2938|3
大家来看下,这样做键盘钩子对吗。 [复制链接]
#include "stdafx.h"
#include
#include "ko999.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
static AFX_EXTENSION_MODULE Ko999DLL = { NULL, NULL };
HINSTANCE g_hInst;
const int KeyPressMask=0x80000000;  //键盘掩码常量
char g_PrvChar;
#pragma data_seg ("shared")
static HHOOK g_hHook=NULL;
#pragma data_seg ()
LRESULT CALLBACK KeyboardProc(int iCode,WPARAM wParam,LPARAM lParam);
BOOL APIENTRY DllMain( HANDLE hModule,
                                          DWORD  ul_reason_for_call,
                                          LPVOID lpReserved
        switch(ul_reason_for_call)
        case DLL_PROCESS_ATTACH:
                g_hInst = HINSTANCE(hModule);
                break;
        case DLL_PROCESS_DETACH:
                break;
        case DLL_THREAD_ATTACH:
                break;
        case DLL_THREAD_DETACH:
                break;
        return 1;
HINSTANCE  g_hHookApiDLL        = NULL;                        //handle to coredll.dll, where all the hook related APIs are present
#define WH_KEYBOARD_LL                   20
typedef LRESULT        (CALLBACK* HOOKPROC)(int code, WPARAM wParam, LPARAM lParam);
typedef HHOOK                 (WINAPI *_SetWindowsHookExW)(int, HOOKPROC, HINSTANCE, DWORD);
typedef LRESULT        (WINAPI *_CallNextHookEx)(HHOOK, int, WPARAM, LPARAM);
typedef LRESULT        (WINAPI *_UnhookWindowsHookEx)(HHOOK);
static _SetWindowsHookExW                 SetWindowsHookEx;
static _UnhookWindowsHookEx        UnhookWindowsHookEx;
static _CallNextHookEx                  CallNextHookEx;
DLLEXPORT int CALLBACK InstallHOOK()
        g_hHookApiDLL = LoadLibrary(_T("coredll.dll"));
        if(g_hHookApiDLL == NULL)
                //something is awfully wrong
                //the dll has to be present
                return false;
        SetWindowsHookEx = (_SetWindowsHookExW)GetProcAddress(g_hHookApiDLL, _T("SetWindowsHookExW"));
        g_hHook=SetWindowsHookEx(WH_KEYBOARD_LL,KeyboardProc,g_hInst,0);
        if (g_hHook)
                return TRUE;
        else
                return FALSE;
DLLEXPORT int CALLBACK UninstallHOOK()
        if (UnhookWindowsHookEx(g_hHook)==0)
                return FALSE;
        else
                return TRUE;
        if (wParam == VK_RETURN )
                AfxMessageBox(L"asdf");
        return CallNextHookEx(g_hHook,iCode,wParam,lParam);
#include "stdafx.h" #include "winceKBhook.h" #include "IconButton.h" //globals #define PARENT_WND CHomeScreenDlg #define POWER_ON 0 #define POWER_OFF 1 HINSTANCE  g_hHookApiDLL        = NULL;                        //handle to coredll.dll, where all the hook related APIs are present HHOOK g_hInstalledLLKBDhook = NULL;                        //g_hInstalledLLKBDhook represents handle to the installed KB hook static int begin=0,beginTime=0,EndTime=0;        static int PowerOnOff=0; HWND hWnd; /** *        Function Name:ActivateKBHook *        *        Function Desc:Initializes the proc. adress of various hook related APIs. *                                  Loads the keyboard hook. * *        Parameters: *                                 HINSTANCE hInstance : handle to the application to be hooked *                                 HOOKPROC LLKeyboardHookCallbackFunction : procedure where the control will come to after any KB event. *        Returns:        *                                 true if we get all the proc addresses of hook related APIs and load the hook succesfully *                                 false if any of the above fails * *        Author:                 Prathamesh Kulkarni **/ LRESULT CALLBACK hwKeyBdHook(int code, WPARAM wParam, LPARAM lParam) {                 CWinThread* pThread; //        LPMSG lpMsg;         PKBDLLHOOKSTRUCT lpKBD;         CIconButton* pIconBtn;         //pIconBtn = new CIconButton(GetSafeHwnd(), WM_MSG_ICONCLICK, 1, 1);                 if ((code < 0 /*&& code != MSGF_DDEMGR*/) ||                 (pThread = AfxGetThread()) == NULL)         {                 return ::CallNextHookEx(g_hInstalledLLKBDhook,                         code, wParam, lParam);         }         ASSERT(pThread != NULL);         HANDLE p_evtSignal;         p_evtSignal = CreateEvent(NULL, FALSE, FALSE, TEXT("UserInputEvent"));         //p_evtSignal = CreateEvent(NULL, FALSE, FALSE, szevtBacklightChange);         if(p_evtSignal != NULL)         {                 SetEvent(p_evtSignal);                 Sleep(30);                 CloseHandle(p_evtSignal);         }                 lpKBD = (PKBDLLHOOKSTRUCT)lParam;                 RETAILMSG(1,(TEXT("code %d,wParam 0x%x,vkCode %d,scanCode %d,flags 0x%08x,time %d\n"),code,wParam,lpKBD->vkCode,lpKBD->scanCode,lpKBD->flags,lpKBD->time));                         switch(lpKBD->vkCode)                         {                                 case LKeyUp:        if(wParam==0x101)                                                 pIconBtn->AnswerTheCall();                                         break;                                 case LKeyCenter:                                         if(wParam==0x101)                                                 