AT89X52.H
Header file for the low voltage Flash Atmel AT89C52 and AT89LV52.
Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc.
All rights reserved.
#ifndef __AT89X52_H__
#define __AT89X52_H__
Byte Registers
sfr P0 = 0x80;
sfr SP = 0x81;
sfr DPL = 0x82;
sfr DPH = 0x83;
sfr PCON = 0x87;
sfr TCON = 0x88;
sfr TMOD = 0x89;
sfr TL0 = 0x8A;
sfr TL1 = 0x8B;
sfr TH0 = 0x8C;
sfr TH1 = 0x8D;
sfr P1 = 0x90;
sfr SCON = 0x98;
sfr SBUF = 0x99;
sfr P2 = 0xA0;
sfr IE = 0xA8;
sfr P3 = 0xB0;
sfr IP = 0xB8;
sfr T2CON = 0xC8;
sfr T2MOD = 0xC9;
sfr RCAP2L = 0xCA;
sfr RCAP2H = 0xCB;
sfr TL2 = 0xCC;
sfr TH2 = 0xCD;
sfr PSW = 0xD0;
sfr ACC = 0xE0;
sfr B = 0xF0;
P0 Bit Registers
sbit P0_0 = 0x80;
sbit P0_1 = 0x81;
sbit P0_2 = 0x82;
sbit P0_3 = 0x83;
sbit P0_4 = 0x84;
sbit P0_5 = 0x85;
sbit P0_6 = 0x86;
sbit P0_7 = 0x87;
PCON Bit Values
#define IDL_ 0x01
#define STOP_ 0x02
#define PD_ 0x02 /* Alternate definition */
#define GF0_ 0x04
#define GF1_ 0x08
#define SMOD_ 0x80
TCON Bit Registers
sbit IT0 = 0x88;
sbit IE0 = 0x89;
sbit IT1 = 0x8A;
sbit IE1 = 0x8B;
sbit TR0 = 0x8C;
sbit TF0 = 0x8D;
sbit TR1 = 0x8E;
sbit TF1 = 0x8F;
TMOD Bit Values
#define T0_M0_ 0x01
#define T0_M1_ 0x02
#define T0_CT_ 0x04
#define T0_GATE_ 0x08
#define T1_M0_ 0x10
#define T1_M1_ 0x20
#define T1_CT_ 0x40
#define T1_GATE_ 0x80
#define T1_MASK_ 0xF0
#define T0_MASK_ 0x0F
P1 Bit Registers
sbit P1_0 = 0x90;
sbit P1_1 = 0x91;
sbit P1_2 = 0x92;
sbit P1_3 = 0x93;
sbit P1_4 = 0x94;
sbit P1_5 = 0x95;
sbit P1_6 = 0x96;
sbit P1_7 = 0x97;
sbit T2 = 0x90; /* External input to Timer/Counter 2, clock out */
sbit T2EX = 0x91; /* Timer/Counter 2 capture/reload trigger & dir ctl */
SCON Bit Registers
sbit RI = 0x98;
sbit TI = 0x99;
sbit RB8 = 0x9A;
sbit TB8 = 0x9B;
sbit REN = 0x9C;
sbit SM2 = 0x9D;
sbit SM1 = 0x9E;
sbit SM0 = 0x9F;
P2 Bit Registers
sbit P2_0 = 0xA0;
sbit P2_1 = 0xA1;
sbit P2_2 = 0xA2;
sbit P2_3 = 0xA3;
sbit P2_4 = 0xA4;
sbit P2_5 = 0xA5;
sbit P2_6 = 0xA6;
sbit P2_7 = 0xA7;
IE Bit Registers
sbit EX0 = 0xA8; /* 1=Enable External interrupt 0 */
sbit ET0 = 0xA9; /* 1=Enable Timer 0 interrupt */
sbit EX1 = 0xAA; /* 1=Enable External interrupt 1 */
sbit ET1 = 0xAB; /* 1=Enable Timer 1 interrupt */
sbit ES = 0xAC; /* 1=Enable Serial port interrupt */
sbit ET2 = 0xAD; /* 1=Enable Timer 2 interrupt */
sbit EA = 0xAF; /* 0=Disable all interrupts */
P3 Bit Registers (Mnemonics & Ports)
sbit P3_0 = 0xB0;
sbit P3_1 = 0xB1;
sbit P3_2 = 0xB2;
sbit P3_3 = 0xB3;
sbit P3_4 = 0xB4;
sbit P3_5 = 0xB5;
sbit P3_6 = 0xB6;
sbit P3_7 = 0xB7;
sbit RXD = 0xB0; /* Serial data input */
sbit TXD = 0xB1; /* Serial data output */
sbit INT0 = 0xB2; /* External interrupt 0 */
sbit INT1 = 0xB3; /* External interrupt 1 */
sbit T0 = 0xB4; /* Timer 0 external input */
sbit T1 = 0xB5; /* Timer 1 external input */
sbit WR = 0xB6; /* External data memory write strobe */
sbit RD = 0xB7; /* External data memory read strobe */
IP Bit Registers
sbit PX0 = 0xB8;
sbit PT0 = 0xB9;
sbit PX1 = 0xBA;
sbit PT1 = 0xBB;
sbit PS = 0xBC;
sbit PT2 = 0xBD;
T2CON Bit Registers
sbit CP_RL2= 0xC8; /* 0=Reload, 1=Capture select */
sbit C_T2 = 0xC9; /* 0=Timer, 1=Counter */
sbit TR2 = 0xCA; /* 0=Stop timer, 1=Start timer */
sbit EXEN2= 0xCB; /* Timer 2 external enable */
sbit TCLK = 0xCC; /* 0=Serial clock uses Timer 1 overflow, 1=Timer 2 */
sbit RCLK = 0xCD; /* 0=Serial clock uses Timer 1 overflow, 1=Timer 2 */
sbit EXF2 = 0xCE; /* Timer 2 external flag */
sbit TF2 = 0xCF; /* Timer 2 overflow flag */
T2MOD Bit Values
#define DCEN_ 0x01 /* 1=Timer 2 can be configured as up/down counter */
#define T2OE_ 0x02 /* Timer 2 output enable */
PSW Bit Registers
sbit P = 0xD0;
sbit FL = 0xD1;
sbit OV = 0xD2;
sbit RS0 = 0xD3;
sbit RS1 = 0xD4;
sbit F0 = 0xD5;
sbit AC = 0xD6;
sbit CY = 0xD7;
Interrupt Vectors:
Interrupt Address = (Number * 8) + 3
#define IE0_VECTOR 0 /* 0x03 External Interrupt 0 */
#define TF0_VECTOR 1 /* 0x0B Timer 0 */
#define IE1_VECTOR 2 /* 0x13 External Interrupt 1 */
#define TF1_VECTOR 3 /* 0x1B Timer 1 */
#define SIO_VECTOR 4 /* 0x23 Serial port */
#define TF2_VECTOR 5 /* 0x2B Timer 2 */
#define EX2_VECTOR 5 /* 0x2B External Interrupt 2 */
#endif
不知道哪里错了,说有102个error
