2491|0
83
这几句话如何改成evc语句? [复制链接]
源程序是QBASIC,控制串口,需要改成api语句,不能调用控件!
' Open COM: 4800 Bd, no parity, 8 data bits, 1 stop, no handshake
OPEN "com1:4800,n,8,1,rs,cs,ds,cd" FOR INPUT AS #1
ON ERROR GOTO RecvErr
MainLoop:
DO
  WHILE ASC(INPUT$(1, #1)) <> STX: WEND 'wait for STX
  sonde = ASC(INPUT$(1, #1))            'type of detector
  bc = sonde
  mantlo = ASC(INPUT$(1, #1))           'low order mantissa
  bc = bc XOR mantlo
  manthi = ASC(INPUT$(1, #1))           'high order mantissa
  bc = bc XOR manthi
  expon = ASC(INPUT$(1, #1))            'exponent
  bc = bc XOR expon
  IF expon > 127 THEN expon = expon - 256
  bc = bc XOR ASC(INPUT$(1, #1))        'block check
  IF bc <> 0 THEN ERROR DEVERR          'block check error
  mant = manthi * 256 + mantlo          '16 bit mantissa
  xdl = mant * 2 ^ (expon - 15)         'dose rate as floating point number
  GOSUB GetProbe                        'set ger$, det$ and unit$
  PRINT TIME$; " Device: 1145"; ger$; "  Detector: "; det$;
  PRINT USING "  Reading=########.### "; xdl;
  PRINT unit$
LOOP WHILE LEN(INKEY$) = 0              'exit on any key
PRINT "End."
END
