Val("&h" & UARTdata)
Checksum = 0
For i = 0 To 4
   Checksum = (Checksum + Sentdata(i))
Next i
Sentdata(4) = Checksum Mod 256#
Sentdata(5) = Val("&h24")
MSC.Output = Sentdata
End Sub
不错
65
