3398|0
编译驱动模块后,导入出现问题,请解决! [复制链接]
我写了一个虚拟的字符驱动,编译没有问题,可是作为模块导入时,却出现如下的错误提示:
unresolved symbol DECLARE_WAIT_QUEUE
下面是源码,请帮忙找一下原因,谢谢!
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#define test_major 253
MODULE_LICENSE("GPL");
static ssize_t test_read(struct file *,char *,size_t,loff_t *);
static ssize_t test_write(struct file *,const char *,size_t,loff_t *);
static int __init test_init(void);
static void __exit test_exit(void);
static wait_queue_head_t outq;
static wait_queue_t wait;
static int head=0,tail=0;
static char buf[10];
struct file_operations test_fops=
read:test_read,write:test_write,
        int ret;
        ret=register_chrdev(test_major,"test",&test_fops);
        if(ret)
                printk("test_dev register failed!!!\n");
        else
        printk("test_dev register success!!!\n");
        init_waitqueue_head(&outq);
        return ret;
        unregister_chrdev(test_major,"test");
static ssize_t test_read(struct file *filp, char *buf1,size_t count,loff_t *off)
  DECLARE_WAIT_QUEUE(wait,current);
  char out_data;
        if(head==tail)
                if(filp->f_flags && O_NONBLOCK)
                        return -EAGAIN;
                add_wait_queue(&outq,&wait);
                current->state=TASK_INTERRUPTIBLE;
                while((head==tail)&&!signal_pending(current))
                        schedule();
                if(head==tail)
                        return count;
                current->state=TASK_RUNNING;
                remove_wait_queue(&outq,&wait);
                out_data=get_bufdata();
                if(copy_to_user(buf1,&out_data,sizeof(out_data)));
                        return -EFAULT;
        return count;
static char get_bufdata(void)
        int last;
        last=tail;
        if(++tail==10)
                tail=0;
        return buf[last];
static ssize_t test_write(struct file *filp, const char *buf1,size_t len,loff_t *off)
  buf[head]=buf1;
  if(++head==10)
  head=0;
  wake_up_interruptible(&outq);//唤醒等待队列
  return sizeof(char);
module_init(test_init);
module_exit(test_exit);