pIconBtn->HangUpTheCall();                                 //        if(wParam==0x101)                                                 pIconBtn->CloseDialWindow();                                         break;                                         break;                                 case LKeyDown:                                         if(wParam==0x101)                                                 {                                                         pIconBtn->RunPilot();                                                 }                                         break;                                 case RKeyUp:                                         if(wParam==0x100 && PowerOnOff==POWER_ON)                                         {                                                 if(begin==0)                                                 {                                                         begin=1;                                                         beginTime=lpKBD->time;                                                 }                                                 else                                                 {                                                         EndTime=lpKBD->time;                                                         if(EndTime>beginTime)                                                         {        if((EndTime-beginTime)>500)        {        pIconBtn->OpenDialWindowOnly();        }        if((EndTime-beginTime)>1000)        {        begin=0;        //        pIconBtn->GoIntoSleep();        //pIconBtn->OpenDialWindow();        HANDLE hPwrButtonIntrEvent;        hPwrButtonIntrEvent = CreateEvent(NULL, FALSE, FALSE, TEXT("PowerOffEvt"));        if(hPwrButtonIntrEvent != NULL)        {        SetEvent(hPwrButtonIntrEvent);        Sleep(30);        CloseHandle(hPwrButtonIntrEvent);        //PowerOnOff=POWER_OFF;        }        }                                                         }                                                 }                                         }                                         /*else if(wParam==0x100 && PowerOnOff==POWER_OFF)                                                 {                                                         if(begin==0)                                                         {        begin=1;        beginTime=lpKBD->time;                                                         }                                                         else                                                         {        EndTime=lpKBD->time;        if(EndTime>beginTime)        {        if((EndTime-beginTime)>500)        {        begin=0;        //        pIconBtn->GoIntoSleep();        HANDLE hPwrButtonIntrEventOff;        hPwrButtonIntrEventOff = CreateEvent(NULL, FALSE, FALSE, TEXT("PowerOnEvt"));        if(hPwrButtonIntrEventOff != NULL)        {        SetEvent(hPwrButtonIntrEventOff);        CloseHandle(hPwrButtonIntrEventOff);        PowerOnOff=POWER_ON;        }        }        }                                                         }                                                 }*/                                         else                                         {                                                 begin=0;                                         }                                         break;                                 case RKeyCenter:        if(wParam==0x101)                                                 pIconBtn->ExchangeFrame();                                         break;                                 case RKeyDown:                                         if(wParam==0x101)                                                 pIconBtn->OpenDialWindow();                                         break;                                 default:                                         break;         }   //  delete pIconBtn;         return (LRESULT)0;//ProcessMessageFilter(code, (LPMSG)lParam); } void SetKBHook() {         ActivateKBHook(NULL, (HOOKPROC)hwKeyBdHook); } WINCEKBHOOK_API BOOL ActivateKBHook(HINSTANCE hInstance, HOOKPROC LLKeyboardHookCallbackFunction) {         //we need to manually load these standard Win32 API calls         //MSDN states that these aren't supported in WinCE         SetWindowsHookEx                = NULL;         CallNextHookEx                        = NULL;         UnhookWindowsHookEx                = NULL;         //now load the coredll.dll         g_hHookApiDLL = LoadLibrary(_T("coredll.dll"));         if(g_hHookApiDLL == NULL)         {                 //something is awfully wrong                 //the dll has to be present                 return false;         }         else         {                 //load the SetWindowsHookEx API call                 //the SetWindowsHookEx function installs an application-defined hook procedure into a hook chain.                 //You would install a hook procedure to monitor the system for certain types of events.                 //here we use use the hook to monitor kyeboard events                 SetWindowsHookEx = (_SetWindowsHookExW)GetProcAddress(g_hHookApiDLL, _T("SetWindowsHookExW"));                 if(SetWindowsHookEx == NULL)                 {                         //this means that MS has really stopped supporting this API in WinCE                         return false;                 }                 else                 {                         //install the KB hook                         //the hande needs to be saved for default processing of the events and to uninstall the hook, once we are done with it                         g_hInstalledLLKBDhook = SetWindowsHookEx(WH_KEYBOARD_LL, LLKeyboardHookCallbackFunction, hInstance, 0);                         if(g_hInstalledLLKBDhook == NULL)                         {                                 return false;                         }                 }                 //load CallNextHookEx() API call                 //the CallNextHookEx function passes the hook information to the next hook procedure in the current hook chain.                 //we use this call for default processing of events.                 CallNextHookEx = (_CallNextHookEx)GetProcAddress(g_hHookApiDLL, _T("CallNextHookEx"));                 if(CallNextHookEx == NULL)                 {                         return false;                 }                 //load UnhookWindowsHookEx() API                 //the UnhookWindowsHookEx function removes a hook procedure installed in a hook chain by the SetWindowsHookEx function.                 //we use this call to unistall the hook.                 UnhookWindowsHookEx = (_UnhookWindowsHookEx)GetProcAddress(g_hHookApiDLL, _T("UnhookWindowsHookEx"));                 if(UnhookWindowsHookEx == NULL)                 {                         return false;                 }         }         //all the APIs are loaded and the application is hooked         return true; } /** *        Function Name:DeactivateKBHook *        *        Function Desc:Uninstall the KB hook * *        Parameters: *                                 none *        Returns:        *                                 true if we exit gracefully * *        Author:                 Prathamesh Kulkarni **/ WINCEKBHOOK_API BOOL DeactivateKBHook() {         //unload the hook         if(g_hInstalledLLKBDhook != NULL)         {                 UnhookWindowsHookEx(g_hInstalledLLKBDhook);                 g_hInstalledLLKBDhook = NULL;         }         //unload the coredll.dll         if(g_hHookApiDLL != NULL)         {                 FreeLibrary(g_hHookApiDLL);                 g_hHookApiDLL = NULL;         }                 //we have terminated gracefully         return true; }   详情 回复 发表于 2007-8-20 15:40
65
http://www.codeproject.com/ce/wincekbhook.asp
The article shows how to use keyboard hooks in WinCE.
Hope the article can help you
Thanks :^)
62
我也写了一个钩子,是按照网上介绍的方法,http://www.codeproject.com/ce/wincekbhook.asp,写成了一个动态库,可为什么只能接收到一些控制键如:ctrl、alt等的消息,其他如数字键、字母键等的消息捕捉不到,且运行一会儿后还要死机。为什么?我也是ce5.0下实现的。
#include "stdafx.h"
//globals
#define POWER_ON 0
#define POWER_OFF 1
HWND hWnd;
*        Parameters:
*        Returns:
//        LPMSG lpMsg;
        HANDLE p_evtSignal;
                Sleep(30);
                                case LKeyUp:
                                        if(wParam==0x101)
                                        break;
                                case LKeyCenter:
                                        if(wParam==0x101)
                                        break;
                                        break;
                                case LKeyDown:
                                        if(wParam==0x101)
                                        break;
                                case RKeyUp:
                                                if(begin==0)
                                                        begin=1;
                                                else
        begin=0;
        Sleep(30);
                                                        if(begin==0)
        begin=1;
                                                        else
        begin=0;
                                        else
                                                begin=0;
                                        break;
                                case RKeyCenter:
                                        if(wParam==0x101)
                                        break;
                                case RKeyDown:
                                        if(wParam==0x101)
                                        break;
                                default:
                                        break;
  //  delete pIconBtn;
void SetKBHook()
                return false;
        else
                        return false;
                else
                                return false;
                        return false;
                        return false;
        return true;
*        Parameters:
*                                 none
*        Returns:
        //unload the hook
        return true;
