此帖出自嵌入式系统论坛
sound/arm/s3c24xx-alsa-pcm.c:40:32: asm/arch/regs_ac97.h: No such file or directory
In file included from sound/arm/s3c24xx-alsa-pcm.c:41:
sound/arm/ep93xx-alsa-pcm.h:82: error: parse error before "ep93xx_dma_int_t"
sound/arm/ep93xx-alsa-pcm.h:82: warning: no semicolon at end of struct or union
sound/arm/ep93xx-alsa-pcm.h:95: error: parse error before '}' token
sound/arm/ep93xx-alsa-pcm.h:95: warning: type defaults to `int' in declaration of `audio_stream_t'
sound/arm/ep93xx-alsa-pcm.h:95: warning: data definition has no type or storage class
sound/arm/ep93xx-alsa-pcm.h:102: error: parse error before "audio_stream_t"
sound/arm/ep93xx-alsa-pcm.h:102: warning: no semicolon at end of struct or union
sound/arm/ep93xx-alsa-pcm.h:103: warning: type defaults to `int' in declaration of `input_stream'
sound/arm/ep93xx-alsa-pcm.h:103: warning: data definition has no type or storage class
sound/arm/ep93xx-alsa-pcm.h:105: error: parse error before "output_dma"
sound/arm/ep93xx-alsa-pcm.h:105: warning: type defaults to `int' in declaration of `output_dma'
sound/arm/ep93xx-alsa-pcm.h:105: warning: data definition has no type or storage class
sound/arm/ep93xx-alsa-pcm.h:106: error: parse error before "input_dma"
sound/arm/ep93xx-alsa-pcm.h:106: warning: type defaults to `int' in declaration of `input_dma'
sound/arm/ep93xx-alsa-pcm.h:106: warning: data definition has no type or storage class
sound/arm/ep93xx-alsa-pcm.h:111: error: parse error before ':' token
sound/arm/ep93xx-alsa-pcm.h:112: error: parse error before ':' token
sound/arm/ep93xx-alsa-pcm.h:142: error: parse error before '}' token
sound/arm/ep93xx-alsa-pcm.h:142: warning: type defaults to `int' in declaration of `audio_state_t'
sound/arm/ep93xx-alsa-pcm.h:142: warning: data definition has no type or storage class
sound/arm/ep93xx-alsa-pcm.h:149: error: parse error before "audio_state_t"
sound/arm/ep93xx-alsa-pcm.h:149: warning: function declaration isn't a prototype
sound/arm/s3c24xx-alsa-pcm.c:164: error: parse error before '*' token
sound/arm/s3c24xx-alsa-pcm.c:165: warning: function declaration isn't a prototype
sound/arm/s3c24xx-alsa-pcm.c: In function `audio_set_format':
sound/arm/s3c24xx-alsa-pcm.c:167: error: `val' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:167: error: (Each undeclared identifier is reported only once
sound/arm/s3c24xx-alsa-pcm.c:167: error: for each function it appears in.)
sound/arm/s3c24xx-alsa-pcm.c:170: error: `s' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c: At top level:
sound/arm/s3c24xx-alsa-pcm.c:207: error: parse error before '*' token
sound/arm/s3c24xx-alsa-pcm.c:212: warning: function declaration isn't a prototype
sound/arm/s3c24xx-alsa-pcm.c: In function `copy_to_user_U16_LE_CM':
sound/arm/s3c24xx-alsa-pcm.c:213: error: `to_count' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:214: error: `to' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:215: error: `from' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:222: error: `state' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:249: error: parse error before '*' token
sound/arm/s3c24xx-alsa-pcm.c:254: warning: function declaration isn't a prototype
sound/arm/s3c24xx-alsa-pcm.c: In function `copy_to_user_U16_LE':
sound/arm/s3c24xx-alsa-pcm.c:255: error: `to_count' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:256: error: `to' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:257: error: `from' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:259: error: `state' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:285: error: parse error before '*' token
sound/arm/s3c24xx-alsa-pcm.c:290: warning: function declaration isn't a prototype
sound/arm/s3c24xx-alsa-pcm.c: In function `copy_to_user_S16_LE_CM':
sound/arm/s3c24xx-alsa-pcm.c:291: error: `to_count' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:292: error: `to' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:293: error: `from' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:300: error: `state' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:327: error: parse error before '*' token
sound/arm/s3c24xx-alsa-pcm.c:332: warning: function declaration isn't a prototype
sound/arm/s3c24xx-alsa-pcm.c: In function `copy_to_user_S16_LE':
sound/arm/s3c24xx-alsa-pcm.c:333: error: `to_count' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:334: error: `to' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:335: error: `from' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:337: error: `state' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:363: error: parse error before '*' token
sound/arm/s3c24xx-alsa-pcm.c:368: warning: function declaration isn't a prototype
sound/arm/s3c24xx-alsa-pcm.c: In function `copy_to_user_S8_CM':
sound/arm/s3c24xx-alsa-pcm.c:369: error: `to_count' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:370: error: `to' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:371: error: `from' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:374: error: `state' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:401: error: parse error before '*' token
sound/arm/s3c24xx-alsa-pcm.c:406: warning: function declaration isn't a prototype
sound/arm/s3c24xx-alsa-pcm.c: In function `copy_to_user_S8':
sound/arm/s3c24xx-alsa-pcm.c:407: error: `to_count' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:408: error: `to' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:409: error: `from' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:411: error: `state' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:437: error: parse error before '*' token
sound/arm/s3c24xx-alsa-pcm.c:442: warning: function declaration isn't a prototype
sound/arm/s3c24xx-alsa-pcm.c: In function `copy_to_user_U8_CM':
sound/arm/s3c24xx-alsa-pcm.c:443: error: `to_count' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:444: error: `to' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:445: error: `from' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:448: error: `state' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:475: error: parse error before '*' token
sound/arm/s3c24xx-alsa-pcm.c:480: warning: function declaration isn't a prototype
sound/arm/s3c24xx-alsa-pcm.c: In function `copy_to_user_U8':
sound/arm/s3c24xx-alsa-pcm.c:481: error: `to_count' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:482: error: `to' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:483: error: `from' undeclared (first use in this function)
sound/arm/s3c24xx-alsa-pcm.c:485: error: `state' undeclared (first use in this function)
详情
发表于 2007-2-1 10:17
此帖出自嵌入式系统论坛
此帖出自嵌入式系统论坛
此帖出自嵌入式系统论坛
