3710|3
关于arm-linux编译驱动的一些问题 [复制链接]
大家好。
        我想问一个驱动开发基础点的问题。
        本人写了一个简单的驱动测试,在arm-linux上面跑,现在编译的时候有一些问题。
         我用的编译器arm-linux-gcc,arm是s3c2410的,我现在直接这样去编译是可以的:
        arm-linux-gcc -c hello.c
        这样编译出来的模块总觉得不妥,本来觉得应该include的是内核树里的东西啊,现在感觉include的是
        arm-linux-gcc里面的,但我这样编译确实是通不过:
        arm-linux-gcc -Wall -D__KERNEL__ -DMODULE -I/ARMs3c2410/kernel/include -O2   -c -o Hello.o Hello.c
        报错如下:
        In file included from /ARMs3c2410/kernel/include/linux/kernel.h:13,
                 from /usr/local/arm/3.4.1/lib/gcc/arm-linux/3.4.1/../../../../arm-linux/sys-include/asm/system.h:69,
                 from /usr/local/arm/3.4.1/lib/gcc/arm-linux/3.4.1/../../../../arm-linux/sys-include/asm/atomic.h:130,
                 from /usr/local/arm/3.4.1/lib/gcc/arm-linux/3.4.1/../../../../arm-linux/sys-include/asm/processor.h:25,
                 from /ARMs3c2410/kernel/include/linux/prefetch.h:13,
                 from /ARMs3c2410/kernel/include/linux/list.h:6,
                 from /ARMs3c2410/kernel/include/linux/module.h:12,
                 from Hello.c:9:
/ARMs3c2410/kernel/include/linux/types.h:14: error: parse error before "dev_t"
In file included from /usr/local/arm/3.4.1/lib/gcc/arm-linux/3.4.1/../../../../arm-linux/sys-include/asm/page.h:27,
                 from /usr/local/arm/3.4.1/lib/gcc/arm-linux/3.4.1/../../../../arm-linux/sys-include/asm/cpu-single.h:36,
                 from /usr/local/arm/3.4.1/lib/gcc/arm-linux/3.4.1/../../../../arm-linux/sys-include/asm/proc-fns.h:152,
                 from /usr/local/arm/3.4.1/lib/gcc/arm-linux/3.4.1/../../../../arm-linux/sys-include/asm/system.h:90,
                 from Hello.c:9:
/usr/local/arm/3.4.1/lib/gcc/arm-linux/3.4.1/../../../../arm-linux/sys-include/asm/glue.h:111:2: #error Unknown data abort handler type
In file included from /usr/local/arm/3.4.1/lib/gcc/arm-linux/3.4.1/../../../../arm-linux/sys-include/asm/cpu-single.h:36,
                 from Hello.c:9:
/usr/local/arm/3.4.1/lib/gcc/arm-linux/3.4.1/../../../../arm-linux/sys-include/asm/page.h:96:2: #error Unknown user operations model
Hello.c:41: warning: parameter names (without types) in function declaration
Hello.c:41: warning: data definition has no type or storage class
Hello.c:42: warning: parameter names (without types) in function declaration
Hello.c:42: warning: data definition has no type or storage class
请问如何解决这个问题呢,难道编译驱动不用本生的内核树?
谢谢
此帖出自Linux开发论坛
编译内核模块和编译应用程序是不一样的,不仅仅是头文件不同。 google以下LDD3, 然后看第1,2章。  详情 回复 发表于 2008-5-6 17:29
63
以后需再关注,现在先帮你顶一下
此帖出自Linux开发论坛
63
多加一选项, -nostdinc 则不用当前指定的标准include 了,
再-I 指定你要用的include目录.
此帖出自Linux开发论坛
此帖出自Linux开发论坛
