4066|5
wince 下串口问题!请大侠赐教 [复制链接]
ce4.2下串口1,2都好了,串口3只能发出去不能收,串口4打开失败。谁能帮我分析下可能的问题吗?
我已经根据网上提示在debug.c文件里添加了一句关闭调试串口的语句。
platform.reg文件里中:
前面范围一段如下:
[HKEY_LOCAL_MACHINE\Drivers\Resources\IO]
   "Identifier"=dword:2
   "Minimum"=dword:0
   "Space"=dword:10000
IF BSP_NOSERIAL
   "Ranges"="0-0x5F,0x65-0x277,0x284-0x38F,0x392-0x3DF,0x3E2-0xFFFF"
ENDIF ; BSP_NOSERIAL
IF BSP_NOSERIAL !
   "Ranges"="0-0x5F,0x65-0x277,0x284-0x2F7,0x300-0x38F,0x392-0x3DF,0x3E2-0xFFFF"
ENDIF ; BSP_NOSERIAL !
IF BSP_SERIAL2
   "Ranges"="0-0x5F,0x65-0x277,0x284-0x2F7,0x300-0x38F,0x392-0x3DF,0x3E2-0x3E7,0x3F0-0xFFFF"
ENDIF ; BSP_SERIAL2
IF BSP_SERIAL3
   "Ranges"="0-0x5F,0x65-0x277,0x284-0x2E7,0x2F0-0x2F7,0x300-0x38F,0x392-0x3DF,0x3E2-0x3E7,0x3F0-0xFFFF"
ENDIF ; BSP_SERIAL3
后面注册信息里如下:
IF BSP_NOSERIAL !
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\Serial]
  "SysIntr"=dword:14
  "IoBase"=dword:03F8
  "IoLen"=dword:8
  "DeviceArrayIndex"=dword:0
  "Prefix"="COM"
  "IClass"="{CC5195AC-BA49-48a0-BE17-DF6D1B0173DD}"
  "Dll"="Com16550.Dll"
  "Order"=dword:0
  "Priority"=dword:0
; Turn on follows for Installable ISR (isr16550 supporting SOFTWARE FIFO
;   "Irq"=dword:3
;   "IsrDll"="isr16550.dll"
;   "IsrHandler"="ISRHandler"
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\Serial\Unimodem]
  "Tsp"="Unimodem.dll"
  "DeviceType"=dword:0
  "FriendlyName"=LOC_FRIENDLYNAME_SERIAL
  "DevConfig"=hex: 10,00, 00,00, 05,00,00,00, 10,01,00,00, 00,4B,00,00, 00,00, 08, 00, 00, 00,00,00,00
ENDIF BSP_NOSERIAL !
IF BSP_SERIAL2
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\Serial2]
  "SysIntr"=dword:13
  "IoBase"=dword:02F8
  "IoLen"=dword:8
  "DeviceArrayIndex"=dword:1
  "Prefix"="COM"
  "Order"=dword:0
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\Serial2\Unimodem]
  "FriendlyName"=LOC_FRIENDLYNAME_SERIAL2
ENDIF BSP_SERIAL2
IF BSP_SERIAL3
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\Serial3]
  "SysIntr"=dword:15
  "IoBase"=dword:03E8
  "IoLen"=dword:8
  "DeviceArrayIndex"=dword:2
  "Prefix"="COM"
  "Order"=dword:0
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\Serial3\Unimodem]
;; "FriendlyName"=LOC_FRIENDLYNAME_SERIAL3
  "FriendlyName"="COM3"
ENDIF BSP_SERIAL3
IF BSP_SERIAL4
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\Serial4]
"SysIntr"=dword:1b
  "IoBase"=dword:02E8
  "IoLen"=dword:8
  "DeviceArrayIndex"=dword:3
  "Prefix"="COM"
  "Order"=dword:0
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\Serial4\Unimodem]
;;   "FriendlyName"=LOC_FRIENDLYNAME_SERIAL4
  "FriendlyName"="COM4"
ENDIF BSP_SERIAL4
用以上设置,串口1,2正常,串口3只能发送不能接收,串口4打开失败。
主板BIOS里我手动设置串口3中断号为5,串口4中断号为11.(先前主板默认com1中断号4,com2中断号3,com3中断号3,com4中断号4)
板子是威盛via ml8000a
请大侠赐教~~
都搞定了。中断,端口都对应好。DEBUG.C文件和platform.reg修改好就OK了 手机程序开发QQ群18098403.  详情 回复 发表于 2008-7-3 11:26
eeworld上发现有一个帖子写添加串口4的,但是那个帖子里前面三个串口都正常了,我串口1,2正常了,但是com3只能发出来,不能收进去,com4更加连打开都不行了。 如果com3的问题解决不掉,能把com4调通也就好了。我现在要用到三个串口。知道的朋友还请帮忙提示下啊
有空发你看, 2410么?
修改3个串口都可以用 ,要该的地方还是蛮多地
请知道的朋友指教啊,急用哇。。
67
请知道的朋友指教啊,急用哇。。
手机程序开发QQ群18098403.
