3866|6
菜鸟求教AD转换驱动问题 [复制链接]
在我写的AD转换驱动中(我用的是2410),发现AD的寄存器的值没法改,我怀疑修改寄存器的值应该有专门的函数(像GPIO那样),只是我不知道,希望知道的大侠指教一下,谢谢
谢谢大家关注~  详情 回复 发表于 2007-10-29 09:50
怎么没人回答我啊
79
你操作硬件上的端口或者映射内存
用这些函数或者宏
READ_PORT_BUFFER_UCHAR
READ_REGISTER_BUFFER_UCHAR
83
#ifndef __ADC_H__
#define __ADC_H__
#ifdef __cplusplus
extern "C" {
#endif
#define  IOCTL_SET_ADC_CHANNEL                0x01
#define  IOCTL_SET_ADC_FREQUENCY    0x02
#define  IOCTL_GET_ADC_CURFREQ          0x03
#define  IOCTL_SET_ADC_MAXFREQ                0x04
#define  IOCTL_SET_ADC_MINFREQ                0x05
// ADCCON 寄存器
#define  ADCCON_EN_START              (1 << 0)
#define  ADCCON_DIS_START            (0 << 0)
#define  ADCCON_DIS_READSTART    (0 << 1)
#define  ADCCON_EN_READSTART     (1 << 1)
#define  ADCCON_NORMAL_MODE      (0 << 2)
#define  ADCCON_STANDBY_MODE     (1 << 2)
#define  ADCCON_CHANNEL_MSK                  (0x07 << 3)
#define  ADCCON_CHANNEL_0                 0
#define  ADCCON_CHANNEL_1                 1
#define  ADCCON_CHANNEL_2                 2
#define  ADCCON_CHANNEL_3                 3
#define  ADCCON_CHANNEL_4                 4
#define  ADCCON_CHANNEL_5                 5
#define  ADCCON_CHANNEL_6                 6
#define  ADCCON_CHANNEL_7                 7
#define  ADCCON_PRSCVL_MSK       (0xFF << 6)
#define  ADCCON_PRSCEN_EN                   (1 << 14)
#define  ADCCON_PRSCEN_DIS                 (0 << 14)
#define  ADCCIN_CONVERTING                 (0 << 15)
#define  ADCCIN_CONVERT_END                 (1 << 15)
// ADCTSC 寄存器
#define  ADCTSC_NORMAL_MODE             (0x3 << 0)
#ifdef __cplusplus
#endif
#endif // __ADC_H__
88
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
// DLGADC dialog
DLGADC::DLGADC(CWnd* pParent /*=NULL*/)
        : CDialog(DLGADC::IDD, pParent)
        //{{AFX_DATA_INIT(DLGADC)
        m_DispAIN0 = 0;
        m_DispAIN1 = 0;
        //}}AFX_DATA_INIT
        hFile = INVALID_HANDLE_VALUE;
void DLGADC::DoDataExchange(CDataExchange* pDX)
        CDialog::DoDataExchange(pDX);
        //{{AFX_DATA_MAP(DLGADC)
        DDX_Text(pDX, IDC_DISP_AIN0, m_DispAIN0);
        DDX_Text(pDX, IDC_DISP_AIN1, m_DispAIN1);
        //}}AFX_DATA_MAP
BEGIN_MESSAGE_MAP(DLGADC, CDialog)
        //{{AFX_MSG_MAP(DLGADC)
        ON_WM_DESTROY()
        ON_WM_TIMER()
        ON_BN_CLICKED(IDC_BUTTON_START_ADC, OnButtonStartAdc)
        //}}AFX_MSG_MAP
END_MESSAGE_MAP()
// DLGADC message handlers
void DLGADC::OnDestroy()
        CDialog::OnDestroy();
        // TODO: Add your message handler code here
        if (hFile != INVALID_HANDLE_VALUE)
                // 关闭 ADC 驱动
                CloseHandle(hFile);
        KillTimer(1);                                                        /* 取消定时 */
61
void DLGADC::OnTimer(UINT nIDEvent)
        // TODO: Add your message handler code here and/or call default
        DWORD actlen;
        BOOL ret;
        BYTE channel = 0;
        float v0,v1;
        // 采样 W1(AIN0) 电压值
        ret = ::DeviceIoControl(hFile, IOCTL_SET_ADC_CHANNEL,
                                                        &channel, 1, NULL, 0, NULL, NULL);        /* 设置当前转换通道为0 */
        if (ret != TRUE)
                KillTimer(1);
                MessageBox(_T("设置ADC通道0失败 !"));
                goto END;
        ret = ::ReadFile(hFile, &m_DispAIN0, 1, &actlen, NULL);                /* 采样通道0 */
        if (ret != TRUE)
                KillTimer(1);
                MessageBox(_T("读取ADC通道0失败 !"));
                goto END;
        // 采样 W2(AIN1) 电压值
        channel = 1;
                                                        &channel, 1, NULL, 0, NULL, NULL);        /* 设置当前转换通道为1 */
        if (ret != TRUE)
                KillTimer(1);
                MessageBox(_T("设置ADC通道1失败 !"));
                goto END;
        ret = ::ReadFile(hFile, &m_DispAIN1, 1, &actlen, NULL);                /* 采样通道1 */
        if (ret != TRUE)
                KillTimer(1);
                MessageBox(_T("读取ADC通道1失败 !"));
                goto END;
        v0 = (float)(m_DispAIN0) / 1024;        /* 转换为小数值 */
        v1 = (float)(m_DispAIN1) / 1024;
        m_DispAIN0 = (DWORD)(v0 * 3300);        /* 计算出电压值 */
        m_DispAIN1 = (DWORD)(v1 * 3300);
        UpdateData(FALSE);                                        /* 更新显示 */
END:
        CDialog::OnTimer(nIDEvent);
void DLGADC::OnButtonStartAdc()
        // TODO: Add your control notification handler code here
        CButton *Key;
        Key = (CButton *)GetDlgItem(IDC_BUTTON_START_ADC);
        UINT state = Key->GetState();
        if ((state & 0x0003) == 1)                                        /* 按键按下 */
                if(IDYES==(AfxMessageBox(_T("启动ADC之后将无法使用触模屏,是否继续!"),MB_YESNO)))
                        // Yes
                        if (hFile == INVALID_HANDLE_VALUE)
                                hFile = CreateFile(TEXT("ADC1:"), GENERIC_READ | GENERIC_WRITE, 0,
        NULL, OPEN_EXISTING, 0, 0);
                                        MessageBox(_T("ADC 驱动打开失败!"));
                                        return;
                        Key->SetWindowText(_T("停止采样"));                        /* 按键标题改变, 提示下次操作 */
                        SetTimer(1, 20, NULL);                                                /* 启动定时器, 进行采样 */
                else
                        Key->SetCheck(0);                                                        /* 按键保持为未按下 */
                        UpdateData(FALSE);
        else        /* 按键弹起 */
                Key->SetWindowText(_T("开始采样"));                                /* 按键标题复原 */
                CloseHandle(hFile);
81
谢谢大家关注~
