4134|3
59
skyeye + u-boot + linux2.4 启动失败! [复制链接]
skyeye.conf的内容如下:
#skyeye config file for uboot
cpu: arm720t
mach: ep7312
mem_bank: map=I, type=RW, addr=0x80000000, size=0x00010000
#skyeye for uboot flash 16M bank 1
mem_bank: map=M, type=RW, addr=0x00000000, size=0x00100000, file=./u-boot.bin,boot=yes
mem_bank: map=M, type=RW, addr=0x00200000, size=0x00700000, file=./vmlinux
mem_bank: map=M, type=RW, addr=0x00A00000, size=0x00100000, file=./romfs.img
#skyeye for uboot sdram 16m bank 1
mem_bank: map=M, type=RW, addr=0xc0000000, size=0x01000000
net: state=off, mac=0:4:3:2:1:f, ethmod=tuntap, hostip=10.0.0.1
启动日志如下:
Warning: If you want to run ELF image, you should use -e option to indicate your elf-format image filename. Or you only want to run binary image,you need to set the filename of the image and its entry in skyeye.conf.
arch: arm
cpu info: armv4, arm720t, 41807200, ffffff00, 1
mach info: name ep7312, mach_init addr 0x8077c58
ethmod num=1, mac addr=0:4:3:2:1:f, hostip=10.0.0.1
can't find device module: (null)
uart_mod:0, desc_in:, desc_out:
SKYEYE: use arm7100 mmu ops
Loaded RAM   ./u-boot.bin
Loaded RAM   ./vmlinux
Loaded RAM   ./romfs.img
U-Boot 1.1.2 (Jun 22 2007 - 09:47:58)
U-Boot code: C0F80000 -> C0F96AE4  BSS: -> C0F9AE00
RAM Configuration:
Bank #0: c0000000 16 MB
Flash: 16 MB
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Hit any key to stop autoboot:  0
CS8900 Ethernet chip not found?!
BOOTP broadcast 1
各位大虾帮忙分析下,不知道是什么原因,我的内核和文件系统都在同级目录下。我直接使用skyeye可以启动内核和文件系统,
此帖出自Linux开发论坛
我没有用网络,以前是on,后来我改成off的。  详情 回复 发表于 2007-6-28 14:09
81
没有人帮忙吗?
此帖出自Linux开发论坛
你用了网络么? 把state=off 改成 state=on
此帖出自Linux开发论坛
78
此帖出自Linux开发论坛
