2471|1
vs2003 可以连接SQL CE 3.0吗? [复制链接]
由于我使用的操作系统是windows  server  2003,
不能安装win  ce  5.0的模拟器,而vs2005没有自带的win  ce  模拟器,
现在已经安装了sql  ce  3.0,想使用vs2003连接sql  ce  3.0,但出现如下错误:
代码如下(网上的例子):
public  void  ShowErrors(SqlCeException  e)
                                   SqlCeErrorCollection  errorCollection  =  e.Errors;
                                   StringBuilder  bld  =  new  StringBuilder();
                                   Exception  inner  =  e.InnerException;
                                   if  (inner  !=  null)
                                               MessageBox.Show(("Inner  Exception:  "  +  inner.ToString()));
                                   foreach  (SqlCeError  err  in  errorCollection)
                                               bld.Append("\n"  +  "  Error  Code:  "  +  err.HResult.ToString());
                                               bld.Append("\n"  +  "  Message      :  "  +  err.Message);
                                               bld.Append("\n"  +  "  Minor  Err.:  "  +  err.NativeError);
                                               bld.Append("\n"  +  "  Source        :  "  +  err.Source);
                                               foreach  (int  numPar  in  err.NumericErrorParameters)
                                                           if  (0  !=  numPar)
        bld.Append("\n"  +  "  Num.  Par.  :  "  +  numPar);
                                               foreach  (string  errPar  in  err.ErrorParameters)
                                                           if  (string.Empty  !=  errPar)
        bld.Append("\n"  +  "  Err.  Par.  :  "  +  errPar);
                                               MessageBox.Show(bld.ToString());
                                               bld.Remove(0,  bld.Length);
                       private  void  button1_Click(object  sender,  System.EventArgs  e)
                                   //SQL  CE
                                   SqlCeConnection  conn  =  null;
                                   try
                                               if  (File.Exists("Test.sdf"))
                                                           File.Delete("Test.sdf");
                                               SqlCeEngine  engine  =  new  SqlCeEngine("Data  Source  =  Test.sdf");
                                               engine.CreateDatabase();
                                               SqlCeRemoteDataAccess  rda  =  new  SqlCeRemoteDataAccess();
                                               rda.InternetUrl  =  "http://***/sqlce/sqlcesa30.dll";
                                               rda.InternetLogin  =  "IUSER_***";
                                               rda.InternetPassword  =  "1";
                                               rda.LocalConnectionString  =  "Data  Source=Test.sdf";
                                               conn  =  new  SqlCeConnection("Data  Source  =  Test.sdf");
                                               conn.Open();
                                               rda.Pull("bcjh","SELECT  top  10  bcrq,bch  FROM  bcjh","Provider=sqloledb;server=***;database=****;uid=***;pwd=***;",RdaTrackOption.TrackingOnWithIndexes,"ErrorTable");
                                               String  SqlSelect  =  "SELECT  bcrq,bch  FROM  bcjh";
                                               SqlDataAdapter  objAdapter  =  new  SqlDataAdapter(SqlSelect,  "Data  Source  =  Test.sdf");
                                               DataSet  objDataSet  =  new  DataSet();
                                               objAdapter.Fill(objDataSet,  "dt");
                                               dataGrid1.DataSource  =  objDataSet.Tables["dt"];
                                               dataGrid1.Refresh();
                                   catch  (SqlCeException  ex)
//                                                MessageBox.Show("aaaa");
                                               ShowErrors(ex);
                                   finally
                                               if  (conn.State  ==  ConnectionState.Open)
                                                           conn.Close();
错误:
ERROR  CODE:-2147467259
Message:SQL  Server  CE  Encountered  problems  in  opening  the  SQL  Server
CE  database.[,,,Database  Name,,]
Minor  Err:28559
Source  :  Microsoft  SQL  Server  2000  Windows  CE  Edition
(前提:SQL  CE  3.0  安装正确,在vs2005的  ppc模拟器连接是正常的,使用的是SqlCeDataAdapter)
谢谢!
ERROR    CODE:-2147467259       Message: There is a file sharing violation. A different process might be using the file [,,,,,] Minor    Err:25035 Source    :    Microsoft    SQL    Server    2000    Windows    CE    Edition  详情 回复 发表于 2007-7-21 09:17
79
the file [,,,,,]
Minor    Err:25035
