4114|1
当NAND flash执行erase all blocks操作时,若某一block执行erase后返回info为OK,是否可以确信该block就valid了? [复制链接]
以下是某一NAND flash的erase all blocks源码.
/*F**************************************************************************
* NAME: nf_erase_all_block
* PARAMS:
* return:
*   OK : erase done
*   KO : erase not done
* PURPOSE:
*   This function erase all blocks on a NF card and write CIS information
* EXAMPLE:
* NOTE:
*   This function use the global variable Uint32 address
* REQUIREMENTS:
* ram/xram:
* cycle:
* stack:
* code:
bit nf_erase_all_block (void)
Byte i;
Uint16 j;
Uint16 block;
Uint16 block_reserved_space;
bit erase;
  Nf_CS_ON();
  /* Erase all block */
  block_reserved_space = (Uint16) (((nf_reserved_space_start >> 5) % 1000));
  gl_address = 0;
  for (nf_zone = 0; nf_zone < NF_ZONE_MAX_CPT; nf_zone++)
    for (j = 1024; j != 0; j--)
      Nf_wait_busy();
      Nf_read_open_C_area(gl_address, 0x05); /* Read block status byte */
      erase = TRUE;
      if (Nf_rd_byte() != 0xFF) /* if bad block */
        erase = FALSE;          /* don't erase block */
      else
        ((Byte*)&block)[0] = Nf_rd_byte(); /* Read logical block address */
        ((Byte*)&block)[1] = Nf_rd_byte();
        if ( (MEM_RESERVED_SIZE != 0) && (nf_zone == (NF_ZONE_MAX_CPT - 1)))
          if ((((Byte*)&block)[0] & 0xF8) == 0x10)
            block = (block & 0x0FFF) >> 1;
            if (block >= block_reserved_space)      /* If it is a reserved block */
              erase = FALSE;                        /* Don't erase block */
      if (NF_FULL_CHIP_ERASE == FALSE)
        if (((Byte*)&block)[0] != 0xE8)
          erase = FALSE;
      else
        if (((Byte*)&block)[0] == 0x00)
          erase = FALSE;
      if (erase) //以下开始完成erase
        nf_block_erase(gl_address);
        if (nf_check_status() == KO)
          nf_mark_bad_block(); /* Failure on erase operation */
        else //else部分有何作用???
        { /* Fill redundant area with 0x00 */
          Nf_write_open_C_area(gl_address, 0x00); // 即spare array
          for (i = 16; i != 0; i--)
            Nf_wr_byte(0x00);
          Nf_send_command(NF_PAGE_PROGRAM_CMD);        /* Valid the page programmation */
          if ( nf_check_status() == KO)
            nf_mark_bad_block();                        /* Failure on program operation */
          else
            Nf_read_open_C_area(gl_address, 0x00);        /* Read 16 bytes */
            i = 16;
            while ((i != 0) && (Nf_rd_byte() == 0x00)) i--;
            if (i)
            else
              nf_block_erase(gl_address);          /* Finally, erase the block */
              { /* Failure on erase operation */
      gl_address += 32;
  return (nf_read_spare_byte());
从以上erase算法可以看出,当需要对block进行erase操作时,虽erase OK了,还要验证spare是否编程OK,若spare也OK了,再把erase前面编程的0,该block才erase结束;否则视bad block处理.如此这般,是为何用?
因为擦除时写的是全1,所以之后写个全0啊  详情 回复 发表于 2008-12-20 10:11
77
