2750|2
66
类型转换 [复制链接]
请问ushort类型 怎样才能转变成char类型,是在wince下的
我用wcsncpy();好像也不能
_itow(), 将整型转换成unicode字符串   详情 回复 发表于 2007-6-8 12:01
64
wcstombs
size_t wcstombs( char *mbstr, const wchar_t *wcstr, size_t count );
Parameters
mbstr
The address of a sequence of multibyte characters
wcstr
The address of a sequence of wide characters
count
The maximum number of bytes that can be stored in the multibyte output string
Libraries
All versions of the C run-time libraries.
Return Value
If wcstombs successfully converts the multibyte string, it returns the number of bytes written into the multibyte output string, excluding the terminating NULL (if any). If the mbstr argument is NULL, wcstombs returns the required size of the destination string. In versions of Windows CE prior to 3.0, setting mbstr to NULL returns -1. If wcstombs encounters a wide character it cannot be convert to a multibyte character, it returns –1 cast to type size_t.
Remarks
The wcstombs function converts the wide-character string pointed to by wcstr to the corresponding multibyte characters and stores the results in the mbstr array. The count parameter indicates the maximum number of bytes that can be stored in the multibyte output string (that is, the size of mbstr). In general, it is not known how many bytes will be required when converting a wide-character string. Some wide characters will require only one byte in the output string; others require two. If there are two bytes in the multibyte output string for every wide character in the input string (including the wide character NULL), the result is guaranteed to fit.
If wcstombs encounters the wide-character null character (L'\0') either before or when count occurs, it converts it to an 8-bit 0 and stops. Thus, the multibyte character string at mbstr is null-terminated only if wcstombs encounters a wide-character null character during conversion. If the sequences pointed to by wcstr and mbstr overlap, the behavior of wcstombs is undefined.
Example
/* WCSTOMBS.C illustrates the behavior of the wcstombs function. */
#include
#include
void main( void )
   int      i;
   char    *pmbbuf   = (char *)malloc( MB_CUR_MAX );
   wchar_t *pwchello = L"Hello, world.";
   printf( "Convert wide-character string:\n" );
   i = wcstombs( pmbbuf, pwchello, MB_CUR_MAX );
   printf( "\tCharacters converted: %u\n", i );
   printf( "\tMultibyte character: %s\n\n", pmbbuf );
Output
  Characters converted: 1
  Multibyte character: H
77
【直播时间】5月28日(周三)上午10:00
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 11
