7224|21
67
请教下用RIL来处理来电问题,想阻止系统接受RIL_NOTIFY_RING和RIL_NOTIFY_CALLERID有办法么,然后自己处理这几个消息 [复制链接]
请教下用RIL来处理来电问题,想阻止系统接受RIL_NOTIFY_RING和RIL_NOTIFY_CALLERID有办法么,然后自己处理这几个消息,并显示自己的来电界面.
我写了代码,但是执行不到回调函数里面,是什么原因呢,如果用RIL能实现上面的功能么?
代码如下:
typedef void (*PFVOID)();
typedef HRESULT (*PFRIL_Initialize)(DWORD dwIndex, PFVOID pfnResult, PFVOID pfnNotify, DWORD dwNotificationClasses, DWORD dwParam, HANDLE *hRil);
typedef HRESULT (*PFRIL_Deinitialize)(HANDLE hRil);
typedef HRESULT (*PFRIL_GetRegistrationStatus)(HANDLE hRil);
typedef HRESULT (*PFRIL_GetCellTowerInfo)(HANDLE hRil);
typedef HRESULT (*PFRIL_DevSpecific)(HANDLE hRil, BYTE*buf, int size);
PFRIL_Deinitialize RIL_Deinitialize;
PFRIL_Initialize RIL_Initialize;
PFRIL_GetRegistrationStatus RIL_GetRegistrationStatus;
PFRIL_GetCellTowerInfo RIL_GetCellTowerInfo;
PFRIL_DevSpecific RIL_DevSpecific;
fnInitRil()
m_hRilDll = LoadLibrary(L"ril.dll");
if (m_hRilDll)
RIL_Initialize= (PFRIL_Initialize)GetProcAddress(m_hRilDll,L"RIL_Initialize");
RIL_Deinitialize= (PFRIL_Deinitialize)GetProcAddress(m_hRilDll,  L"RIL_Deinitialize");
RIL_GetRegistrationStatus= (PFRIL_GetRegistrationStatus)GetProcAddress(m_hRilDll, L"RIL_GetRegistrationStatus");
RIL_GetCellTowerInfo= (PFRIL_GetCellTowerInfo)GetProcAddress(m_hRilDll, L"RIL_GetCellTowerInfo");
RIL_DevSpecific= (PFRIL_DevSpecific)GetProcAddress(m_hRilDll, L"RIL_DevSpecific");
HRESULT hResult = 0;
hResult = RIL_Initialize(1, NULL, PFVOID(NotifyProc), -1, (DWORD)this, NULL);
GetLastError();                //retVal = TRUE;
LRESULT CALLBACK NotifyProc(DWORD dwCode, const void *lpData, DWORD cbData, DWORD dwParam)
           switch(dwCode)
        case RIL_NOTIFY_CONNECT:
                break;
        case RIL_NOTIFY_DISCONNECT:
        break;
        case RIL_NOTIFY_CALLERID:
                break;
        case RIL_NOTIFY_RING :
                break;
        case RIL_NOTIFY_CALLPROGRESSINFO:
                break;
        default:
                break;
        return 1;
执行不到NotifyProc回调函数里面,请问下
我是用下面的这个弄的
里面的参数如何定义呢?还是其他的问题呢??
也在做相关的内容,顶一个  详情 回复 发表于 2008-12-30 21:44
86
NOTIFY 是广播的,你只能阻止自己的程序,阻止不了其他的程序。
有没有办法设置参数之类的来设置不让这几个消息进行广播呢,或者在进行广播之前屏蔽掉,只让我程序收到并处理,有办法么??????
