2847|0
请问一个AT指令的问题 [复制链接]
利用SIM300模块和430单片机做的设备,用手机短信控制设备,执行一条删除一条,如果前面短信未删除,后面指令就无法执行,现在的问题是加了回复(执行一条指令返回一条确认消息)后就只能执行第一条,现在问题就是短信无法删除,我只改了总闸分的,其他没改,注
:未改动前短信是可以删除的
请问怎样才能使短信删除
下面是程序
void Action_judge(void)
                        ulong ultemp1=0,ultemp2;        //号码认证
                  char i,temp1;//,temp2;
                 delay1S();
                  for(i=0;i<13;i++)
                  //        test2=22;
                          receivnum=RX_action[i+2]-48;
                  for(i=0;i<11;i=i+2)
                          //test2=33;
                          temp1=receivnum;
                        receivnum=receivnum[i+1];
                        receivnum[i+1]=temp1;
                    //4294967296
                  //13277929732
                        receivnum1=10*receivnum[0]+receivnum[1];//13
                        ultemp2=receivnum[2];
                     ultemp1+=ultemp2*100000000;
                     ultemp2=receivnum[3];
                     ultemp1+=ultemp2*10000000;
                     ultemp2=receivnum[4];
                     ultemp1+=ultemp2*1000000;
                     ultemp2=receivnum[5];
                     ultemp1+=ultemp2*100000;
                     ultemp2=receivnum[6];
                     ultemp1+=ultemp2*10000;
                     ultemp2=receivnum[7];
                     ultemp1+=ultemp2*1000;
                     ultemp2=receivnum[8];
                     ultemp1+=ultemp2*100;
                     ultemp2=receivnum[9];
                     ultemp1+=ultemp2*10;
                     ultemp2=receivnum[10];
                     ultemp1+=ultemp2;
                    receivnum2=ultemp1;
                 for(i=0;(i<2*tablesize-1)&&pass==0;i=i+2)
                          if(receivnum1==Teletable&&receivnum2==Teletable[i+1])
                                        pass=1;
                                //        num6=i;
                          else
                                       pass=0;
                RX_bit=RX_temp;
                  flag_receiving=0;
                counter_action=0;
                if(pass)//如果通过认证
                          switch(RX_action[53])
                         case 65:
                        //设备自检
                             if(RX_action[45]==69)
                                        flag_ensend=1;
                                        flag_allsend=1;
                                  flag_measuring=1;
                                      flag_display=0;
                             break;
                      case 56:
                         //总闸合
                         //重合闸以后所有状态是否需要恢复到初始状态?
                               if(RX_action[45]==66)
                                       P5OUT&=~BIT4;
                                        flag_Tfault=0;
                                        Tstep2send=0;
                                         flag_Irmsfault=0;
                                         rmstep2send=0;
                                         flag_Iresfault=0;
                                         restep2send=0;
                                    flag_reclose=0;
                                          flag_Iresfault=0;
                                          flag_measuring=1;
                                         flag_display=0;
                                          flag_messfault=0;/*invalidate the message caused cut off flag*/
                                                //清除过流标志
                                         P4OUT&=~BIT0;
                                                //清除过热标志
                                        P4OUT&=~BIT1;
                                                //清除剩余电流过大标志
                                        P4OUT&=~BIT2;
                               break;
                     case 54:
                         //总闸分
                                         P5OUT|=BIT4;
                                          delay1S();
                                          delay1S();
                                          delay1S();
                                          diskeyint(); //禁止按键中断
                                         flag_ensend=0;//flag clearence
                                         flag_measuring=0;
                                         flag_messfault=1;/*validate the flag to cutt off the break*/
                                         send_commandall();
                                          send_ATorder(TX_ATEsc);
                                           send_ATorder(TX_ATD);//删除短信
                                         enkeyint ();               //发送完毕,打开按键中断
                                          delay1S();
                                          delay1S();
                                    flag_measuring=1;    //恢复测量状态
                                        flag_display=0;//显示IRES
        ATTReset();
                                         delay1S();
                                         ATT_Cali();
                              break;
                     case 49://支路1操作
                        //支路1合/分
                               if(RX_action[57]==56)
                                       P3OUT&=~BIT0;
                                        flag_messfault=0;
                               else if(RX_action[57]==54)
                                        P3OUT|=BIT0;
                                         flag_messfault=1;
                                flag_measuring=1;
                                  flag_display=0;
                               break;
                      case 50:
                        //支路2合/分
                                       P3OUT&=~BIT1;
                                           flag_messfault=0;
                                        P3OUT|=BIT1;
                                         flag_messfault=1;
                                       flag_measuring=1;
                                       flag_display=0;
                               break;
                      case 51:
                        //支路3合/分
                                        P3OUT&=~BIT2;
                                         flag_messfault=0;
                                       P3OUT|=BIT2;
                                        flag_messfault=1;
                                     flag_measuring=1;
                                       flag_display=0;
                                break;
                       default:
                                         flag_measuring=1;
                                        flag_display=0;
                                break;
//           enRXint();
          send_ATorder(TX_ATD);//3//删除短信
       //   P4OUT&=~BIT1;
          //P4OUT&=~BIT2;
           enkeyint();
           flag_measuring=1;//3//恢复测量状态
           flag_display=0;
           pass=0;///
                else
                      // P4OUT&=~BIT1;
                       //P4OUT&=~BIT2;
                       enkeyint();
                         flag_measuring=1;
                        flag_display=0;
ADI &文晔 探索季第一站,邀您在活动帖跟帖,ADI资深工程师将与您一道寻求解决之道! ...
春晚,最出圈当属穿着棉马甲跳秧歌的机器人”秧Bot”。
转手绢、飞手绢、变换队形,精准度和稳定性甚至超越人类,这背后少不了电机控制技术。
