4055|8
83
W83977芯片驱动程序疑问 [复制链接]
这个是网上一个大侠写的W83977驱动程序。我不明白其中一些为什么那样也,看手册头都看晕了都没办法。
//KBD port--------------------------------------------
w977_select_device(W977_DEVICE_KBC, efbase[1]); //select logic device
w977_write_reg(0x60, 0x0, efbase[1]);    //address              这里把0X60和0X0写到0X3F0和0X3F1是什么意思,手册上不是这样的啊
                {CR60, CR 61 (Default 0x00, 0x60 if PENKBC= 1 during POR, default 0x00 otherwise)
                  These two registers select the first KBC I/O base address [0x100:0xFFF] on 1 byte boundary.
                  CR62, CR 63 (Default 0x00, 0x64 if PENKBC= 1 during POR, default 0x00 otherwise)
                  These two registers select the second KBC I/O base address [0x100:0xFFF] on 1 byte boundary.这一段是手册上写的}
w977_write_reg(0x61, 0x60, efbase[1]);    //address--0x060
w977_write_reg(0x62, 0x0, efbase[1]);    //address
w977_write_reg(0x63, 0x64, efbase[1]);    //address--0x064
蓝色的代码不清楚为什么要这样写,这几个函数定义在下面贴出来
//set irq number
w977_write_reg(0x70, 0x05, efbase[1]);    //irq for keyboard  irq5--active H
w977_write_reg(0x72, 0x04, efbase[1]);    //irq for mouse      irq4--active H
//12MHZ, disable port 92
w977_write_reg(0xf0, 0x80, efbase[1]);
/* Activate device */
w977_write_reg(0x30, 0x01, efbase[1]);
下面是上面要用到的子函数
static unsigned int efbase[] = { W977_EFIO_BASE+nGCS7, W977_EFIO2_BASE+nGCS7 };
static unsigned int efio = W977_EFIO_BASE;
#define readb(x)    (*(volatile unsigned char *)x)
#define writeb(val, x)  (*(volatile unsigned char *)x)=val
#define readw(x) (*(volatile unsigned short *)x)
#define writew(val, x) (*(volatile unsigned short *)x)=val
static void w977_write_reg(unsigned char reg, unsigned char value, unsigned int efio)
unsigned int addr;
writeb(reg, efio);
addr=efio+1;
writeb(value, addr);
在hrimfaxi的帮助下问题基本解决: w977_write_reg(0x60, 0x0, efbase[1]);    //address             w977_write_reg(0x61, 0x60, efbase[1]);    //address--0x060 w977_write_reg(0x62, 0x0, efbase[1]);    //address w977_write_reg(0x63, 0x64, efbase[1]);   //address--0x064 上面其实是附地址,和X86汇编差不多付高低值差不多。   详情 回复 发表于 2009-4-14 00:15
看这样子第一个值是芯片内部寄存器的Index值,第二个才是要写入该寄存器的值
至于为什么要这样写,那还是要查看芯片的Datasheet
如果你看了手册,你觉得应该怎么写呢?
78
i2c通信?
58
引用 1 楼 hzdysymbol 的回复:
如果你看了手册,你觉得应该怎么写呢?
这个我知道,我想问的是为什么后面写那些值就是标记为蓝色的那些,手册上没有说明那些值是什么意思。
引用 2 楼 xqhrs232 的回复:
i2c通信?
这个不是IIC通信。我用这个芯片来做PS/2键盘,鼠标,还有串口的
67
引用 3 楼 wdw1600 的回复:
如果你看了手册,你觉得应该怎么写呢?
那你注释的这行是什么意思?
[code]
闂傚倸鍊搁崐鎼佸磹妞嬪海鐭嗗〒姘e亾妤犵偞鐗犻、鏇㈠Χ閸℃ぞ绮℃俊鐐€栭崝褏绮婚幋鐘差棜闁秆勵殕閻撴洟鏌熼柇锕€鐏遍柛銈咁儔閺屻倝寮堕幐搴′淮闂佸搫鏈粙鎴﹀煡婢跺ň鏋庨柟閭﹀枤閳诲繘姊虹拠鎻掝劉闁煎綊绠栬棟濞村吋娼欐闂佸憡娲﹂崹鎵不閹惰姤鐓曢柍鈺佸暔娴狅箑顭跨憴鍕缂佽鲸鎹囧畷鎺戔枎閹存繂顬夋俊鐐€戦崝灞轿涘┑瀣瀬闁告劦鍠栭~鍛存煟濡櫣浠涙繛鍫熷劤閳规垶骞婇柛濠冩礋楠炲﹥鎯旈姀鐘插闂傚倸鍊风粈渚€鎮块崶褜娴栭柕濞у懐鐒兼繛杈剧秬椤宕h箛娑欑厪闁割偅绻嶅Σ褰掓煟閹捐泛鏋涢柡宀嬬到椤粓鍩€椤掍胶顩查悹杞拌閻庡爼鏌i幋锝呅撻柣鎾存礋閺岋繝宕掑┑鍥┿€婄紓浣哄Х缁垶濡甸崟顖氼潊闁挎稑瀚崳鏉课旈悩闈涗粶妞ゆ垵顦靛顐﹀磼閻愭潙娈熼梺闈涱檧婵″洩銇愰妸鈺傗拺閻犲洦鐓¢妤呮煕濡崵鐭掔€规洘鍨块獮妯肩磼濡厧骞堥梻浣哥秺閸嬪﹪宕㈡總绋跨闁靛牆妫涚粻楣冩煕椤愵偄澧悗姘炬嫹闂傚倸鍊搁崐鎼佸磹瀹勬噴褰掑炊椤掍礁鍓銈嗗姧缁犳垿鐛姀銈嗙厓閺夌偞澹嗛崝宥嗐亜閺傚灝顏紒杈ㄦ崌瀹曟帒顫濋钘変壕闁告縿鍎抽惌娆撴煕閺囥劌鐏犵紒鐙€鍨堕弻銊╂偆閸屾稑顏�闂傚倸鍊搁崐鎼佸磹閻戣姤鍤勯柛顐f礀缁犵娀鏌熼崜褏甯涢柛瀣ㄥ€濋弻鏇熺箾閻愵剚鐝曢梺绋款儏椤戝寮婚敐澶婄疀妞ゆ帊鐒﹂崕鎾绘⒑缂佹ê绗掗柣蹇斿哺婵$敻宕熼姘鳖唺闂佽鎯岄崹閬嶅极妤e啯鐓熼幖娣灮閸熸煡鏌熼崙銈嗗婵犵數濮烽弫鍛婃叏閻戣棄鏋侀柟闂寸绾剧粯绻涢幋鏃€鍤嶉柛銉墻閺佸洭鏌曡箛鏇炐ユい锔诲櫍閹宕楁径濠佸闂備礁鎲″ú锕傚磻婢舵劕鏄ラ柣鎰劋閳锋垿鎮归幁鎺戝婵炲懏鍔欓弻鐔煎礄閵堝棗顏�
67
62
快来报名!