63
没有的,只有改RIL才可以。
66
哦,那我想实现自己的来电界面,不用系统的来电界面 ,看来是不行了,我曾经用你所说的试了下,把来电界面窗体移走,但是并没有成功,设置静音的话,有时成功,有时失败,看来是不行了,实在没办法的话,只能用系统的来电了
83
主要是用系统的来电,自己的程序不好处理,
自己的来电界面我已经实现了
不过不是采用的ril的方法,而是在注册表添加了自己处理拨号基面的dll
源码可以看我的blog
就是还有一点小bug,开始弹出的界面修改背景后被系统本身的给重绘了
其他的功能已经全部实现了~
85
5.0以上的系统来电界面功能是可以自定义的,你并不需要替换。
具体用法查询 Phone Canvas Customization
57
但是我并不只是替换界面,我想控制来电界面,来电时候,需要的时候显示,不需要的时候不显示,并且没有系统来电声音,根据需要什么时候播放,就什么时候调用自己的程序播放音乐.
界面替换后整个就由你控制啊,至于来电声音,可以在RIL_Ring的时候干掉
65
关键是系统总会收到来电消息,总会弹出来电窗口,无论你用RIL或TAPI都没用
96
HRESULT hr = (*s_pfRIL_Initialize)(1, ResultCallback, NotifyCallback, RIL_NCLASS_ALL, NULL, &m_hRil);
void CALLBACK ResultCallback(DWORD dwCode, HRESULT hrCmdID, const void* lpData, DWORD cbData, DWORD dwParam)
        DWORD *dwNum;
        switch (dwCode)
        case RIL_RESULT_OK:
                dwNum = (DWORD*)lpData;
                break;
        case RIL_RESULT_NOCARRIER:
        case RIL_RESULT_NODIALTONE:
        case RIL_RESULT_ERROR:
        case RIL_RESULT_BUSY:
                break;
void CALLBACK NotifyCallback(DWORD dwCode, const void* lpData, DWORD cbData, DWORD dwParam)
        RILMESSAGE *pMessage = (RILMESSAGE *)lpData;
        switch (dwCode)
        case RIL_NOTIFY_RING:
                break;
        case RIL_NOTIFY_MESSAGE:  //通知消息,也就是我们要处理的消息
                AfxMessageBox(_T("hh"));
                ofstream ofile(" 1.txt ");
                ofile<< pMessage->cbSize<                         <dwFlags<                         <dwParams<                         <dwType<                         <<"\nstart struct:==============="<                         <raSvcCtrAddress.cbSize<                         <raSvcCtrAddress.dwNumPlan<                         <raSvcCtrAddress.dwParams<                         <raSvcCtrAddress.dwType<                         <raSvcCtrAddress.wszAddress<                         <<"end struct:==============="<                         <<"\nstart struct:==============="<                         <msgBcGeneral.cchMsgLength<                         <msgBcGeneral.dwGeoScope<                         <msgBcGeneral.dwID<                         <msgBcGeneral.dwMsgCode<                         <msgBcGeneral.dwPageNumber<                         <msgBcGeneral.dwTotalPages<                         <msgBcGeneral.dwUpdateNumber<                         <msgBcGeneral.rgbMsg<                         <<"end struct:==============="<                 ofile.close();
                ofstream ofile2(" 2.txt ");
                ofile2<msgInDeliver.raOrigAddress.wszAddress<                         <msgInDeliver.rgbMsg<                 ofile2.close();
                exit(0);
                if(pMessage->dwParams & RIL_PARAM_M_FLAGS)
                        if(pMessage->dwFlags == RIL_MSGFLAG_NONE)
                                break;
                //MMS_Decode(pMessage->msgInDeliver.rgbMsg, pMessage->msgInDeliver.cchMsgLength);
                break;
打印的能捕获你接受的消息
但怎么发送呢?
我还不知道!
86
留个胶印,跟踪一下!
88
Mark
61
学习了
那个ril.dll能不能发个给我啊 ,谢谢了。。。35248710@qq.com
不错的贴!DING!!!
不知道楼主有没成功啊!!!
直播时间:3月12日(周三)上午10:00
直播奖励:多功能榨汁机、蓝牙音箱、手机支架
