3260|2
87
蓝牙应用程序静态库? [复制链接]
  1. btpair.obj : error LNK2019: unresolved external symbol BthNsLookupServiceEnd referenced in function "unsigned long __cdecl DoInquiry(void *)" (?DoInquiry@@YAKPAX@Z)
  2. btpair.obj : error LNK2019: unresolved external symbol BthNsLookupServiceNext referenced in function "unsigned long __cdecl DoInquiry(void *)" (?DoInquiry@@YAKPAX@Z)
  3. btpair.obj : error LNK2019: unresolved external symbol BthNsLookupServiceBegin referenced in function "unsigned long __cdecl DoInquiry(void *)" (?DoInquiry@@YAKPAX@Z)
  4. btpair.obj : error LNK2019: unresolved external symbol BthCloseConnection referenced in function "void __cdecl Pair(void)" (?Pair@@YAXXZ)
  5. btpair.obj : error LNK2019: unresolved external symbol BthAuthenticate referenced in function "void __cdecl Pair(void)" (?Pair@@YAXXZ)
  6. btpair.obj : error LNK2019: unresolved external symbol BthCreateACLConnection referenced in function "void __cdecl Pair(void)" (?Pair@@YAXXZ)
  7. btpair.obj : error LNK2019: unresolved external symbol BthSetPIN referenced in function "void __cdecl Pair(void)" (?Pair@@YAXXZ)
  8. btpair.obj : error LNK2019: unresolved external symbol BthRevokeLinkKey referenced in function "void __cdecl Unpair(void)" (?Unpair@@YAXXZ)
  9. btpair.obj : error LNK2019: unresolved external symbol BthRevokePIN referenced in function "void __cdecl Unpair(void)" (?Unpair@@YAXXZ)
复制代码
BthNsLookupServiceEnd这样的函数在哪个具体的库里面,没有弄过蓝牙,移植一蓝牙程序,发现这样的错误
我解决了,就是我不知道那些函数是哪个库里面的。谢谢楼上的,我就等着有人回答,我好结贴呢!不然就死贴了! 补丁我打了的。 1.添加静态链接库Btdrt.lib btdrtstubs.lib     2.Btdrt.lib btdrtstubs.lib所在文件夹C:\WINCE500\PUBLIC\COMMON\OAK\LIB\ARMV4I\RETAIL   详情 回复 发表于 2009-5-20 19:01
ce版本?ce打补丁了吗?早期的ce对蓝牙的支持是很差的,少库很正常。
79
补丁我打了的。
