2922|1
82
skyeye+uClinux段错误 [复制链接]
在skyeye上面启动uClinux的时候报段错误
[root@localhost uClinux-dist]# skyeye -e linux-2.4.x/linux
arch: arm
cpu info: armv3, arm7tdmi, 41007700, fff8ff00, 0
mach info: name at91, mach_init addr 0x8071ad4
can't find device module: (null)
SKYEYE: use arm7100 mmu ops
Loaded ROM   images/romfs.img
exec file "linux-2.4.x/linux"'s format is elf32-little.
段错误
我的skyeye.conf文件是
cpu: arm7tdmi
mach: at91
mem_bank: map=M, type=RW, addr=0x00000000, size=0x00004000
mem_bank: map=M, type=RW, addr=0x01000000, size=0x00400000
mem_bank: map=M, type=R, addr=0x01400000, size=0x00400000, file=images/romfs.img
mem_bank: map=M, type=RW, addr=0x02000000, size=0x00400000
mem_bank: map=M, type=RW, addr=0x02400000, size=0x00008000
mem_bank: map=M, type=RW, addr=0x04000000, size=0x00400000
mem_bank: map=I, type=RW, addr=0xf0000000, size=0x10000000
lcd: state=on
uClinux的版本是uClinux-dist-20040408
skyeye的版本是skyeye-0.7.0
交叉编译工具arm-elf-tools-20030314.sh
编译内核的步骤
make menuconfig
make dep
make lib_only
make user_only
make romfs
make
make image
这个是什么原因,网上找了半天也没有找到相关的东西,是不是我的内核配置的问题?还是其他什么原因?
此帖出自Linux开发论坛
老大? 你是用什么引导的啊?  详情 回复 发表于 2007-6-28 09:56
64
老大? 你是用什么引导的啊?
此帖出自Linux开发论坛
