2830|2
88
求助测试代码编写 [复制链接]
[upload=rar]viewFile.asp?ID=2754[/upload]
LIBRARY ieee;
USE ieee.std_logic_1164.all;
use ieee.std_logic_textio.all;
use std.textio.all;
ENTITY fft4_vhd_tst IS
END fft4_vhd_tst;
ARCHITECTURE fft4_arch OF fft4_vhd_tst IS
-- constants
constant clk_period : time := 10 ns;
constant clk_stb : time := 2us;
-- signals
file inv :text is in "bar.in";
--file outv:text is out "bar.out";
SIGNAL t_sig_clk   : STD_LOGIC ;--:= '0';
SIGNAL t_sig_start : STD_LOGIC;
SIGNAL t_sig_Re_in : STD_LOGIC_VECTOR(15 downto 0);
SIGNAL t_sig_Im_in : STD_LOGIC_VECTOR(15 downto 0);
SIGNAL t_sig_Re_out : STD_LOGIC_VECTOR(15 downto 0);
SIGNAL t_sig_Im_out : STD_LOGIC_VECTOR(15 downto 0);
SIGNAL t_sig_finish : STD_LOGIC;
COMPONENT fft4 PORT (
  clk : in STD_LOGIC;
  start : in STD_LOGIC;
  Re_in : in STD_LOGIC_VECTOR(15 downto 0);
  Im_in : in STD_LOGIC_VECTOR(15 downto 0);
  Re_out : out STD_LOGIC_VECTOR(15 downto 0);
  Im_out : out STD_LOGIC_VECTOR(15 downto 0);
  finish : out STD_LOGIC );
END COMPONENT;
BEGIN
i1 : fft4 PORT MAP (
-- list connections between master ports and signals
clk => t_sig_clk,        start => t_sig_start,
Re_in => t_sig_Re_in,    Im_in => t_sig_Im_in,
Re_out => t_sig_Re_out,  Im_out => t_sig_Im_out,
finish => t_sig_finish);
init : PROCESS
-- variable declarations
  variable li,lo:line;
  variable clk,start: std_logic;
  variable Re_in,Im_in : STD_LOGIC_VECTOR(15 downto 0);
BEGIN
-- code that executes only once
  READLINE(inv,li);
  READ(li,clk);
  READ(li,start);
  READ(li,Re_in);
  READ(li,Im_in);
  t_sig_clk <= clk;
  t_sig_start <= start;
  t_sig_Re_in <= Re_in;
  t_sig_Im_in <= Im_in;
  wait for (clk_period - clk_stb);
  --write(lo,now,left,8);
  --hwrite(lo,count,right,3);
  --writeline(outv,lo);
  wait for clk_stb;
  if(endfile(inv)) then
   wait; -- 只执行一次
  end if;
   END PROCESS init;
always : PROCESS
-- optional sensitivity list
BEGIN
    -- code executes for every event on sensitivity list
--t_sig_clk <= not t_sig_clk ;
wait for clk_period/2 ;
END PROCESS always;
END fft4_arch;
上面的测试代码有什么错误呢??附件中文件是 bar.in
以后需再关注,现在先帮你顶一下  详情 回复 发表于 2008-5-1 08:29
等待牛人来答.
81
以后需再关注,现在先帮你顶一下
