3177|1
75
Uboot中那个函数可以使其重启 [复制链接]
RT,
想在里面添加一个reboot命令,请了解的仁兄指点.
你是指什么重启,在固件还是驱动中. 如果是驱动中重启,使用的芯片带8051的话,可以使用以下函数 NTSTATUS Ezusb_8051Reset(    PDEVICE_OBJECT fdo,    UCHAR resetBit    ) /*++ Routine Description:    Uses the ANCHOR LOAD vendor specific command to either set or release the    8051 reset bit in the EZ-USB chip. Arguments:    fdo - pointer to the device object for this instance of an Ezusb Device    resetBit - 1 sets the 8051 reset bit (holds the 8051 in reset)               0 clears the 8051 reset bit (8051 starts running)                Return Value:    STATUS_SUCCESS if successful,    STATUS_UNSUCCESSFUL otherwise --*/ {    NTSTATUS ntStatus;    PURB urb = NULL;    urb = ExAllocatePool(NonPagedPool,                        sizeof(struct _URB_CONTROL_VENDOR_OR_CLASS_REQUEST));    if (urb)    {       // toggle the EZ-USB reset bit (harmless on FX2)       RtlZeroMemory(urb,sizeof(struct  _URB_CONTROL_VENDOR_OR_CLASS_REQUEST));       urb->UrbHeader.Length = sizeof(struct _URB_CONTROL_VENDOR_OR_CLASS_REQUEST);       urb->UrbHeader.Function = URB_FUNCTION_VENDOR_DEVICE;       urb->UrbControlVendorClassRequest.TransferBufferLength = 1;       urb->UrbControlVendorClassRequest.TransferBuffer = &resetBit;       urb->UrbControlVendorClassRequest.TransferBufferMDL = NULL;       urb->UrbControlVendorClassRequest.Request = ANCHOR_LOAD_INTERNAL;       urb->UrbControlVendorClassRequest.Value = CPUCS_REG_EZUSB;       urb->UrbControlVendorClassRequest.Index = 0;       ntStatus = Ezusb_CallUSBD(fdo, urb);       // toggle the FX2 reset bit (harmless on EZ-USB)       RtlZeroMemory(urb,sizeof(struct  _URB_CONTROL_VENDOR_OR_CLASS_REQUEST));       urb->UrbHeader.Length = sizeof(struct _URB_CONTROL_VENDOR_OR_CLASS_REQUEST);       urb->UrbHeader.Function = URB_FUNCTION_VENDOR_DEVICE;       urb->UrbControlVendorClassRequest.TransferBufferLength = 1;       urb->UrbControlVendorClassRequest.TransferBuffer = &resetBit;       urb->UrbControlVendorClassRequest.TransferBufferMDL = NULL;       urb->UrbControlVendorClassRequest.Request = ANCHOR_LOAD_INTERNAL;       urb->UrbControlVendorClassRequest.Value = CPUCS_REG_FX2;       urb->UrbControlVendorClassRequest.Index = 0;       ntStatus = Ezusb_CallUSBD(fdo, urb);    }    else    {       ntStatus = STATUS_NO_MEMORY;    }    if (urb)       ExFreePool(urb);    return ntStatus; }   详情 回复 发表于 2007-10-24 09:23
94
你是指什么重启,在固件还是驱动中.
   PDEVICE_OBJECT fdo,
   UCHAR resetBit
Arguments:
Return Value:
   NTSTATUS ntStatus;
   PURB urb = NULL;
   if (urb)
   else
   if (urb)
      ExFreePool(urb);
   return ntStatus;
