2616|1
63
6.0内核启动问题 [复制链接]
搞好了eboot,内核起到一半又不行了,还得麻烦朋友们帮忙看看:
Download successful!  Jumping to image at 0x80101000 (physical 0xA0101000)...
Waiting for host to connect...
Got EDBG_CMD_JUMPIMG
Got EDBG_CMD_CONFIG, flags:0x00000000
Windows CE Kernel for ARM (Thumb Enabled) Built on Sep  6 2006 at 19:11:16
ProcessorType=0411  Revision=7
OEMAddressTable = 80105d34
INFO:OALLogSetZones: dpCurSettings.ulZoneMask: 0xb
Setting up softlog at 0x87ffc000 for 0x800 entries
Booting Windows CE version 6.00 for (ARM)
&pTOC = 81aebc1c, pTOC = 81ad602c, pTOC->ulRamFree = 81af0000, MemForPT = 00001000
Booting kernel with existing memory configuration:
Memory Sections:
[0] : start: 81af2000, extension: 0000d000, length: 064fd000
NKStartup done, starting up kernel.
Windows CE KernelInit
到这停住了,跟踪到了内核初始化函数:
void KernelInit (void)
#ifdef DEBUG
    g_pNKGlobal->pfnWriteDebugString (TEXT("Windows CE KernelInit\r\n"));
#endif
    APICallInit ();         // setup API set
    HeapInit ();            // setup kernel heap
    InitMemoryPool ();      // setup physical memory
    PROCInit ();            // initialize process
    VMInit (g_pprcNK);      // setup VM for kernel
    THRDInit ();            // initialize threads
    MapfileInit ();
#ifdef DEBUG
    g_pNKGlobal->pfnWriteDebugString (TEXT("Scheduling the first thread.\r\n"));
#endif
可见初始化未完成,
void APICallInit (void)
    /* setup the well known system API sets & API types */
    SystemAPISets[SH_WIN32] = &cinfWin32;
    SystemAPISets[SH_CURTHREAD] = &cinfThread;
    SystemAPISets[SH_CURPROC] = &cinfProc;
    SystemAPISets[SH_CURTOKEN] = &cinfToken;
    SystemAPISets[HT_EVENT] = &cinfEvent;
    SystemAPISets[HT_MUTEX] = &cinfMutex;
    SystemAPISets[HT_CRITSEC] = &cinfCRIT;
    SystemAPISets[HT_SEMAPHORE] = &cinfSem;
    SystemAPISets[HT_APISET] = &cinfAPISet;
    // SystemAPISets[HT_FILE] = &CinfFile;
    // SystemAPISets[HT_FIND] = &CinfFind;
    // SystemAPISets[HT_DBFILE] = &CinfDBFile;
    // SystemAPISets[HT_DBFIND] = &CinfDBFind;
    // SystemAPISets[HT_SOCKET] = &CinfSocket;
    // SystemAPISets[HT_WNETENUM] = &CinfWnetEnum;
    KInfoTable[KINX_APISETS] = (DWORD)SystemAPISets;
void HeapInit (void)
    int loop;
    KInfoTable[KINX_KHEAP] = (long)heapptr;
    /* Find the smallest size of block. */
    SmallestSize = heapptr[0].size;
    for (loop = 0; loop < NUMARENAS; loop++) {
        DEBUGMSG(ZONE_MEMORY,(TEXT("HeapInit: Entry %2.2d, size %4.4d\r\n"),loop, heapptr[loop].size));
        DEBUGCHK(IsDwordAligned(heapptr[loop].size));
        if (heapptr[loop].size < SmallestSize)
            SmallestSize = heapptr[loop].size;
    KInfoTable[KINX_HEAP_WASTE] = 0;
    DEBUGMSG(ZONE_MEMORY,(TEXT("HeapInit: SmallestSize = %4.4d\r\n"), SmallestSize));
heapinit的信息都没有打印,这是怎么回事呢,和哪里配置有关系呢,奇怪之前的5.0没遇到过啊
有人指点一下吗  详情 回复 发表于 2009-12-23 15:46
88
有人指点一下吗
