2541|3
58
STL中的getline在CE下用不了 [复制链接]
读文件中的一行数据,这个API有没有可以替代的。
另外我从http://users.libero.it/g.govi/info_ce_en.html上面下了一个针对WINCE的STL,怎么使用啊?getline在哪个文件中?
仿造网上列子写的   详情 回复 发表于 2007-4-3 18:04
79
No stream library (iostream, iostream.h, etc. are missing).
No stream iterators: ostream_iterator and istream_iterator.
No stream-related functions (this limits the functionality in some class template, such as rope and string )
rope.dump is not available
是不是对输入输出流库没有哈??
算了,不用getline了,自己写了一个读*.INI的函数,请大家帮忙指点一下,有什么地方需要改进。
using namespace std;
#include
#include
#include
#include
#include
int GetPrivateProfileString(const LPTSTR path, const LPTSTR section, const LPTSTR key, LPTSTR result)
        TCHAR        ppos = NULL;
         wstring inbuf;
        wstring strsect;
        wstring srchkey;
        srchkey += section;
        srchkey += MIDDLESTRING;
        srchkey += key;
        std::vector        record;
        std::map > tempmap;
        std::wifstream outfile(path);
        if(!outfile.is_open()){
                ::MessageBox(NULL, _T("Need *.ini file"), _T("Test350"), MB_OK);
        return 0;
    while(outfile.good())
                TCHAR temp[5] = {0, };
                outfile.read(temp, 1);
                if(temp[0] != 0x0a){
                        inbuf += temp;
                } else {
                        record.push_back(inbuf);
                        inbuf.clear();
        outfile.close();
        if(record.empty()){
        return 0;
        for(UINT iloop = 0; iloop < record.size(); iloop ++){
                wstring strini = record[iloop];
        int first = strini.find('[');
        int last = strini.rfind(']');
        if( first != string::npos && last != string::npos && first != last+1)
            strsect = strini.substr(first+1,last-first-1);
            continue ;
                if(strsect.empty()){
            return 0;
                if((first=strini.find('='))== string::npos){
            return 0;
        wstring strtmp1= strini.substr(0,first);
        wstring strtmp2=strini.substr(first+1, wstring::npos);
        first= strtmp1.find_first_not_of(_T(" \t"));
        last = strtmp1.find_last_not_of(_T(" \t"));
                if(first == string::npos || last == string::npos){
            return 0;
        wstring strkey = strtmp1.substr(first, last-first+1);
        first = strtmp2.find_first_not_of(_T(" \t"));
        if(((last = strtmp2.find(_T("\t#"), first )) != wstring::npos) ||
            ((last = strtmp2.find(_T(" #"), first )) != wstring::npos) ||
            ((last = strtmp2.find(_T("\t//"), first )) != wstring::npos)||
            ((last = strtmp2.find(_T(" //"), first )) != wstring::npos))
            strtmp2 = strtmp2.substr(0, last-first);
        last = strtmp2.find_last_not_of(_T(" \t"));
            return 0;
        wstring value = strtmp2.substr(first, last-first+1);
        wstring mapkey = strsect + MIDDLESTRING;
        mapkey += strkey;
        tempmap[mapkey] = value;
        map >::iterator it;
        it = tempmap.find(srchkey);
        if(it == tempmap.end()){
                _tcscpy(result, _T("NONE"));
        return 0;
        } else {
                _tcscpy(result , it->second.c_str());
                return 1;
81
仿造网上列子写的
