3632|4
能给出tonardo下memshow()的代码吗? [复制链接]
在网上找过但是没找到,many thanks!
有点难度哦  详情 回复 发表于 2008-5-1 11:35
75
安装源码就看到。但是,不要问我源码盘到哪里弄。
85
直接给你源码吧
STATUS memPartShow
    PART_ID partId,        /* partition ID                          */
    int                 type                /* 0 = statistics, 1 = statistics & list */
    int                numBlocks;
    unsigned        totalBytes = 0;
    unsigned        biggestWords = 0;
    if (partId == NULL)
        printf ("No partId specified.\n");
        return (ERROR);
    if (ID_IS_SHARED (partId))  /* partition is shared? */
        if (smMemPartShowRtn == NULL)
            errno = S_smObjLib_NOT_INITIALIZED;
            return (ERROR);
        return ((STATUS) (*smMemPartShowRtn)(SM_OBJ_ID_TO_ADRS (partId), type));
    /* partition is local */
    if (OBJ_VERIFY (partId, memPartClassId) != OK)
        return (ERROR);
    /* print out list header if we are going to print list */
    if (type == 1)
        printf ("\nFREE LIST:\n");
        printf ("   num    addr       size\n");
        printf ("  ---- ---------- ----------\n");
    semTake (&partId->sem, WAIT_FOREVER);
    if ((totalBytes = memPartAvailable (partId, &biggestWords, type)) == ERROR)
        semGive (&partId->sem);
        return (ERROR);
    else
        biggestWords /= 2;        /* memPartAvailable returns bytes, not words */
    if (type == 1)
        printf ("\n\n");
    numBlocks = dllCount (&partId->freeList);
    if (type == 1)
        printf ("SUMMARY:\n");
    printf (" status    bytes     blocks   avg block  max block\n");
    printf (" ------ ---------- --------- ---------- ----------\n");
    printf ("current\n");
    if (numBlocks != 0)
        printf ("   free %10u %9u %10u %10u\n", totalBytes, numBlocks,
                totalBytes / numBlocks, 2 * biggestWords);
    else
        printf ("   no free blocks\n");
    if (partId->curBlocksAllocated != 0)
        printf ("  alloc %10u %9u %10u          -\n",
                2 * partId->curWordsAllocated, partId->curBlocksAllocated,
                (2 * partId->curWordsAllocated) / partId->curBlocksAllocated);
    else
        printf ("   no allocated blocks\n");
    printf ("cumulative\n");
    if (partId->cumBlocksAllocated != 0)
                2 * partId->cumWordsAllocated, partId->cumBlocksAllocated,
                (2 * partId->cumWordsAllocated) / partId->cumBlocksAllocated);
    else
    return (OK);
Thanks a lot!
86
有点难度哦
