2848|0
求助:uclinux启动出错 [复制链接]
uclinux启动有错误,大虾们帮看看,谢谢!
starting uClinux, waiting...
Copy kernel from sdram
Uncompressing Linux.............................................................Linux version 2.4.24-uc0 (root@localhost) (gcc version 2.95.3 20010315 (release7Processor: Samsung S3C44B0X revision 0
Architecture: S3C44B0X
On node 0 totalpages: 2048
zone(0): 0 pages.
zone(1): 2048 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/rom0
Console: colour dummy device 80x30
Calibrating delay loop... 30.82 BogoMIPS
Memory: 8MB = 8MB total
Memory: 5880KB available (1944K code, 198K data, 60K init)
Dentry cache hash table entries: 1024 (order: 1, 8192 bytes)
Inode cache hash table entries: 512 (order: 0, 4096 bytes)
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 2048 (order: 1, 8192 bytes)
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
ttyS0 at I/O 0x1d00000 (irq = 3) is a S3C44B0
ttyS1 at I/O 0x1d04000 (irq = 2) is a S3C44B0
Blkmem copyright 1998,1999 D. Jeff Dionne
Blkmem copyright 1998 Kenneth Albanowski
Blkmem 1 disk images:
0: C0E6698-C1FD297 [VIRTUAL C0E6698-C1FD297] (RO)
RAMDISK driver initialized: 16 RAM disks of 2048K size 1024 blocksize
Cirrus Logic CS8900A driver for Linux (V0.02)
eth0: CS8900A rev E detected
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 512 bind 512)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
Blkmem: open: 0
Blkmem: open: 0
VFS: Mounted root (romfs filesystem) readonly.
Freeing init memory: 60K
Allocation of length 90336 from process 1 failed
Buffer memory:       40kB
Cache memory:        8kB
Free pages:        5612kB (     0kB HighMem)
Zone:DMA freepages:     0kB
Zone:Normal freepages:  5612kB
Zone:HighMem freepages:     0kB
( Active: 9, inactive: 3, free: 1403 )
= 0kB)
1*4kB 1*8kB 0*16kB 1*32kB 87*64kB = 5612kB)
= 0kB)
Unable to allocate RAM for process data, errno 0
munmap of non-mmaped memory by process 1 (init): 0c121818
Allocation of length 90334 from process 1 failed
Buffer memory:       48kB
Cache memory:        8kB
Free pages:        5604kB (     0kB HighMem)
Zone:Normal freepages:  5604kB
( Active: 12, inactive: 2, free: 1401 )
= 0kB)
1*4kB 0*8kB 0*16kB 1*32kB 87*64kB = 5604kB)
= 0kB)
Sash command shell (version 1.1.1)
此帖出自Linux开发论坛
